Question about Logitech QuickCam for Notebooks Pro Personal Web Camera
I am looking for the stand that goes with the quickcam. It came with a base and a couple of sections...my base does not seem to hold the bottom section...I think a piece of plastic broke off. Can I get another one?
    Problem Solver:
  • 5 Answers
Ok,thank you!!
Posted on Oct 09, 2010
How to remove a sylvania tv stand
From the bottom there should be a couple of screws to hold the base on. If they are not there then you need to remove the concealment panel at the base where the stand goes in. Once that is off you will see 3 or 4 screws holding it on.
Dec 12, 2015 | Sylvania LC370SL8 37 in. LCD Television
How do I tilt my KDS 92 MWDB monitor. There are 2 buttons on the base of the stand but they don't seem to do anything. I'm afraid to put too much pressure pushing back for fear of breaking it.
Be gentle, but apply pressure if needed. The buttons may require you to hold both in, then tilt the screen. Some models have switches, button, or other things to manipulate the tilt. Check the bottom and the back to be sure.
May 14, 2011 | KDS Computers & Internet
How do you remove the bottom stand from the TV set so you can hang it on the wall? I have unscrewed the bottom of the stand, but there seems to be something internal keeping it attached to the TV.
Most flat TV's actually have the stand held on by 4 screws on the back of the TV, not the bottom. Look closely and you should see them down 4 small holes. These hold the stand on. I think what you may have done is taken the bottom plate of the stand.
Hope this helps
TV_Doctors
Jan 06, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Agitator not moving--seems loose
This washer has what we call a bionic agitator and this agitator has a 2 parts:
it has a base and a top section.
IF the BASE IS NOT WORKING AT ALL, please have the transimssion checked and also check the coupling.
IF the BASE is working and the top is NOT
THEN replace the 4 plastic AGITATOR DOGS that are in the agitator.
Remove the CAP from the agitator...remove any plastic cap.
Get a socket wrench and get the socket that removes the bolt.
remove bolt...
PULL the agitator from the base and separate the top from the bottom.
Take the top and turn it upside down to remove the platic interior part that holds these 4 dogs. REMOVE the old dos and replace with new and do a reverse engineeriong putting agitator back.
Nov 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I'm trying to wall mount my Proscan 19LB30Q LCD. According to the manual, to remove the base, you simply take out 3 screws from the back near the base and pull out the stand gently. I can't remove the...
Although the instructions don't mention this, you also need to remove two screws on the bottom of the base. Pull the base bottom off. Then remove another screw that holds the base post on.
Nov 17, 2009 | Proscan Televison & Video
How do you replace the stand for a 26 digistar tv
look for rubber pads on the rear or bottom of unit, if you peel them back usually you will find the screws that hold the base to the tv
Apr 11, 2009 | Televison & Video
How to remove the stand
On the the sticker on the back of my SONY kdl-40xbr1, where the model number is, there is the symbol > x 18.  That means you need to remove the 18 screws on the back of the tv that have arrows next to them.  Most are around the outside but 2 were by the RCA inputs and 2 were under the cover for the computer input.
Once you remove all these screws the back will come off easily.  Remove the 4 screws holding the base on, slide it off and refasten on the back with the 18 screws.
Thats it.
Jun 25, 2008 | Televison & Video
Opening the monitor
These are a snap to open.
Put a towel on a flat surface like the dining table.
Remove the 2 screws that hold the stand in and slide the stand out of the hole.
Remove the screw in each of the 2 bottom corners.
Remove the screw in the middle at the bottom (it was under the stand to begin with but some do not have it for some reason.)
Now comes the easy part.
Put a few fingers onto the section the power plug goes into.
Tuck your thumbs into the hole left by the stand.
Push into the power plug section downwards with your fingers at the same time pull upwards with your thumbs. The rear panel should pop up. Gently pop it all around the edges.
Hope that helps =)
Apr 10, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Agitator (can't get to the dogs)
Not sure if you mean the agitator is stuck to the shaft or the agitator will not separate now that you have it out of the machine, if the agitator is stuck, you may be able to get it loose by rocking it back and forth while pulling up on the base or bottom of the agitator. If you have the agitator out already, then stand on the base and pull up sharply on the top section and it will separate.
Jan 09, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Logitech QuickCam for Notebooks Pro Personal Web Camera Logo
26 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
