Question about Cell Phones
My nokia e71 won't turn it vibrates when i press the on key but the screen seems to be dead. Please help me.
  • Cell Phones Master
  • 17,130 Answers
Remove off the battery and the memory card from the phone. replace battery after about 10 minutes. Now check to on and reset the phone usingg settings- reset factory settings- 12345 to set your phone to normal state.
If the phone works then insert memory or else you must try to get the software installed .
Posted on Aug 30, 2010
Reboot nokia e71
Back up data first.
Turn phone is off.
Press the keys "3", "*" and the green/talk button simultaneously. This action forces a hardware reset and also reformats the device.
Without releasing the 3 keys mentioned above, press the "on" button.
When you feel the phone vibrate, release only the "on" button but not the keys in step 3.
When you see the Nokia boot up screen (handshake screen) then you can let go of all the keys.
Aug 24, 2012 | Nokia E71 Smartphone
How to format E72 that won't charge in either nokia charger nor USB cable. But once it open it only vibrate then NOKIA sign appears and yet it won't open. please HELP ! thank you !
For Hard Reset:
This also restore your Nokia when it frezzes at the nokia screen logo only and didn't go any further.
hard reset is an options but will result to loosing all settings, contacts, data etc...
Turn your phone off and simultaneously press these four buttons circled in red.
* * (asterisk key)
* 3 (numeric 3 key)
* CALL / GREEN key
* On button
This is another method below found out by trial and error when the * + 3 + Call didnt work.
Switch your phone off.
Then, lay it down on a flat surface
With 3 finger of one hand, keep pressed shift, space bar and back space all at the same time
With one finger of the other hand, press the power on button
Do not release neither the 3 keys nor the power key till you see the nokia shakehands animation.
Jun 23, 2012 | Nokia E72 Smartphone
Nokia E71 unlock key in the top left side isnt working
joistics left key and some more key is not work please help me
May 24, 2012 | Nokia E71 Smartphone
Hi there. If got a Nokia E71. Since yesterday my phone kept on saying that my internet connection is wrong and that I must change it. Where must I go to change it. And Who can I contact to find the Lock...
Hi, sorry about your phone. you don't need to hit the Phone against the wall.
Here are ways you can reset your phone:
Due to the amount of data it handles, a slow down in your phone may arise or a conflict in applications may occur, or worse, a total malfunction in your Nokia E71 may happen. A hard reset should be done only as a last resort as it will wipe out most data and new applications you have installed. Before heading out to your Nokia Care Center, try the following steps first, otherwise, it might be time for your cell phone to be handled by the technical experts at Nokia.
SOFT RESET:
Back up data from your phone and memory card before doing any kind of reset. To perform this please refer to resources below.
Switch on the phone.
When it goes on standby mode, press "*#7870#". Make sure you press the "*" key - some people forget this. This triggers a software reset and restores the default factory settings without losing your data. Although this action doesn't remove your personal data it still is a good idea to do back up when performing any kind of reset.
Enter the default code "12345" when requested.
HARD RESET NO. 1 - Do this if soft reset procedure above doesn't work.
Back up data.
Press "*#7370#". Again, make sure the "*" is pressed before the "#" key. This also triggers a software reset that involves reformatting the phone. When Nokia E71 is reformatted not all data are lost due to a new feature called UDP - User Data Preservation. You won't know though what will be retained and what will be removed so perform a back up no matter what.
HARD RESET NO. 2 - If hard reset no. 1 doesn't work then do these steps.
Back up data if you still can.
Make sure your phone is switched off.
Press the keys "3", "*" and the green/talk button simultaneously. This action forces a hardware reset and also re formats the device.
Consigning your internet problem, acquiring your setting for your internet,
you will need to contact your service provider for help...They will help you out with that..
Take care...
May 25, 2011 | Nokia E71 Smartphone
Nokia E71 software updated through Nokia PC Suite But My bad luck I forget the data backup & I lost important contacts . So please help me how recovery the contacts
Fr restore the data of mobile , just turn off ur mobile than start and immigatlly press ok key+star key +3 together till ur mobile on than you will see your mobile is come genuin data
Apr 29, 2011 | Nokia E71 Smartphone
When i start my nokia e71 mobile's camera its says general fetures are not supported. please tell me what am i do for it.
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Jan 04, 2011 | Nokia E71 Smartphone
How do i format my nokia e71
Hi
Apologies but this is a cross-post from the Expansys USA forums. I've bought my E71 in the US, and the US forums are a bit quieter than the UK ones.
I've tried to follow the directions at http://my-symbian.com/s60v3/faq/showquestion.php?faq=1&fldAuto=6 and http://my-symbian.com/s60v3/faq/showquestion.php?faq=1&fldAuto=7. Neither of these seem to work. Any ideas?
If I key in *#7370# it will offer to send service command, but comes back with Request Not Completed. Holding the green key with 3 and * whilst powering on doesn't seem to start a format. Should something appear on the screen.
OR:
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Format it
Thanks,
Sep 03, 2010 | Nokia E71 Smartphone
Unlock code for my Nokia E71
Switch on the phone
Press *#7370#
OR
Without releasing the 3 keys mentioned above, press the "on" button.When you feel the phone vibrate, release only the "on" button but not the keys in step 3.When you see the Nokia boot up screen (handshake screen) then you can let go of all the keys.
www.usedcellphoneshop.com
Jun 02, 2010 | Nokia E71 Smartphone
I have problem wiht e71
try to format your phone with Pressing CALL KEY 1 * 3 and Power at the same time (turn it off first) and hold for a few Second until text "FORMATED" at the Screen.
but if stiil doesn't work,bring your phone to nokia service center in your town.
Sep 29, 2009 | Nokia E71 Smartphone
My Nokia 5800 will not turn on. It only vibrates.
  1. With your 5800 turned off,
  2. Press and hold [Green] + [Red] + [Camera] Keys
  3. Turn phone ON, and keep pressing it until you see the Nokia Shaking Hands Logo.
The phone will be factory reset. If asked, default code is 12345. My phone did not ask- only the normal SIM PIN.
Jun 10, 2009 | Nokia 5800 XpressMusic Smartphone
Cell Phones Logo
212 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
