Question about Packeteer PacketShaper 2500 Network Monitoring Device
I'm using a PacketShaper® 2500 Software Version: 5.3.0 i can't gain touch access to the unit. is there a way to do a hard reset of the unit instead of using the console cable?
Garmin 2460 software reset
There are 2 different reset modes, a soft reset and a hard reset.
A soft reset is done by holding down the power button for at least 10 seconds and letting the Nuvi restart.
A hard reset will return the Nuvi to factory specification and will clear all user data like the favorites.
Hard Reset:
1.Start with the unit OFF and unplugged from power
2.Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
3.Continue touching and holding the lower right hand corner of the screen then power the unit ON
4.Release the power button when the device powers ON. You will see a new message: Do you really want to erase all user data?
5.Remove your finger from the touchscreen when this message displays
6.Touch Yes
The device will automatically reset. Follow the on screen prompts.
Dec 26, 2011 | Garmin Nuvi 2460LMT GPS Receiver
Touch screan does not work on nuvi 760. Everything else works. Does not respond when touching screens. Can't change menus
Try performing a soft reset or a hard reset to the unit.
The soft reset is done by holding the and sliding the power button on for at least 10 seconds and allowing the unit to power on.
A hard reset is done by pressing and holding the bottom right hand corner of the screen while the power is off and then pressing the power button on. A pop up will appear asking to confirm the reset.
The hard reset will erase the user data, so it is advisable to save the data if possible.
Installing and running the Garmin WebUpdater to load or reload the latest update will resolve most issues.
download the latest version of WebUpdater software
You may also want to contact Garmin support for assistance.
http://www.garmin.com/us/support/contact
Sep 28, 2011 | Garmin Nuvi 760 Car GPS Receiver
I want administrator or root user name and password for packet shaper 2500
There is no root access, the OS is not *nix ish, there are 2 levels of access:-
look and touch, depending on the password entered takes you to the relevant level of access
Mar 18, 2011 | Packeteer PacketShaper 2500 Network...
I forgot the password to my ipod touch
There is only one way, you must restore the ipod which wipes out everything if you forgot it.
Updating and Restoring iPod touch Software
You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch.
• If you update, the iPod touch software is updated. Your downloaded applications, settings, and data aren’t affected.
Note: In some cases, an update may also include restoring iPod touch.
• If you restore, the latest version of iPod touch software is reinstalled, settings are restored to their defaults, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. If you’ve backed up iPod touch with iTunes on your computer, you can restore data from the backup at the end of the restore process.
Deleted data is no longer accessible via the iPod touch user interface, but isn’t erased from your iPod touch. For information about erasing all content and settings, see “Resetting iPod touch” on page 122.
Update or restore iPod touch:
1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes.
2 Connect iPod touch to your computer.
3 Select iPod touch in the iTunes sidebar and click the Summary tab.
4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available.
5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
For more information about updating and restoring iPod touch software, go
Feb 06, 2010 | Apple iPod touch
My ipod touch is locked and i forgot the passcode and its disabled and i cant link it up to itunes unless i unlock it which i cant
Updating and Restoring iPod touch Software You can use iTunes to update or reinstall iPod touch software, restore default settings, and delete all data on iPod touch. ââ If you update, the iPod touch software is updated but your downloaded applications, settings, and songs are not affected. ââ If you restore, the latest version of iPod touch software is reinstalled, default settings are restored, and data stored on iPod touch is deleted, including downloaded applications, songs, videos, contacts, photos, calendar information, and any other data. In iTunes 7.7, you can also restore from a backup without deleting data stored on iPod touch. Note: Deleted data is no longer accessible via the iPod touch user interface, but is not permanently erased from your iPod touch until it is overwritten by new data. For information about permanently erasing all content and settings, see “Resetting iPod touch” on page 94. Update or restore iPod touch: 1 Make sure you have an Internet connection and have installed the latest version of iTunes from www.apple.com/itunes. 2 Connect iPod touch to your computer. 3 Select iPod touch in the iTunes sidebar and click the Summary tab. 4 Click “Check for Update.” iTunes tells you if there’s a newer version of the iPod touch software available. 5 Click Update to install the latest version of the software. Or click Restore to restore. Follow the onscreen instructions to complete the restore process.
May 07, 2009 | Apple iPod touch
Touch Screen fails to work
get it serviced?
my guess, damaged screen.
most shops would touch any Ipaq.
why not ask on a real HP forum?
my guess, the only hope for old Ipaq
http://h30434.www3.hp.com/
May 10, 2017 | HP iPAQ hx2190 Pocket PC
How do I get files from the EHD, won't allow access, disk is full
you should try demo version of some recovery software like R-Studio or GetDataBack.
Nov 30, 2008 | Computers & Internet
MY PHONE HAS BEEN BLOCKED FOR PHONE ACCESS HOW DO I GAIN ACCESS
i am a customer if tata indicom walky prepaid connection my phoen has been blocked plz tell me what can i do for unblocked my phone my email is - tanuj_bhatia6457@yahoo.co.in
Mar 27, 2008 | HTC Touch P3450 Smartphone
How to hard reset magellan 700
Hussam.. I believe the newest software upgrade you can get for the 700 is version 4.32 which is the same version used on the 760's. The maps are stored on the hard drive, so I do not think a reset will help but here is how it's done. 1. At the user select menu (first screen to appear after initial turn on) hold down the zoom out key (-) and the repeat button (on top of your unit). 2. Once at the "secret" menu, select reset user data. This will reset all of your personal information from the unit. All of your POI's will be deleted as well as your user name (which you can re-create of course) 3. Your unit will re-boot automatically and that's how you reset your unit. Like I said though, I do not think this will revive your maps. If you have the maps on a DVD-CD then you can reload them that way, otherwise send it to the Fort Worth, Tx repair center and they have the proper program to load data directly to the hard drive. Good luck! -Daniel
Jun 28, 2007 | Magellan RoadMate 700 GPS Receiver
Garmin eTrex Legend
Do the following: 1 - Make sure you have fresh batteries in the unit and turn the unit on. 2 - Check the GPS date and Time. On the Main Menu at the bottom of the screen, you can see a date and time. If the date and time are not current, then the clock is your problem. You will have to wait for the almanac information to be updated. Details are below in a later section. 3 - Make sure your GPS is in the Normal Mode and not a demo mode. Verify other systems settings. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. Verify the following settings: GPS: normal WAAS: Enabled Language: English or your choice. Battery: Set according to your battery types. 4 - Check your GPSs Version Software. Go to the main menu and click on Setup icon. From the Setup screen, access the System screen icon. From the System screen, access the sub-menu icon in the upper right bar. Select "Software Version" from the list. Verify the actual software version for me. The latest version available for the eTrex Legend is version 3.90 dated March 2008. http://www8.garmin.com/support/download_details.jsp?id=711 Update the unit using this latest software and using Garmin's Webupdater. http://www8.garmin.com/products/webupdater/howtoinstall.jsp If that won't work, use the following download page to access the latest software updates per units. http://www8.garmin.com/support/blosp.jsp 5 - Resetting your GPS clock and almanac information Next you may need to acclimate your unit to a new date and time (almanac information). If you had your unit off and without batteries for over a month since you last accessed satellites, then your clock and almanac information may be incorrect. Even Garmin acknowledges this problem after software updates and the problem with accessing satellites. They state: "unit data including alamanac information may be incorrect or cleared. Back up all user data before upgrading. After installation is complete, place unit with a clear view of the sky for 15-30 minutes to re-acquire almanac data. " I know of no way to reset the clock using the GPS menus. All I can suggest is that you do the following: A - turn the unit on and wait 5 minutes or so for the "Poor Satellite Reception" screen to appear. See page 7 of the owner's manual. B - Set the "new location" to your area using the map when the "poor satellite reception screen" appears. Be sure to use the "map" option and not the "automatic". C - Set the GPS outside with a clear view of the sky. Check on it every 10 minutes. When the "Poor Satellite Reception" screen appears again, then click on "Restart Search". The "Restart Search" option is used when the date provided in the GPS is not today's date. (See page 7 of the Owner's manual for an example) Legend Owners Manual: http://www8.garmin.com/manuals/eTrexLegend_OwnersManual.pdf D - Once the GPS can track 4 satellites, then the clock should reset and you should be fine. This process could take up to an hour. I have had this problem with my eTrex Vista and eTrex Legend (both backup GPSs) and resolved it by having the clock reset. In fact, I just tried my eTrex Legend today after not using it for many months and storing it without batteries and it had this same problem. I followed the steps above to fix the problem. This took about 35 minutes.
Mar 28, 2007 | Garmin eTrex Legend GPS Receiver
Packeteer PacketShaper 2500 Network Monitoring Device Logo
79 people viewed this question
Top Packeteer Computers & Internet Experts
David Payne
David Payne
Are you a Packeteer Computer and Internet Expert? Answer questions, earn points and help others
