Question about Microsoft Xbox 360 Console
I have an xbox 360 and i have the three red lights error and the secondary code is 0020. i have done the x-clamp fix. and i know i am doing something wrong in this fix please please help me.
  • 767 Answers
0020 is open connection under the G.P.U. 90% of the time.
If you removed the heatsink studs and the x clamp then screw down
the G.P.U.'s heat sink followed by a forced over heating of the G.P.U.
Then you did nothing wrong as far as the stander procedure goes.
The connections under the G.P.U. have to much gaping to be
compressed back the pads.
Your second option is to have the G.P.U. re flowed with
proper clamping to insure it stays connected .
This will give the longest lasting repair .
The x-clamp mod repair last 1-3 months on average
and it will warp the board under the G.P.U. and
becomes very difficult to repair after that .
Just something to think about.
if you have any questions feel free to ask
Rob
Posted on Aug 30, 2010
How to fix a xbox 360
RRoD is like a BSoD on Windows. It's a fatal error and a primary code. It doesn't tell you anything at this stage and the code is so generic, if can be anything from the PSU being faulty/not being connected to a specific component fault. You therefore need the Secondary Error Code (google it). If you get anything like 0102, 0020, 0110 then it's extremely possible the problem is with the GPU. Ignore any videos regarding heatguns, towel tricks or clamping / bolting. you'll just make it worse. The solder balls which attach the GPU to the main board need replacing. This is done by special equipment and is a proper fix, unlike the methods mentioned above. In extreme cases, the actual GPU needs to be replaced.
Aug 21, 2012 | Microsoft Xbox 360 Console
Hi! i got those damn three red lights and get an error code 0020 what is wrong??? thank you :)
Unfortunately, the 0020 error means that the motherboard of the console is overheating and bending the board loses contact with the heat sink and GPU (graphics processor unit). If the unit is under warranty, contact Microsoft Xbox support. (The warranty for the 3 red light issues was extended to a 3-year warranty.)
If it is out of warranty, there are a couple of things to try. 1) Modify the X Clamp on at least the GPU; sometimes the X Clamp on the CPU also needs to be fixed. Remove the heat sink and put a better coat of thermal paste on the processors. Then either replace the original heat sink or use a better one. http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
2) Some people have fixed the problem by heating the entire motherboard with a heat gun to straighten out the entire board. (Protect the capacitors and other parts on the top of the board with towels.)
I hope this helps.
(there are other procedures for the X Clamp mod given online; google to find them)
Oct 18, 2010 | Microsoft Xbox 360 Console
Red flashing light and having a code E73
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Sep 06, 2010 | Microsoft Xbox 360 Pro System Console
Secondary error code 0020 fix
Some consoles just aren't fixable. It's not common, but does happen. This is why I recommend only having a repair done by an experienced professional.
Dec 30, 2009 | Microsoft Xbox 360 Console
Error Code 0020
First, my xbox would have one red light and E 74. Then when I opened it up and booted it I got three red lights and 0020. I took out the motherboard, replaced the heatsink compound and did the x-clamp fix, but I couldn't get nylon washers in the right size so i just used no washers at all. Varying the tightness of various x-clamp bolts gave me 0020, 0003, 0002, 0001, or it would boot up to the black screen and I'd get E 74 again. Other times the xbox would almost immediately overheat. Most of the time I would get 0020, though. At that point, I gave up and I just tightened up the bolts replacing the x-clamp a certain way (nothing seemed special about it) and put the motherboard back in the case without testing it. I screwed everything back together, and since the heads of the bolts were thicker than they should have been, the motherboard didn't really sit flat in the metal cage. But i just screwed the motherboard back into the cage not to tight with the 9 small silver screws, which I would imagine put some stress on the mobo. Then I pu the rest of the case on and the 6 long screws, and once I had snapped everything back together I tried booting it up. To my great surprise it booted up fine! I played some halo 3 and it has booted up fine every time (3 times) since then
Many people have got this error You need to replace the xclamp and make sure there's extra pressure (less than half a turn) on the front right corner of the GPU. You can read more about xclamp replacement here.
its not an issue with ur HDD so no worries....
regards iversh
a very helpful rating is appreciated for answering ur query
Sep 17, 2009 | Microsoft Xbox 360 Console
Xbox 360 had 3ROD W/error code 0102 now its 0020
error code 0020 is a overheating error.You need to do the X-clamp fix.That should solve your problem.Did you use the Acrylic silver thermal paste?
Aug 31, 2009 | Microsoft Xbox 360 Console
Error code 0020
a solution?!ok my suggest is throw away the fuckin' 360 'n buy a PS3.every time i fix that ***** another fuckin code appears.i've had 0102,0001,0020.0133!so the solution is fuckin' the fuckin' Bill Gates 'n all the microsoft./
Jan 05, 2008 | Microsoft Xbox 360 Console
Xbox 360 0020 error code
here is a site i found that shows detailed fixes for this error with your 360's - here it is
360 Xbox problem Three red rings
3 Red lights problem is one of the most common problem of Xbox 360. You will have to either get it repaired from Microsoft (in case your Xbox's warranty is not expired, but one thing to note is that you will have to wait for at least 3-4 weeks to get back your Xbox) or you can Fix your Xbox's 3 Flashing red lights problem yourself with the help of DIY Video guide available on Internet. You can fix yourself without any technical knowledge.
Nov 15, 2007 | Microsoft Xbox 360 Console
Xbox360 error code
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
0023 (not yet known)
0101 (not yet known)
0102 unknown error
Oct 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
50 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
