Question about Lexmark Office Equipment & Supplies
My typewriter dosen't come on when you turn it to "on" It was working fine.
  • Lexmark Master
  • 3,594 Answers
Probably not a good thing, power supply 95.00 or a board 125.00 plus a tech.
DickyO
Posted on Aug 30, 2010
My Carriage moves all the way left, hits the stop, then errors out.
wo things first spray a little WD40 on the silver shaft that the carrier slides on, if that dosen't work you have to get some lube on nthe carrier motor bearings located on the loweright rear under the case.
The front one can be accessed from inside the T/W the rear you have to fish the straw thrfu the case.
DickyO
Oct 01, 2012 | Lexmark Wheelwriter 1500 Typewriter
Ribbon doesn't raise up enough to let the letters strike it. Is there an adjustment somewhere?
If it dosen't lift at all wiggle the large black gear bakand forth a few times they do get tooth for tooth.
DickyO
Jun 30, 2012 | IBM Wheelwriter 6 Typewriter
My Nakajima AE-710 margin release does not work. How can I reset to factory settings?
When using the margin release DON'T HOLD IT DOWN just press and release. if this dosen/t work turn off the machine and see if the carrier will move both ways relatively freely if not look fot debris and spray a little WD40 on the silver shaft that it slides on.
DickyO
May 08, 2012 | Nakajima AE-710 Typewriter
IBM Selectric: Why does ball keep typing in the same spot when it gets to middle of the carridge? Space past that spot and it types fine. Hopefully, there is a simple fix. Thanks.
There are 2 black plastic dust covers that get bowed after the years and catch the carrier at the seam where they meet. They may just be loose so first try pushing them down. If that dosen't work take a sharp object and round off the top edge where they meet. If all fails gently remove them it will work fine without them.
DickyO
Apr 26, 2012 | IBM SELECTRIC2 refurbished selectirc ii 2...
Will not change out of the bold print. I am doing what the manual says to get out of Bold print, and this will not work. Thanks
I believe there is a key in the top row that is labeled in green BOLD. Hold the ALT key and pressing it should turn it off. If it dosen't try CODE and that key.
DickyO
Jun 01, 2011 | Brother GX-6750 Typewriter
The ribbon is not moving. typing in same spot only.
If the ribbon is just moving a little you may be in the overstrike ribbon mode try code period, comma or slash I can never remember which to get out of the mode if that dosen't do it try a new ribbon.
DickyO
May 28, 2011 | Nakajima AE-800 Typewriter
Left margin release doesn't work. Seems to decide for itself where the left tab margin will be, and that could be anywhere.
Put a shot of WD40 on both sides ofthe silver silver shaft that the carrier slides on, if that dosen't do it you have to lube the carrier motor that's in the R. rear corner under the case.
DickyO
Apr 25, 2011 | Lexmark Wheelwriter 2500 Typewriter
Continuous beep at start up. Nothin works except cap lock light so codes or margins can't be changes.
Doesn't sound good. Be sure the upper cover is fully closed, check for debris in the carrier area, give the silver shaft that the carrier rides on a shot of WD40, be sure the ribbon and L/O are properly installed and the print wheel dosen't have broken spokes.
DickyO
Apr 12, 2011 | Nakajima AE-800 Typewriter
Erase key
When you press the correcton key it should backspace and lift off the print, if it makes the movement and dosen;t correct check to be sure you have a correctable ribbon (orange or yellow knob), be sure the correction is installed properly dull side facing the paper.
DickyO
Jan 22, 2009 | Olympia Mastertype 3 Typewriter
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
