How to configure or add WAP 610N as Repeater with the same type WAP610N Accesspoint connected to the dsl modem using internet the purpose is to increase the signal level at the dead spots at my home if not possible is there any sollution Kind Regards A Mateen..
gunja
  • 43 Answers
SOURCE: PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Posted on Nov 01, 2007
kakee
  • 1268 Answers
SOURCE: Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Posted on Nov 25, 2008
2Gigs
  • 141 Answers
SOURCE: how to add a netgear wgr614 router to dsl modem
The NETGEAR router needs to be configured. Call NETGEAR. Try this also http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
SOURCE: Connection using DSL-2640T
Try this. It was meant for configuration with Streamyx but you can ask your ISP for the required values circled in the pictures.
http://whatidoonmymac.wordpress.com/2009/05/12/d-link-dsl-2640t-wireless-signal-on-but-no-internet/
good luck!
Posted on May 19, 2009
SOURCE: how to configure the netgear modem?
hello
how to configure adsl modem router netgear dg834gt
Posted on Jul 06, 2009
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
D-Link DSL-2750U N300 ADSL Modem Wireless Router configuration with Hathway
YES THATS TRUE. TO CONFIGURE THE ROUTER. NEED THE PPPOE USERNAME AND PASSWORD FROM THE INTERNET SERVICE PROVIDER. VPI AND VCI SETTINGS.
..THEN ACCESS THE ROUTER PAGE
..GO TO ADVANCE SETUP PAGE.
..THEN LAYER2 INTERFACE
..CLICK ADD
..CONFIGURE THE SETTINGS.
..POWER CYCLE THE NETWORK.
Nov 21, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
Access point wap 610n constantly rebooting in every 10 minutes
Unfortunately you will likely need to replace the router. it sounds like the firmware is completely shot.
Jul 21, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
I want to connect my HD TV to the internet, wirelessly thro my home network. I have purchased an access point (Linksys WAP610N) but that doesn't appear to support my application. Should I be using a...
An access point is used to extend the signal.
Have you set it up by putting the MAC address of the WAP into the router and vsetting it up as a repeater?
Watvh this video:
http://www.youtube.com/watch?v=0I6vKp_XuSQ
After you setup the WAP correctly, the TV should pick up the signal.
Jul 02, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
IS CISCO LINSYS WAP-610 AN AP REPEATER Range extender?
You cannot use the WAP610N in repeater mode unless you connect it to your router using a cable.
Dec 14, 2010 | Linksys by Cisco WAP610N Wireless-N Access...
Diffrent between Dynamic&static ip address
Static IP address is usually a single IP address provided by the ISP to you, which can be configured so that you can run a web server (host web sites etc), or access your home computer from any where in the world ( your computer and internet should be on ).
Dynamic IP address is usually IP address provided by the ISP to your DSL modem / computer (for dialup modems) for that internet session, next day or next time you connect the IP address will be a different one. (usually home internet connections are Dynamic IP based.
In a typical home environment if you have one wireless adaptor and planning for a wireless repeater its better to configure dynamic IP address in the repeater (so that you repeater will acquire IP address from the wireless adaptor)
Dec 09, 2010 | Computers & Internet
Is there wireless repeater option in this linksys wap 610 n model
No, there is not. I actually called Cisco and was told it would work, but after searching on the internet for the configuration options, it turns out it WILL NOT.
Cisco needs better pre-sales reps. That is a lot of money down the drain thanks to their not so educated staff.
Sep 20, 2010 | Linksys by Cisco WAP610N Wireless-N Access...
Wap 610n
just no the defauld ip address for wap 610n
Sep 10, 2010 | Linksys by Cisco WAP610N Wireless-N Access...
Dlink accesspoint doestnot connect with playstation3
The Dlink wireless modem is configured correctly and the computer/laptop can access the Internet wirelessly.
The PS3 needs to be configured with the Dlink modem's wireless settings so it can communicate with the wireless modem.
To configure the PS3 please follow these steps :-
1. Power up the PS3 and login then Select Network Settings and
press X
2. Select Easy then press > button
3. Select Wireless then press > button
4. Select Scan then press > button
5. Select the wireless modem you want to use, then press X button
6. Confirm the SSID for the wireless modem then press > button
7. Select the security settings (ie WAP, WPA - this is the in the wireless modem settings) then press > button
If there is no encryption I suggest you enable the encryption on the wireless modem, use passphrase to generate the encryption key.
Write down this encryption key, you will need this key for your computers and PS3.
8. Enter the WEP or WPA encryption key (from the wireless modem) then press > button
9. Check the settings then press X button
Dec 23, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Connection Problem
update the firmware of the all device
Feb 23, 2008 | SMC EZ Connect g SMCWEBT-G
Computers & Internet Logo
919 people viewed this question
David Payne
David Payne
