Question about Maytag MDG7757AW Gas Dryer
Dryer doesn't get hot. Fix or replace? Cost? Home owner.
  • Maytag Master
  • 17,130 Answers
Unless you look into to see a first hand infomatiion the cost cannot be confirmed. So please take a good look and find the cost of the component , like the motor or valve, but have an estimation in mind to decide whether to fix or replace.
Posted on Aug 30, 2010
Replace fuse dryer model GEQ8821LLO
Hello;
My name is Peter. I am a retired field service appliance technician.
You never explained what the problem was. Dryer not running? No heat? Dryer shutting down. It could be as simple as cleaning out your dryer hot air distribution manifold. A dryer will not run if you do not have good air flow due to lint blockage. A dryer will not run if you have a bad door switch. You can Ohm components out with a multi-meter, setting the meter to the lowest Ohms (Omega Symbol). You should get a reading of "0" if the component is good.
1.) Dryer Door Switch - This switch replaces your dryer door's switch.
  • You may need to remove your dryer's lint screen and lint screen housing before lifting its top panel to reach its existing switch.
  • Be sure your dryer is unplugged during installation.
This Dryer Door Switch part #3406107 Cost $20.00
Dryer Door Switch - Unplug the dryer before replacing the door switch.
This Dryer Door Switch part #279782 Cost: $22.00
Thermal Cut-Off- This component is located on your heating element housing,. you may be able to access it at your hot air distribution manifold in the back of your unit.
  • When replacing your dryer's fuse, replace its thermostat, too. The thermostat should have prevented the dryer's existing fuse from blowing. The high-limit thermostat is functional to 250 degrees (Fahrenheit) and the thermal cut-off fuse to 360 degrees (Fahrenheit).
  • Install the fuse in your dryer's heater element housing box. Be sure your dryer is unplugged during installation
  • Part #: 3977394 Cost: $33.00
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-9.jpg Cost: $34.00
    The high-limit thermostat replaces your dryer's thermostat.
    • The thermostat is functional to 250 degrees (Fahrenheit).
    • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
    This High-Limit Thermostat part #3390291
    Hot Air Distribution Manifold:
    This is in the back of your dryer and easily unbolted. If you are plugged up with lint your unit will shut down. Remove this component and clean the lower discharge end.
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-14.jpg So, tell me what the problem is, and I will tell you how to fix it.
    Peter,
    Glen Burnie, Maryland, USA
    Feb 15, 2015 | Whirlpool Dryers
    Where is the reset button?
    There is no reset button, the issue is most likely a heating element
    Feb 02, 2015 | LG DLE7177WM 7.3 Cu. Ft. Electric Dryer -...
    My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
    Hello there and welcome to fixya there are several things that could make this dryer not heat up
    Here are the most common things
    Thermal Fuse
    If the dryer doesn\'t heat, but the drum
    turns, check the thermal fuse(s). The thermal fuse protects the dryer
    from overheating and helps to prevent fires. If the thermal fuse is
    blown, it will have to be replaced.
    Enter your model number to see parts for your dryer.
    Help me find my model number
    Gas Valve Solenoid
    The gas valve has two or more electric
    solenoids which open the valve to let the gas flow into the burner
    assembly. If the dryer doesn\'t heat one or more of the solenoids may be
    defective. If the igniter glows for 90 seconds but the burner flame
    doesn\'t light, replace these coils as a set.
    Dryer Igniter
    If the dryer doesn\'t heat, the igniter might
    be burned out. Check the igniter for continuity with an ohm meter. Dryer
    igniters burn out over time, similar to a light bulb.
    Heating Element
    The heating element on an electric dryer can
    burn out over time. If the dryer doesn\'t heat, the element should be
    checked for continuity. The heating element cannot be repaired and must
    be replaced if defective.
    Heating Element Assembly
    the heating element assembly on an electric
    dryer can burn out over time. If the dryer doesn\'t heat, the element
    assembly should be checked for continuity. The heating element assembly
    cannot be repaired and must be replaced if defective.
    Flame Sensor
    Gas dryers have a flame sensor to detect the
    heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
    might be defective. Check the flame sensor for continuity. This is not
    as common as a burned out igniter or thermal fuse.
    High Limit Thermostat
    Although not common, if the dryer doesn\'t
    heat the high limit thermostat can be defective. It can be checked for
    continuity. If the thermostat is "open" the dryer doesn\'t heat.
    Cycling Thermostat
    The cycling thermostat regulates the
    temperature of the air in the dryer. If the dryer doesn\'t heat it may be
    caused by a defective cycling thermostat. This is not common.
    Main Control Board
    The main control board is normally not at
    fault when the dryer doesn\'t heat. Check all of the other components in
    this troubleshooting guide before replacing the main control board. The
    main control board cannot be tested easily and must be replaced if it is
    defective.
    Timer
    The timer is normally not at fault if the
    dryer doesn\'t heat. In many situations where timers are replaced they
    end up being returned. Check all of the more common components in this
    troubleshooting guide before replacing the timer
    Oct 14, 2013 | Dryers
    Reset dryer
    there are thermal one time use fuses and your heater element may also be faulty.
    here are more info of fuse locations etc.
    http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-3--RFBHVDc1MEVDIA==/GE-Dryer-doesn-t-heat
    Jun 14, 2013 | GE Profile Harmony DPGT750EC Electric...
    Dryer doesn't shut off and doesn't get hot
    Look at this video to help you fix the no heat issue.
    Nov 14, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
    DRYER STOPS/STARTS DOESN'T GET HOT ENOUGH
    dryer duct blockage caused thermal limiters to trip. four t 20 screws remove the heater bank cover on the back of the dryer. unplug the dryer. unplug the dryer. did i forget to mention, unplug the dryer? remove the heater bank cover, and press the three red buttons in the center of each thermal limiter. at least one of them should click when you press it. replace the cover, plug the dryer in. it will now heat, but if you dont fix the blockage it will trip again.
    Jun 14, 2012 | Miele T9800 Electric Dryer
    My dryer doesn't heat up any more, I would like to repair it by myself. Where do I find the replacement part on the dryer
    Bosch sells parts online. The parts arrive at your home in about 2 business days after you place your order.
    The website link: http://www.bosch-home.com/us/support.html
    Sep 06, 2011 | Bosch Nexxt 500 Dryer
    MY DRYER HEATS ALL THE TIME IT IS PLUGGED IN..I HAVE TO KEEP IT UNPLUGGED SO IT WON'T HEAT..IT HAS GOTTEN SO HOT THAT IT HAS MELTED PART OF ONE OF THE PLASTIC DIVIDERS IN THE DRUM..WHAT WOULD BE THE...
    This could potentially be a very dangerous situation. If you would forget, leave clothes or something else flammable on top of the dryer and leave the dryer plugged in, you could come home to a house burned to the ground, not even considering what could happen if someone was in the home at the time. If it has been hot enough to melt one of the clothes tumblers inside the drum, it could, conceiveably have been hot enough to have melted some of the insulation off some of the wiring inside the unit. The only way to tell for sure would be to disassemble the unit to have it inspected, which could cost a fair sized bill in itself, not to mention what it could cost to replace that wiring. In light of this I would suggest just starting a search for a new dryer. Sorry.
    Mar 01, 2011 | KitchenAid KEYS750LQ Electric Dryer
    Dryer doesn t get hot
    it is going to be either the igniter for the gas or the heating element
    you probably have an electric igniter. it is not igniting the gas to make the dryer heat i would definantly start with that
    Jan 07, 2009 | Kenmore Dryers
    Maytag MDG7757AW Gas Dryer Logo
    37 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
