Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Seagate freeagent go 250g 9za2a4-500 (no lights, no recognition, beeping sound maybe disk stuck or p.s problem?)
SOURCE: i knocked over seagate 500 freeagent and it beeped and groaned an
I'm not expert but try freeze therapy. I did it in on mine and it did not work but I hear it does rarely. Basically all you do is wrap the harddrive in a plastic bag tightly to prevent any form of moister entering, leave it in for about two days and plug it back it. It's said that sometimes if the lense is shaken out of place the cold would make the metal go back to original placing. This means you plug the harddrive in while still frozen, just something try before throwing it away or replacing it.
Posted on Jul 08, 2009
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
Posted on Jul 24, 2009
pcpal
SOURCE: Knocked over Seagate 500GB FA Pro Makes Beep Noise/Can't Connect
it sounds like the disc (inside the hard drive casing) has become jammed or what is known as "stickation". the best way to unstick the disc is usually another sharp blow. the best way to do this is to remove the drive from the external casing and, while holding it by one side, strike the other side downward onto a hard surface like a wood desk. do not strike it on metal or cement as you may cause more damage. make sure the surface is softer than the drive casing. it sounds extreme but it has worked for me on several occasions.
Posted on Jul 25, 2009
brukau747
  • 51 Answers
is damaged my friend. Hard drives are very, very delicate pieces of equipment. The disk is paper thin and any sudden jarring, especially dropping it creates a warp in the drive. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Posted on Sep 01, 2009
  • 34 Answers
SOURCE: How to format my new seagate freeagent 500 gb with macbook?
Here is a link to Seagate that describes how to fromat your drive fro a Mac. GOOD LUCK!
Posted on Oct 14, 2009
Freeagent 500gb not responsive. No lights; just a beeping noise.
ok here goes, my neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 hope this helps Ytee.
Good Luck
Aug 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do i fix an external hard drive (seagate freeagent) that makes a beeping sound and is not recognized by my system ?
Look inside your P.C. 1st to check SATA data connection type.
eSATA is a different connection from SATA so you might need an eSATA data lead if you follow the guide in the link, not sure if it just external connections only and plain SATA connection inside.
Google image 'eSATA' data lead/cable and you will see the difference between the eSATA and SATA connection if you don't already know.
My neighbour has the Seagate FreeAgent Desk 500GB (Externel HardDrive), and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t​=84 Thread can be found in 'Technical' under 'General Technical Issues' Dont worry if your a novice like me with computers, the guide is quite easy to follow...
Aug 08, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Cannot read
It sounds almost like 2 things are happening,
1. The drive itself it going out or the board inside that is connected to the drive is bad.
2. or the drive is not getting enough power through the USB ports (or too much maybe?)
I have only encountered the beeping issue on my free agent 160GB when it was not getting enough power to spin up the platters.
If you still have warranty on it. I would HIGHLY recommend you call western digital about it.
Mar 20, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I own a 320GB seagate freeagent hard disk and accidentally unplugged it from my laptop a few days back. It gives a beeping sound whenever I try plugging it into a laptop and I've tried 3 laptops, all gave...
Connect the 320GB HDD before switching ON the laptop and try to repair using scandisk option to repair the drive. Also use chkdsk /f option in command line mode.
Revert back for more assistance.
Jan 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Freeagent 1.5TB hard drive beeping
remove hard-drive and put it start in to your computer this sounds hard but isn`t. it sounds as the internal board has gone.
Dec 07, 2009 | Seagate Computers & Internet
Seagate 250G running out of space
creat incremental backup rather than complete fresh backup.
empty trash can.
either way, it's possible the backup drive uses up more than working drive especially adding/deleting files alot between backup's.
Dec 26, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent 500g usb 2.0 beeps sound
You still need assistance in cracking open the Seagate Freeagent Pro 500GB and trying data/file recovery? If yes, would appreciate a post back.
Good luck and kind regards.
Thank you for using FixYa.
Mar 17, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
334 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
