Question about Olympus C-7000 Zoom Digital Camera
The lens cover does not open and close completely when you power the camera on/off - one of the cover leaves appears to be loose.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
Lens cover stuck
Get canned air and gently blow on diaphragm while opening and closing.
Jul 11, 2014 | Nikon Coolpix 4800 Digital Camera
Tz10 lens cover sticking
My TZ10 problem was the opposite, the cover wouldn't open. I just resorted to surgery with needle-nose pliers and a carefully wielded Stanley knife, and removed the cover completely without opening up the camera or the lens assembly. No big deal not having a lens cover, the thing lives in a leather case and it doesn't take a moment to wipe the lens with a tissue if it gets dusty. The camera is 4 years old anyway. Solved by 'amputation'.
Jul 29, 2012 | Panasonic Lumix Cameras
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
The cover over the lens is two pieces. The top one open and closes properly but the bottom one is stuck in the open position leaving the lens unprotected when the camera is off.
Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $86.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 14, 2009 | Olympus Stylus 740 Digital Camera
Lens cover does not operate correctly
I fixed this problem on my Fuji FinePix A303 (though it took some hard work).
The problem:
Camera Lens Cover stuck open or stuck closed.
Power on, and get !LENS COVER error.
Lens fails to extend.
The solution:
Short answer: The motor driving the lens cover is weak and eventually breaks down. I manually open the cover now. This took a manual modification to the camera (and some work).
1. Take the camera apart. See here for details, and be careful around the flash, as you'll get a nasty shock otherwise! http://www.mathematik.uni-marburg.de/~haim/focuserr.htm
2. Once you can see this, you're just about there:
3. Take off the battery cover (in the picture above).
4. Wrap a wire around the sliding pin for the lens cover, and drill 2 small holes through the black structure underneath the battery case, and then to the outside. The wire goes from the pin to the outside via the two holes. You should be able to manually open and close the camera cover COMPLETELY now with the wire.
5. Reassemble the camera (actually, you can test that it's working when it's all apart, if you're careful).
6. To operate the camera now, close the shutter first while off. Power on the camera, and very soon after open the shutter all the way by pulling on the wire (from step 4). This basically mimics the action of the little lens cover motor. If you timed it right (you have about a second margin), the lens should extend and everything functions perfectly.
It would have been nice to have been able to simply buy a new motor, but that would probably be a pain and cost some money.
Hope this helps!
Matt Van Dyken.
http://mattvd.googlepages.com
Aug 16, 2008 | Cameras
Cybershot camera lens cover closed
Follow the steps below to troubleshoot if the lens will not open, retract, or extend. WARNING: There is a risk of hardware damage. Do not attempt to manually force the lens in or out. Doing so may damage the camera. NOTE: Because each of these steps represents a possible solution to this issue, check the camera status after completing each step. Ensure the battery is adequately charged or connect the AC power adapter (if applicable). Perform a power reset. If the camera lens is still not operating correctly after completing the troubleshooting steps suggested, service will be required. Hope this helps
Aug 23, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
When powered up, "Remove lens cover, press button"
The symptom of "remove lens cover" always showing can be caused by two different things. If the lens assembly has become jammed and will not move when the camera tries to extend it - this can cause the message. On some cameras a stuck-closed shutter can cause this message as well. The symptom you describe of seeing two images prior to the failure is strange. I cannot make any kind of conclusion from that information without further elaboration. Does the lens extend when you turn the power on? If not the lens is jammed. Do you see nothing but black all the time on the screen and the captured photos? If so the shutter is stuck closed. Either of these problems will require complete disassembly and re-setting of the lens elements. Check with your manufacturer and see if they will fix it under warranty. If not, there are service providers available on the internet who can service your camera. David Millier Advance Camera Repair
Feb 27, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
No startup on lens cover opening
well the problem it´s on the switch that turns on the camera that is located under the lens cover.... this swith is glued to the front cover and lots of times gets unglued, u need to remove the lens cover by removing 2 screws on the bottom part of the lens cover, after that just pull the switch slowly and glue it. don´t use 3 seconds glue use a more viscose one. good luck
Feb 14, 2007 | Olympus Stylus 400 Digital Camera
My lens cover can't open and close completely.
Have you tried Canon customer support? If the camera is new[ish] you may get it fixed under warranty. A repair price will be high. You could just gently push it back. Or compose your picture to miss that side of the image
Jan 04, 2007 | Canon PowerShot A610 Digital Camera
Lens Cover Closed
the switch inside that activates the camera is probably loose, or worse, broken.
Sep 09, 2006 | Sony DSC-T7 Digital Camera
Olympus C-7000 Zoom Digital Camera Logo
64 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
