Question about Powermatic 1352001 3520B 20x35" Wood Turning Lathe
Do you have any assembly and maintenance manuals for the Hafco WL18 woodturning lathe?
I have a Jet JWL-1442 woodturning lathe. The on/off switch has given up the ghost. My question is how do I fit a new one.
Dear David,
I wish I were there to help. However...
If you never get it out, a last resort might be ( what I have done in the past) to take a tiny tester (that you touch on a piece of wire that will tell you if it is "hot" or not.) and find the hot wire going to the switch. Turn off the power and cut that wire close to the switch.
Mount a separate electrical box on your lathe with an on /off switch and use that one to power you machine on and off.
God bless your efforts.
Nov 04, 2016 | Cars & Trucks
Coronet major lathes
That site no longer seems to offer the manual... and I think I'd be hesitant about giving them a credit card number...
Aug 01, 2013 | Tools & Hardware - Others
How to modify clarke cwl6b to accept MT1 accessories
It can be done. Pop out your existing dead center and check- it may already have a Morse Taper on it. There are smaller Morse tapers in "0" and "00" and there are of course adapters too.
You might try sine if the US vendors, I am not sure which ones ship over seas, but Packard Woodworking has probably the most Lathe tooling and parts. There is Woodcraft and Rockler as well. There are some import catalogs that a local tool shop might have they can order from as well.
Sep 20, 2012 | Welding Tools
Brake lathe chattering bad
There's a lot of reasons why a brake lathe chatters during a cutting operation. They range from lack of maintenance, adjustments, cutting speeds, wrong cutting tools and so on and so forth.
Be a little more specific.
What kind of machine are you using?
What are you cutting? (rotors? drums?)
Are you using the proper silencers?
Come back with some answers please.
Buy Sell Used Brake Lathes Brake Lathe Parts
Dec 16, 2010 | Ammco Combination Disc/Drum Brake Lathe
Initial setup and operation of hafco al 336 lathe
DRINK MORE ALCOHOL TO IMPROVE YOUR LIFESTYLE
Nov 22, 2010 | Garden
How do I change the belt on my ammco 4000 lathe?
I am a brake lathe technician.
To change the drive belt on an Ammco 4000, you must first remove the 90 degree angle PTO (power take off) gear assembly which is driven off the back of the big pulley. Two small allen head screws hold it tight.
Pull the PTO gear assembly out of the disc-feed gearbox. If there are colored shims between the gearbox and the PTO assembly, you must make sure not to loose. If they drop off, be sure to replace them with a dab of grease.
Rotate the red knob at the back of the machine and the motor assembly will unlock and rotate upwards. Replace the drive belt.
To adjust the drive belt tension properly--loosen the 3/4 inch nut on the back of the machine, and the motor will drop down. Tighten the 3/4 inch nut and then rotate the red knob back until the belt is taught.
Replace the PTO gear assembly--making the rotating part with the protruding pin is centered on the big pulley. Tighten the allen head cap screws.
Turn on the machine. If the PTO is making noise--you have not correctly is correctly. Repeat the centering process until the machine runs without rattling or vibration.
Sep 28, 2010 | Ammco Combination Disc/Drum Brake Lathe
I need a manual to repair my tos trencin lathe sn-40a
I am looking for a tos trencin taper attachment for a 20" lathe. Got any ideas?
Apr 15, 2010 | Ammco Combination Disc/Drum Brake Lathe
Powermatic 1352001 3520B 20x35" Wood Turning Lathe Logo
49 people viewed this question
Top Powermatic Tools & Hardware - Others Experts
Bill Boyd
Tom Chichester
Are you a Powermatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
