Our Konica #2125 is displaying a F34 error code. what can we do to fix this?
  • 40 Answers
This code for fuser unit but make sure about this code is that's f34-1 or f34-2
anyhow you need to rest this code
Posted on Sep 01, 2010
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
How do I fix a F-28 error code on a Konica 2125 Copier?
this code means the transfer separation corona is arcing and the wires and blocks will have to be replaced sometimes you can get by with cleaning them but usually they need to be replaced
Oct 28, 2009 | Konica Minolta Office Equipment & Supplies
Error code F34 on Konica 1015 copier is there any way to fix without service call?
No...it's a fuser error (low warm up temperature)...It's a blown fuse, or lamp, and the code can only be reset in 'service mode'after fixing the fault
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Nov 29, 2008 | Office Equipment & Supplies
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
good luck
Nov 24, 2008 | Office Equipment & Supplies
Konica 7145 Fuser Error F34-2
You could go into service mode and reset error count normally to get into the service mode is the following depending on age of machine.
Thanks Jason
A. Procedure
1. Press the Utility/Counter key.
2. Touch [Details] on Meter Count display.
3. Press the following keys in this order.
Stop → 0 → 0 → Stop → 0 → 1
Aug 16, 2008 | Office Equipment & Supplies
137 people viewed this question
k24674
jasbo
jasbo
