Question about Whirlpool AWG5122 Front Load Washer
The washin machine stopped mid-wash, the on button and timer button are now flashing but the machine is unresponsive
  • 2,272 Answers
Unplug the machine from main power outlet and wait for 10 minutes then reconnect and recheck.If still the same problem then check the power to the motor with the meter.If the motor has power then its the timer control short or the faulty control panel board. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    Why did my washer stop mid cycle and now won't work at all?
    Hope your warranty is still in effect. It sounds like your control board has an electronic problem that will require replacement; typically around $135 for the part and $110 for the service visit.
    Aug 21, 2014 | Zanussi Washing Machines
    My washing stopped working mid cycle. I checked
    the timer is probably sticking (needs replacement) or lid safety switch stuck open. try restarting the load and if stops at the same place it is the timer unit, if it fills up with water and than stops - lid switch.
    Mar 29, 2010 | Washing Machines
    Stopped in mid cycle.
    The timer went bad. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure
    Nov 12, 2009 | Maytag Bravos MTW6600T Top Load Washer
    Machine wont complete a cycle, it clicks once then stops
    try to preceed manually to next program and if this problem repeat then the timer has problem chang it my advice donot try to select program during electricity connected to timer thank you
    Jun 07, 2009 | Whirlpool AWM5145/2 Front Load Washer
    Washing machine timer stops mid cycle
    Your lid switch needs replacing.
    Part number 3949237 available at any applinace parts store.
    Apr 05, 2009 | Estate TAWS800JQ Top Load Washer
    Ariston Margherita 1635
    try putting timer dial to the black dot and holding the start button until the red light flashes,then try selecting a new cycle.not sure what country you are in, aristons might be set up different in australia.hope this helps.
    Feb 27, 2008 | Ariston Technologies AW149NA Washer
    Machine stops at Mid Cycle and the Timer Flashes
    Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
    And pl rate me if helped.................
    Jan 25, 2008 | Kenmore Elite 45986 Front Load Washer
    Whirlpool AWG5122 Front Load Washer Logo
    98 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
