Question about Car Audio & Video
Im trying to install a clarion head unit in my car now i think im ment to connect the red ignition and yellow power together ? or is it yellow power and yellow memory together ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
Neither. yellow needs to go to a constant power source and red needs to go to a switched (ignition) power source.
Posted on Aug 30, 2010
Fitting a jvc head unit to a 1990 telstar tx5 does the yellow wire from car connect to yellow from jvc and does red access. wire from car connect to red from jvc. because have tried this nothing happening...
get a voltmeter(multimeter) and check the voltage on the
red wire
and
yellow wire
(from the car)
when the car is turned off and when the car is on
one should be 0V when the car is off
and both should be 12V when the car is on
then you need to match that up with the radio using the manual
but im guessing that you dont have a manual so...
i want ot confirm that
when you connect red to red and yellow to yellow
nothing happens
try the oposite way
red to yellow yelolow to red
May 29, 2010 | Car Audio & Video
I installed a clarion cd player now cd plat doesn't shut off
THe red wire is to be connected to power from the ignition.Meaning this wire should only be hot, when the ignition is on..
Sep 07, 2009 | Clarion DB538RMP CD Player
We had a clarion reciever with tape deck in our boat and found another clarion reciever with two new speakers and two good 1996 speakers which had not weathered. The instalation was difficult but the...
As long as you have connected the ground(black) try adding one wire at a time to the live(red). If possible try connection each wire one at a time to the power line and then both together. If nothing has blown(fuses) and the unit starts working then you can try by trial & error method the remaining wires. You should be able to figure out which wire is required and if there are any extra wires like cellular phone(mute) and then decide whether to connect them or keep them open.....sodeep
Jul 27, 2009 | Clarion DB245 CD Player
Kenwood head unit not powering up help please.
find your remote wire. it would help to know the type of car and the kind colors of wires your using as your 3 main wires.
normally in most chevy and fords they are yellow 12 volt.
black as ground.
red sometimes even a tan as your remote start.
deff check your start
May 09, 2009 | Kenwood KDC-W6027 CD Player
Have to manually power on and off
Try to connect the RED and the YELLOW wires from the unit to the ACC ( ignition ) wire. My car has 2 lead wires. I only connected to the ignition wire, and the unit turns on/off with the car. Check the wiring diagram for your car see if it's applicable for you. Good luck.
Feb 04, 2009 | Clarion MAX385VD Car DVD Player
I tried to install a radio but im not getting any power to the stereo when I turn the car on to acc.
ok did you hook up red to ignition and yellow to constant power?
check all the fuses car and back of head unit
if worse comes to it connect red and yellow to geather and send it straight to the positive on the battery with a fuse but u will have to turn the radio on and off by your self not the ignition
Jul 04, 2008 | Pioneer Car Audio & Video
Ok i am putting in a alpine head unit in a 99 neon i can get it to hold the memroy i have to put the red and yellow wire together and do the same on the wiring bracket and when i put all for together the...
The yellow wire must be connected to a constant voltage source. You have the red and yellow connected to a voltage source that only gets power when the car is turned on. The yellow wire is for the memory. Check the fuse box for a fuse that has voltage on it when the car is off and the key is not even in the ignition. That is the type of connection the yellow wire needs. The red wire can stay connected to the place it is at now.
Are you using a harness that is made for installing a radio into a 99 neon? They sell them at most all places that sell car stereos. Go in and ask for an installation harness for your car and then you connect it to the harness that comes with your radio by matching the colors of the wires and you have a nice and easy install. It plugs right into the factory harness with all the connections you need.
Jun 17, 2008 | Car Audio & Video
Help with install on clarion vrx935vd
The green would have to be connected to the handbrake indicator switch. Additionally, Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 13, 2008 | Clarion VRX935VD Car DVD Player
Installing Sony Explod CDX-GT210 CD deck
try connecting the red and yellow together, and to a 12 volt source. that should deffinately get power to the head unit.
check the fuse under the big connector on the back.
Sep 24, 2007 | Sony CDX-GT210 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
