Question about HP Officejet 9110 All-In-One InkJet Printer
HP 9110 all in one's scanner will not work
We are able to print to it howevr we can not scan from it to our p.c
The HP director would not open either, i have tried advice from this site and managed to get that open, but there are only two buttons in it. the software update button will not work and the websitesdriver update has no effect.
  • 1 more comment
  • matvering May 28, 2008
    I can print, but the scanner does not work.
  • mando5231 May 30, 2008
    officejet all-in-ine 9110
  • jmoye Aug 07, 2008
    Printer will print and make copies but will not scan. Can't open HP director either. This all started after up grade to IE 7. I don't know if there's a connection or not.
I have a 9110 and a laptop running Windows XP and Internet Explorer 7. Prior to upgrading the IE from 6 to 7, I was able to run the HP Director and fax, scan, whatever from the laptop. After upgrading to IE 7, HP Director quit working. I contacted both Microsoft and HP and they pointed fingers at each other and said yes, upgrading to IE 7 broke the HP Director. Both said fixes were being developed, but that was months ago and I have not heard of any fixes.
I did find a workaround that allowed me to scan documents to the PC (faxing worked fine manually). Assuming the 9110 all-on-one’s drivers are still on the PC, and that the PC is connected to the 9110, go to “start, settings, control panel” and once in control panel, select “scanners and cameras”. If the drivers are still there, you should see the HP 9110 under “device”. Highlight the HP 9110 and double click. A wizard should start and it will guide you through the scanning process. If the 9110 does not appear in the “scanners and camera” box, you will need your 9110 CD and click on “add an imaging device”, which will start another wizard. It’s not as easy as using HP Director, but at least I can use the scanner. Hope this works for you.
Posted on Oct 10, 2008
I actually signed up to "find" a solution to this problem....not solve it. Have been trying to solve it for hours.
D
Posted on Oct 09, 2008
HP Officejet 9110 scan function drivers required
Below is the link where you can go and download the drivers and firmware for the HP Scanjet 2200C Flatbed scanner.
Click Here to download
Please let me know if you have any further questions or concerns.
Thanks.
Feb 23, 2010 | HP Officejet 9110 All-In-One InkJet...
HP director will not open
try this...
click start
right click my computer
properties
hardware
device manager
?ports
scan for hardware changes
Jan 06, 2009 | HP ScanJet 3500C Flatbed Scanner
Scan to computer
Several ways to control your scanner:
From this HP link
Changing scan settings in HP Director
Scan settings include resolution, output type, and file type. These settings can be changed using HP Director.
  1. Open HP Director, if it is not already open:
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Director .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Director .
  2. In the Select Device list, select your product, if it is not already selected.
  3. Click Settings , and then point to Scan Settings & Preferences .
  4. Click the scan setting menu that corresponds to the type of file you are scanning.
    • Scan picture settings : Designed for scanning pictures, including any type of non-text image, such as a drawing, logo, or photograph
    • Scan document settings : Designed for scanning documents
    • Scan preferences : Control scanning preferences, such as automatically straightening crooked images
    • Button settings and Scan to... setup : Control the defaults for the scanner buttons on the control panel of the product
    After selecting the appropriate menu, the corresponding window opens.
  5. Change settings as appropriate, and then click OK . The scan setting window closes.
  6. Click Scan Picture or Scan Document HP Director to scan with the changed settings.
From this HP link
Using the Advanced Scanning Features of the HP Solution Center Softwaretoo large to paste - just follow the link above :)
Here the main site for the scanner - click here
Nov 18, 2008 | HP Office Equipment & Supplies
HP PSC 1210 all-in-one Director does not work with VISTA
I've been fighting the same. Did some hunting on the HP and MS web sites. Found a "work around". Not what I wanted but at least I can scan. I think HP Director is gone for Vista users. :(
Scanning with Windows Photo Gallery
1. Click the Start ( ) icon.
2. Click All Programs .
3. Click Windows Photo Gallery .
4. Click File and then click Import From Scanner or Camera .
5. Click Import .
6. Click Scan .
Jan 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Scanner/Director problems since installing new ink cartridge
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=45391&lc=en&cc=us&dlc=&product=90764
Dec 28, 2007 | HP PSC 1210 All-In-One InkJet Printer
The printer will not scann to the computer
Are you able to print? I suspect so. If not your probably looking at a bad cable or corrupt windows drivers.
The director software uses it's own system to talk to the printer via scan / fax though printing is controlled by windows itself. Since scan and fax are the same function to the printer, essentially i would start by re-installing the director software.
1. Remove it via add/remove programs, don't reinstall over. It may work but you'll likely just waste time, you want all it's files gone and replaced with new ones.
2. If that has no effect remove the printer from Control Panel > Printers. Also remove the scanner device from Control Panel > System > Hardware > Device Manager >
3. Reboot, windows doesn't really remove things till you shut it off.
4. Install the director software again, hook up the printer when asked.
Again:
If you can print at all communciation with the device is perfectly fine from a hardware perspective.
If you can fax without the computer then your scanner and such is fine from a hardwware perspective.
So your problem is simple software, either windows devices install or hp director. Both simple to remove and re-input.
It's very
Nov 09, 2007 | HP Photosmart 2710 All-In-One InkJet...
HP Officejet 9110 All-In-One InkJet Printer Logo
710 people viewed this question
Ben Johnson
