Question about Samsung SyncMaster 2233BW 22" LCD Monitor
I recently bought the samsung 2232bw but after a while my screen wont display after i turn it off for like say overnight,it stays black with the power blinking for a long time.i usually press the buttons repeatedly and wait for like 45-1 hour time to display.when its starts to display it's flickers for a while b4 it becomes stable.Does anybody have a solution to my problem.Pls help me out cos its really disturbing. Thanks.
Fix-4U
  • 293 Answers
SOURCE: Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Posted on Oct 11, 2008
SOURCE: Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Posted on Jun 09, 2009
  • 1684 Answers
SOURCE: Samsung 226BW 22" LCD wont turn on and flickers a blue light
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
Posted on Jun 17, 2009
  • 7 Answers
SOURCE: flicker then display goes black
My samsung syncmaster 225bw when turned on would have the back light stay on for about one second, then go black, with or without the signal cable attached to the computer. After your screen goes black, shine a flash light on the screen to see if you can see any images
I repaired my monitor by replacing several bad electrolitic capacitors on the inverter board. These capacitors had broken bulging leaking vents on ther tops. There were two 820uf 25v and one 330uf 25v electrolitic capacitors that had failed. I ordered from www.digikey.com Panasonic FC series low impedance electrolitic capacitors, However, the 820uf was not curently stocked and had to be backordered, so I got one 1000uf and one 680uf to replace the two 820uf which were in parallel on the board. There were two 680uf 25v on my board which had not yet failed, so I also replaced them. On my monitor, the capacitors can not be longer than 20mm, due to space limitations. These electrolitic capacitors have a life time between 1000 to 5000 hours, so when you order get a few extra of the ones that went bad.
Posted on Jun 23, 2009
  • 29 Answers
SOURCE: my samsung syncmaster 2232bw wont turn on at all,
Solution for Samsung SyncMaster 2232BWplus:
The problem is bad capacitors: 5 pcs. 820microFarad – 25v and 1 pc. 330microFarad -25v. Replace these capacitors. Then re-solder the two transformers of inverter side. Also re-solder the power transformer and the inductor coil.
To open the casing:
At the bottom of the stand just twist the knob to unlock. Then, use a small flat screw driver beginning from the bottom (left or right) then using a hard credit card (or alike) then slide/glide it in between the cover plastics.
Roan
Triangle Tech Whiz
Posted on Jan 07, 2010
Half screen normal , other half blackened for 20-30 minutes, before turns normal. Recently getting longer to get normal screen and left side stays black(about 2" wide)
sounds like a bad smps or bad display. I would try the smps, but if that doesn't do it the display costs as much as the tv most likely.
Sep 07, 2013 | Samsung LN46A530 46 in. LCD HDTV
Screen freezes and wont come back
Also damaged capacitors can cause a slow dieing effect to the display, from what I have seen during my research efforts to find solution for repairs to computers people have bought to me. I have only seen "dead" display lcd monitors that have repaired ok by replacing the $1 capacitors.
Jan 16, 2013 | Westinghouse SK-26H240S Television
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Flashing screen when i first turn on my SamsungSyncMaster 2232 bw
I had a similar problem with my LCD computer screen. I took it apart and noticed a capacitor that was raised up on the flat end and appeared to be leaking a substance. Replaced it with a similar capacitor and works fine, for three years now.
Jul 05, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung laptop black screen
Sounds like a loose connection between your mainboard, inverter or LCD. Try to connect an external monitor and see if the display appears to the external monitor. If a display appears on the external monitor, you need a qualified technician to check your laptop. I fixed 3 laptops with that same symptoms, 1 has loose connector, 1 has ground problem and the other is an inverter.
Apr 09, 2009 | Intel Motherboard
Any suggestions ?
hello,
firstly you check this monitor to another pc. it the same problem accure then
i thinks this problem due to falure of power supply or dead of flurocent tube. or any the vga cable is faulty.
ok
bye
Oct 29, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
5570z and 2232bw
first, I would check screen cable. try replacing it with a new one, you will be surprised to know how many display problems are are caused by a defected screen cable.
in case this is not the problem, it can get more complicated, but first, just in case, reinstall drivers. its a long shot, but if you get lucky it will save you alot of pain. in case it didn't help, It's probably a bad vertical output chip. if you have some familiarity with monitors and decent soldering skills you could probably fix it yourself, but I would advise looking into taking it to a shop, or at least find an experienced hobbiest if you're not yourself. It's a pretty straightforward fix for someone who knows what they're doing.
Good Luck/Please dont for get to Vote.
Dec 12, 2007 | Acer Aspire 5500 5570-2609 Laptop
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
158 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
