Question about Honeywell Programmable Thermostat Heater
My honeywell programmable thermostat chronotherm IV plus (ac cycle)shuts down after 25-30 sec and displays a flashing wait. It turns back up again in few min only to shut off in few seconds. I have turned the system off to reset it, but no luck.
    President:
  • 1,515 Answers
Hi, if this thermostat has batteries, try and replacing them. It sounds to me as though the circuitry in the sub-base has a problem keeping the stat programmed. Shutting down with in 30 seconds and back on only to shut off again tells me that the sensor that is a part of the circuitry on the sub-base that senses the rooms temperature, has failed and it cycles on and off. If it does have batteries, change them to see if this solves this problem. If no batteries, shut the power off to the a/c and remove the cover to the stat. If this does not expose the control wires, you will have the stat sub-base to remove. It will have several small screws that will need to be loosened to get to wiring. If your system has a gas furnace or electric heat and not a heat-pump, you will have terminals marked like this. RH, RC, with a jumper wire connecting the 2, W white for heat control, G, green for fan control, and Y, yellow or they may have used blue for cooling control. You can pick up a new programmable thermostat at Home Depot, Lowe's hardware for this for around $30. It will come with the Red jumper already wired in and this is where you connect your existing red to either one, but leave this jumper on. This will solve your problem. If you have no gas furnace and it is a heat-pump, it will have many more wires and terminals such as this, R, W-1, W, E, O, B, Y, C. Draw your self a diagram on the wire terminals and colors of all wires and what terminals they are connected to so you get it right and take this along to match it with the correct heat-pump thermostat. Honeywell has good dependable stats, so try and stay with them. If the price for one is off the wall, go with a White Rodgers, Hunter, Carrier, and just look them over good. Read to see if they have batteries for the display and if they are included with the stat. This will solve this problem. Please don't forget to rate me on this as I know you will be kind. I will be checking in to see how you are coming along and if you need more help as I will be here.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Posted on Aug 30, 2010
  • 455 Answers
Hello A flashing WAIT in A/C mode is the built in anti-short cycle timer.If you switch from heat to cool or adjust the thermostat on/off or raise/ lower temp within a 5 min.peroid it will not allow the unit to run untill time is up.
Honeywell Chronotherm iv Plus power cuts on and off
There's a trouble shooting guide here, you need to check for the presence of 24V when it goes blank, and trace back to where it's disappearing (I assume it is losing the 24v, if not you'll need to go through the installer setup or read on...
My first thought would be to check the wiring which has been touched last if it started doing that after you had coil replaced.
As an aside I'm not sure which model you have but if it has batteries you should replace them (I don't think it does have batteries but not seen a model iv so I'm unsure)
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1410.pdf
May 12, 2014 | Honeywell Programmable Thermostat Heater
Chronotherm 4 plus
change the batteries in the thermostat
Mar 21, 2014 | Honeywell Heating & Cooling
I can't turn my Chronotherm IV plus off! Can anyone help me. It is going to cost a fortune
Depends what model number you have. The older models had problems. So Honeywell upgraded the model several times. When you say, cant turn it off. If that means the heat will not shut off then you have no choice to replace it, also if the heat,cool, off,switch will not work it is not repairable. Go to Home depot or menards and pick up a thermostat. Find somebody with some handy man skills and they can replace it for you.
Nov 28, 2011 | Honeywell Programmable Thermostat Heater
I HAVE A HONEYWELL T8600D 2028, CHRONOTHERM IV PLUS DELUXE PROGRAMMABLE THERMOSTAT, AND THE TIME/DATE SETTINGS DO NOT HOLD; EVERY MORING, IT FLASHES MONDAY, 1pm. ANY SUGGESTIONS? I RESET TIME/DAY,...
pknab, I have the same problem. And it comes down a few things: 1) the flashing 1:00 indicates that you've lost power, and the system needs to be reset. 2) Reset means taking out the batteries for longer than 5 minutes. 3) You have to change your filter monthly. There's one in the cold air return and another one in the furnace. If you don't, your FURNACE may be causing number one (my conjecture). 4) We had an electrical storm 2 days ago--nothing else in the house lost its sense of time...but...well...the online operating manual is difficult to find try http://customer.honeywell.com/techlit/pdf/69-0000s/69-1400.pdf or http://dl.owneriq.net/e/e67c2c91-73c2-4bd8-abc8-91d843a27658.pdf (but it doesn't tell us this stuff...I'm still looking for the meaning of the EEE in the display..perhaps I have repowered the thermostat/furnace in the wrong order).
Dec 07, 2010 | Honeywell Programmable Thermostat Heater
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
May 12, 2010 | Honeywell Programmable Thermostat Heater
Thermostat not functioning correctly
-AC means there is no power coming from the furnace. not a tstat problem
Sep 24, 2009 | Honeywell Programmable Thermostat Heater
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
May 11, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
3,422 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
