Grainy Picture Denon 1740 DVD and Samsung 1080P LA40M81BD
I just bought a denon 1740 dvd player. I have hooked it to my 40" Samsung 1080P and it appears grainier than my last cheap dvd player, i am wondering if I have some settings wrong. Even animated graphics seem to jump a bit. Is there a setting or anything else you thik I should try or is this just a result of something wrong with the hardware,
  • 476 Answers
Firstly, you should alter the picture settings on the TV. Most TVs have independant settings for tuner, scart and HDMI, so you may need to do this several times. Once for each.
Excessive contrast and/or sharpness on an LCD causes graininess, particularly around the edges of moving objects.
Check and adjust the following on the TV:
  • Contrast - about 65% max
  • Sharpness - 20%
These settings are a % of maximum, so you may need to work out a value if max is not 100.
Also turn off any contrast enhancements - (Contrast + / Digital
Contrast etc.) dependant on make.
I assume that you are using the upscaling facility of the Denon 1740 via an HDMI lead. If so, disconnect any other connections between the DVD and TV, particularly scart. If the scart is connected the TV will auto-switch to the scart input when you use the DVD, and you will not get the benefit of the high def connection.
This is probably obvious, but make sure the DVD is set to 1080p scaling, and you will need to manually select the HDMI input on the TV.
Posted on May 08, 2008
Stand by problem
Try going to Target or like store and buy a CD/DVD cleaner disk and running it to clean the heads of the machine.
Jun 13, 2015 | Denon DVD-1740 DVD Player
I have a Denon AVR 1707 reciever. I am trying to connect my dvd player through RGB cables. The sound works just fine when i turn the reciever to dvd but there is no video. I have the component 2 set to dvd...
The video cables--the green, blue, and red ones must be connected from the video OUT portion of the DVD player to the Component 2 video IN of the Denon. It could be the handshake between your Denon and your television. Do you have anything else to connect to the Denon to see if you get a picture? How are you connecting the Denon to the television? Make sure you have your television on the proper input and check the cables going between it and the Denon.
May 25, 2011 | Denon AVR-1707 Receiver
DVD player won't read disc anymore
i had the same problem.
is the player done? or is there a fix?
Mar 02, 2010 | Denon DVD-1740 DVD Player
Hello I need firmware for denon 1740 Dvd. Cant not faind self.Thx
Go to the Denon Global Website and select Europe, once on the Europe site go to downloads the 1740 will show up in the model drop down menu. You'll need the unit Serial Number, good luck on that, I couldn't find one anywhere on my unit.
Next step? Buy a Sony.
Jul 16, 2009 | Denon DVD-1740 DVD Player
I have a Denon AVR-3808CI A/V receiver, a Samsung HL67A750 DLP TV, a Samsung BD-P1600 Blu-ray player, and a Motorola HDPVR for the cable signal. I have connected the Blu-ray player and HDPVR to the Denon...
You will have to disable one or the other. Most likely the source because not all disk"s will be recorded the same. If a disk was transfered from film to digital poorly, this will show up as a grainy look on your tv, not much you can do about that. I would set your tv the best possible and go with that, also if your tv is capable of 24fps use that setting.tweaktv.com can help you with your tv setting. Use Progressive Mode on you blueray and your dvd also.
Apr 24, 2009 | Denon AVR 3808Ci Receiver
No picture
the reason you can't get a signal is the denon 1708 will not pass the 1080p, switch the DVD output res. to 1080i or 720p and it will work
dennis
Feb 02, 2009 | Denon AVR-1708 Receiver
Sound with HDMI but no video
the Denon does not pass 1080p change the output res from the DVD/PS3 or Xbox to 720p or 1080i will solve the problem
Nov 18, 2008 | Denon AVR-2807 Receiver
Denon DVD-1740 component video to RGB cable
YOU HAVE THE RIGHT CABLES FOR THIS INSTALL, GREEN, RED, BLUE FOR COMPENENT VIDEO AND RED AND WHITE FOR AUDIO UNLESS USING THE OPTIACL OR COAXIAL, FROM THE DVD PLAYER TO THE AMP OR TV.
ON THE FRONT OF THE DVD PLAYER IS A HDMI BUTTON PRESS THIS BUTTON UNTILL OFF IS DISPLAYED AND YOU SHOULD HAVE PICTURE
Jun 02, 2008 | Denon DVD-1740 DVD Player
Denon AVR1602
I know the avr 1602 well....What exactly do you mean "I have my TV cable service wired to the Denon".....Do you mean the actual co-ax cable ?....
The denon is only able to switch raw video and audio signals.
What do I mean by that ?....IF you are running your co-ax cable from your cable company directly into the back of the denon, it won't work. The Denon has an AM-FM tuner, but not a video tuner ( channels 1-121)....If this is what you are doing, then you want to run it to your samsung first ( as long as the samsung has a tuner so you can change channels ).
If the samsung operates like an old VCR, whereby you can plug the cable company co-ax cable into the back of it, and change channels with the samsung, then that is what you must do. You would then hook up the OUTPUTS of the samsing to the VCR or DVD inputs on the Denon receiver. ( use DVD inputs on the denon if the samsung has optical audio out, and use an optical cable as well for better sound ).
You would then use the Denon for the sound, and hook up your TV to the Monitor out jack on the back of the Denon.
The Denon is like a big switchbox. You plug your DVD, VCR, Satellite, video game, or what-have-you into the Denon. Then you use the denon to route the signal to your TV for the picture, and the denon takes care of the sound.
Hope this helps, and remember to always follow your owners manual.......Rob
Mar 13, 2008 | Denon AVR-1602 Receiver
Televison & Video Logo
255 people viewed this question
Top Televison & Video Experts
