Question about Vacuums
How to assemble kirby legend II shampooer - Vacuums
SOURCE: Kirby Ultimate G Series
Ok, I will try to explain this as well as I can. Please bear with me. Remove the dust bag, cover and all, from the machine. Attatch the shampoo tank to the part where the dust bag attatched on the machine (not on the handle). Remove all attatchments from the front of the machine, and attatch the shampoo foam "collector", ensuring that the belt is over the drive. Connect the small hose between the tank and the foam collector. Mix the water and shampoo as directed on the bottle, in the tank. Turn the knob on the top of the tank to on, then start the machine. I run the foam over about three sections, and then turn the knob back to off, lower the collector, and run back over it to pick up all the foam and dirt. I hope some of that makes sense.
Posted on Apr 20, 2007
SOURCE: kirby diamond edition - shampooer
1. Raise the vacuum head all of the way up. 2. Remove the vacuum head by removing the belt and releasing it. 3. Place the shampooer head on the vacuum by securing the clamp and them put the belt on 4. Take the bag off of the vacuum by twisting at the base just slightly outward and lifting upwards and unclamp it from the handle 5. Put water and cleaner into the water resevoir. 6. Put the reservoir on to the kirby where the bag was by holding it parallel to the vacuum then using both hands, twist it outward slowly until it goes down onto the unit then twist back to parallel position. 7. Put the coil looking piece on the shampooer head on top where the hole is...it will only fit one way successfully. 8. Put the other end on the under side of the water reservoir. 9. Lower the shampooer head all of the way down on the carpet just like you would the vacuum head 10. Turn on the vacuum and reach down and turn the knob at the top of the reservoir, this will begin putting cleaner (tons of foam) onto the carpet. Just work in 3' x 3' sections, turning off the foam intermitently until you are finished. I hope this helps.
Posted on Sep 03, 2007
b0sslady2001
  • 357 Answers
SOURCE: shampooer instructions
Here's my online guide for using the Kirby shampooer....
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
HOPE IT HELPS!!
Marci
Posted on Oct 23, 2007
crownline248
  • 19 Answers
SOURCE: replace fan impeller on Kirby Legend II
take to repair shop u have have the tools needed to replace
Posted on Jul 19, 2009
  • 430 Answers
SOURCE: replace Kirby legend II fan
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Posted on Oct 08, 2009
I can't get the screws out to replace the belt on my carpt shampooer...
No screws need to be taken out on a Kirby for a belt change. Take the nozzle off, remove the base plate with the 2 twist locks, pull the brushroll out. Puton the new belt, and re-assemble. Twist the belt lifter around the belt, replace the nozzle, spin the belt lifter back, and go vacuum
Oct 11, 2013 | Kirby Heritage II Vacuum
How to put bag assembly on kirby g4 shampooer
You have to disassemble shampooer before putting vacuum back together, once you do that then look at this video on our site:
http://www.goodvac.com/
Good luck,
Rocky
Dec 18, 2009 | Kirby G4 Bagged Upright Vacuum
Need instructions attaching shampooer
First you must remove the power head from the front of the Kirby.
Insttuctions for this are found here...
http://www.greatvacs.com/head%20removal.shtml
Once the power head is off of the Kirby you can connect the shampooer and its tank...Instructions for the Shampooer can be found here
http://www.greatvacs.com/shampoo.shtml
Hope this is helpful =)
Thank you for using Fixya!!!
Apr 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Belt broke on shampooer
there are screws on the ends. I got it fixed.
Apr 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Legend II shampooer
make sure you have the exact soap added, tank filter cleaned after each tank fill up, turn tank knob all the way open, pull back slowly. try those...one or all has to fix it.
Jan 31, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Shampooer
this site has instructions with pictures
Hope this helps!!
Mar 25, 2008 | Kirby Heritage II Vacuum
Vacuums Logo
60 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
