Question about True TD-65-24 Commercial Refrigerator
I need a thermostat for a true td-65-24 cooler? Do any of you guys have a part number and suggested discount place to purchase from? I'ts at least 6 yrs old
5 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: Problem with a True TD-50-18
That is the drain which may be clogged. Look for hose in pan by compressor and use one of those cans of air to blow out computer keyboards.
Posted on Apr 26, 2009
rockitman187
  • 2559 Answers
SOURCE: TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MIN.
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
Posted on May 03, 2009
401Cay
  • 4 Answers
SOURCE: true cooler td 65 24.
All commercial beverage boxes will have shipping retainer screws holding the compressor tray in place, usually 1 or 2 on the lower cabinet outside tray base. (although, a few years of drain waste into tray may glue tray in as well.. lol).
Posted on Jul 11, 2010
  • 10 Answers
SOURCE: the GDM-41 true cooler is freezing my food what do you guys think I am thinking of replacing the thermostat
Simply turn the temperatue up a couple of points..If it is freezing stuff it is set too cold !
Posted on Dec 04, 2013
True TD-95-38-LT Beverage Cooler wont drain , cannot locate drain plug
Usually inside the compressor compartment, below that is the collection pan, blow it out with compressed air
Feb 01, 2013 | True TD-95-38-LT Beverage Cooler
We have a true upright, glass front beer cooler. TBB-4-G refrigerated back bar. The bottles and cans right in the middle are icing up and forming huge blocks of ice. we have turned up the thermostat,...
Check your evaporator drain pan and the outlet for the condensate water, and make sure the drain tubing is clear. That water is supposed to drain outside the box.
Aug 30, 2011 | True TD-95-38-LT Beverage Cooler
Coils keep freezing up, and temperature in cooler won't go lower than 44 degrees. just installed new thermostat.
The refrigerant system is low on charge....you will need to have the leak fixed and the system recharged.
heatman101
Jun 12, 2011 | True TD-65-24 Commercial Refrigerator
I own a true 2 keg beer cooler and it has recenty been not able to turn off the cooler and freezes the beer. is this a problem with the thermostat or something else?
This is probably the thermostat stuck closed and bad. Turn the tstat all the way to left or counter clock wise. The compressor should turn off.If the compressor continues to run the tstat is stuck and bad. A good replacement tstat would be Ranco # A12-1560.
Nov 08, 2009 | True TD-50-18 Beverage Cooler
TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MINUTES.SEEMS TO COOL FINE MAINTAINS 38 DEGREES, OTHER TRUE COOLER WE HAVE DOES NOT DO THIS...ANY SUGGESTIONS?
May 03, 2009 | True Refrigerators
True cooler td 65 24. what is holding the sled in place
I think you are referring to the condensing unit that the compressor sits on. Look on the rite side of the unit near the bottom. There you should find 1 3/8" screw that runs through the side of the unit into the "sled" thus holding it in place.
May 03, 2009 | True TD-65-24 Commercial Refrigerator
Freezing up TD-64-24 beverage cooler
Some of this TRUE don't have service valves, but you can put a tapping valve (A1) in the appendix (small piece of pipe comming out of the compresor and seal on the other end).To check the pressure you need to know what type of refrigerant is in the system .If is 134a the low side should be about 24psi and the high around 160 it could vary depends how hot is inside the place and the fridge but not much more than 200.If you working with R22 pressures be around 60 low and 250 high side.
May 01, 2009 | True TD-65-24 Commercial Refrigerator
Apr 26, 2009 | True TD-50-18 Beverage Cooler
True TD-36-12-S Bottle Cooler
1st check the outter coil and make sure you can shine a flash light through the coil. If not blow out with compressed air and look again. A dirty coil may be your problem.
2nd check the inside coil it may be blocked with frost - ice
3rd the fan both in and out have to be running.
4th check the door seals
you could be low on refrigerant or have a bad thermostat but eliminate all else before going to these 2 problems.
Sep 16, 2008 | True TD-50-18 Beverage Cooler
Help?
turn thermostat all the way to the left to turn it off. restore power and see if it stays on and inside fan is running. Then turn thermostat to rite to turn on compressor. If the power trips when turning thermostat back on, the compressor may be bad. :(
Dec 27, 2007 | True GDM-41 Refrigerator
True TD-65-24 Commercial Refrigerator Logo
37 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
