Question about Gateway FPD2275W LCD Monitor
Caravan extractor fan
I am trying to find a replacement fan for an extractor on a Spectrum 418 1996 model.
Can you help me please.
J. Hill
    Guru:
  • 859 Answers
Replacement fans are based on size measured by distance between mount holes horizontally in millimeters and amperage. Connectors are another issue in your case. You may have to splice and insulate that splice properly to connect a replacement fan with your old connector. And Amperage rating is not too much of an issue so long as that replacement fan is rated equal or higher than the original. Fans can be found through NewEgg or CyberGuys on the Web.
Posted on May 10, 2008
I need to remove a broken bolt from a hatch support so a new one can be installed
The way I've always removed a broken off bolt is with an "EZ-Out" broken screw/bolt extractor:
http://www.houserepairtalk.com/attachments/f33/2979d1313072552-need-extractor-tool-help-ez-out.jpg
You drill a hole a little way into the center of the broken off bolt stub (drill size to use is etched on extractor), screw in extractor so it gets a "bite", then wrench out the bolt stub.
Mar 10, 2014 | 1997 Dodge Caravan
Atlantic azurea 100T - extractor fan - how do I adjust how long it stays on, I have one that the previous owners of my home put in and it stays on all the time. Please let me know! Thanks, Laura
Hi Laura,
There are many auto timer enabled extractor fan's available in the market but it could cost you more, therefore I would recommend an alternate solution for you.
All you need to do is replace your fan's switch with an auto timer.
For e.g. An auto timer which will switch off your fan after the desired time automatically.
Examples of an auto timers can be found on these links :- http://bit.ly/kUNC4x
http://bit.ly/kJPprC
So when the timer goes off , the fan stops by itself , and you don't have to worry about it any more.
Or you can get a new extractor fan with timer as well , check out an example in this link :- http://amzn.to/jybLfl
If you want to know how to install a bathroom timer switch , please follow this link :- http://bit.ly/lN7p67
Hope this helps ..:) Your feed back would be appreciated , let me know in case you have any queries.
Jun 02, 2011 | Vacuums
Replacement line for grass trimmer
Where do I find line for my cordless lawn trimmer spectrum 60-2270-0 12 v
Jul 28, 2010 | Garden
Looking for part number 831238 1/6hp brush motor
Try these people:
http://www.michco.com/p-102421-minuteman-ambassador.aspx
1- 800-331-3339
CustServe@Michco.com
831238-2
Item On Page-7-8 Ref# 128
Qty Required-1
This item replaces part#(s): 831238
Apr 16, 2010 | Minuteman C46000-00 Self Contained Carpet...
I hv a bathroom light incorporated in with the ceiling extractor
I would like to help you with this, But with out looking at the light/fan I can't. So what you can do is find the make and model of the Light/ Fan go to there website and email there tech support. # 2 go to Home Depot and ask someone that works in the fan area to help you out.# 3 If you like email me a picture of the fan/ light in four different places, and I'll be able to help you out. j-zubiate@hotmail.com. My name is Jason
Nov 04, 2009 | Dryers
Neff extractor fan not working
Hi rags116,
I'm Harvey the Master Plumber.
Your problem is: You have a neff extractor fan which hasstopped working. The light and fan have both stopped working. Do I know where you can find the fuse as you suspect that this may be the problem. If I don't think it is the fuse would I be able to suggest anything else.
The type is D-AY25-8 If there is another number that is more helpful please let you know. thanks Again your Neff Series 2 extractor has stopped working and you want to save yourself buying a new one!! Any suggestions greatly appreciated!
Since both light and fan require low voltage it sounds like a bad transformer. It will be mounted next to the motor. Make sure you turn off the power first.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Kitchen Ranges
Rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
Jul 15, 2008 | Juicers
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Mar 20, 2008 | Whirlpool GZ7730XGS Stainless Steel...
Bosch Extractor Fan model DKE945DGB
One way to check is to track down a schematic of the parts. That will often give you a good idea of there the part attaches and how.
Feb 01, 2008 | Kitchen Ranges
Gateway FPD2275W LCD Monitor Logo
74 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
