Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
Pilot light goes out randomly on 6 year old Bosch Aquastar tankless water heater. When I restart it it may work for a day then goes out again.
  • 395 Answers
The pilot light can be blown out just by the main gas being ignited especially if the pilot flame is a little weak. Some times a bit of grit gets into the pilot nozzle reducing the flow and hence a weak flame. Try cleaning the piolt jet nozzle with a fine piece of wire. You may have to dismantle the jet nozzle to clean it properly.
Posted on Aug 31, 2010
Bosch 1600 h not lighting pilot light
If your getting a spark the generator should be ok I would clean the pilot injector and re try
Nov 16, 2014 | Bosch 1600H-LP Liquid Propane AquaStar...
Failing ignition on Bosch Aquastar AQ125-HX tankless on demand water heater. Carefully followed all directions on device to best of ability. Gas supply is full and on. Water pressure should be...
Before calling service technician, open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Resources at Bosch
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/tabid/370/Default.aspx
Typical Bosch Aquastar manual:
http://waterheatertimer.org/pdf/Bosch-aquastar-170vp-manual.pdf
All tankless and tank-type gas water heaters require regular cleaning and maintenance.
It is unknown if your unit needs maintenance or repair parts, but catching up on maintenance using information from manual is good place to start.
Gas appliances are increasingly complicated and experienced technician is good resource to have in local area before installing tankless.
Apr 16, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light works but no flame. Somehow, think it overheated due to stoppage of water flow at sink.
Resources at Bosch
Apr 16, 2011 | Bosch AQ125BO LP AquaStar 4.3 GPM Outdoor...
Bosch AquaStar tankless natural gas water heater pilot goes out periodically--after a few hours or a few days, whether weather hot or cold, whether windy or not. This condition has been the same from day...
I had a similar problem with mine and it turned out to be a plugged air vent sceen. This is the small dome like sceen on the gas valve. I vaccumed out the unit and have not had the pilot go out in over a year.
Nov 27, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Pilot light was out after a fierce thunderstorm. relit pilot light and unit is operational at this time. heat exchanger was descaled a year ago. unit is 6 years old. what should i be looking for as far as...
Probably excessive winds caused a draft to enter your boiler via the flue and blew your pilot out - not unknown - if the unit is now working okay - don't worry. As you seem to be servicing the unit you will probably get a good many years out of it yet.
Jul 18, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
May 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Bosch tankless hot water heater 1600H
it sounds more like the ignitor thats messing up, if you are able to remove it and get a new one that would probobly do it for you
Nov 07, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
615 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
john h
Paul Nielson
Paul Nielson
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
