Question about Sewing Machines
Draper eyelet punch
i want to put some eyelets on fabric and have purchased a draper interchangeable eyelet punch but i cant seem to figure it out, it didnt come with instructions and i opened the packaging thinking i could figure it out but i havent been able to????any ideas???
  • Sewing Machines Master
  • 1,388 Answers
There are two sizes of metal........use one of each to create the eyelet.
Thread the longer one over the stalk shaped side, and the shorter one on the other side........if the fabric is lightweight, the clamping motion should also cut the hole as it engages to create the eyelet...if it is too thick, you will need a hole punch to clear the way first.
The action is for the longer shaft to pass through the fabric, then the inside edge of the smaller one, then the edges are bent and rolled but the flanged die to finish and secure......try a few samples on scrap first.
Posted on Jun 01, 2008
Where do i find direction on the eyelet stich
you mean button hole ?? google make /model/manual
Mar 30, 2015 | Sewing Machines
Small loops random are appearing on the back of the fabric
Are you using a large needle, size 110 probably would be required. However, this does sound like a tension issue, although it is appearing on the bottom, its probably your top tension device that is causing it, check tension is set to 4 or 5, and that your top thread is threaded into all the eyelets correctly.
Clean your top tension device if you can get to it, these do gunk up with dye particles and dust with time and this can affect performance. To clean, turn dial to zero and "floss" between the metal tension discs with selvage edge of a clean piece of waste cotton fabric, if some black stuff comes out, keep cleaning. Set tension back to normal setting when done.
Also, I am assuming that you are using a good quality thread, polyster, or a cotton wrapped polyester. Gutterman, Sylko, Mettler, Metrosene are all good.
May 09, 2012 | Brother Sewing Machines
Thread breaks after sewing short distance 1
first check the threading path and tension device and see if thread is catching somewhere. check it is in the take up lever correctly. check the spool on the holder and see if it is snaring up there on something. is thread old dry and brittle. check needle isnt burred or bent- rule is use a needle for 4-6hours of sewing then chuck.
if you can access the top tension discs then clean them out. turn tension dial to zero and floss between discs using edge of a ckean piece of cotton fabric. often lint and dye particles will build up in here. reset tension to 4 and thread upagain making sure thread is in all eyelets in the threading path. hold both threads at theback when you start stitching.
Dec 31, 2011 | Sewing Machines
I am trying to do a flatlock seam. It is so tight that I cannot open it.
Flat lock is done with only three threads so unthread the right hand needle, then you need to turn down the tension on the left needle, as this is the part of the seam that needs to pull open when you pull the two pieces of fabric apart. You may need to move the cutting blade hard left too as you need to minimise the amount of fabric that will lie inside the flat lock.
You then seam and pull open the seam to get the flat lock look. A flat lock gives two different looks on each side of the fabric, the ladder on one side is nice on lingerie as you can run a ribbon up through it like an eyelet. The other side looks like on sweatshirting as a seam finish.
Aug 13, 2011 | Baby Lock Imagine
Having trouble with the tension. I keep breaking the thread from the top spool. What are the normal settings?
normal tension for the top thread on a sewing machine is between 4-6, usually 5. If the top thread is breaking you need to firstly look at the thread you are using; is it old and brittle or a new reel. Don't use those cheap cottons you buy 4 in a pack in a bargain bin, they shred colour and fibres and are not good for the machine. Brands to use include Guttermann, Mettler Metrosene, Molynecke, and Madeira.
If you can access them, try cleaning between the discs on the tension device. To do this, turn the tension dial to zero, then "floss" between the discs using the selvage edge of a clean piece of cotton offcut, if some gunk comes out, clean some more. You can moisten the fabric with denatured alcohol if the discs are pretty gummed out. Make sure you set tension back to 5, then thread up again and pay particular attention to the thread take up lever. This draws down the thread from the spool on its downward stroke, so is necessary to ensure smooth flow of thread from spool to needle.
Also see if the thread is catching anywhere in the thread path, it may be catching on the thread spool itself, some have a slot to hold the thread during storage. Also see if the thread has wrapped around any of the thread eyelets or part of the machine. Make sure its threaded through all the eyelets in the threading diagram, usually top eyelet, tension dial, take up lever then down to the needle.
Try all these things and see if it resolves the issues you are having, it is easy sometimes to just miss one part of the threading up, even experts do it sometimes.
Jul 29, 2011 | Elna 2007 Mechanical Sewing Machine
My thread keeps breaking on my elna tx electronic sewing machine
Love the TX, its a gem. Is it the top thread that is breaking before the needle?
You could check the following:
tension dial - set to 5 and working okay? Unthread, turn it to zero and floss between the discs with a clean piece of cotton waste to remove any lint and dye build up. Turn back to 5.
Thread - are you using a good quality polyester or cotton wrapped polyester thead on top? Same thread top and bottom. Also check the spool doesn't have a little knick in it to hold the thread tail, sometimes the thread will catch in this as it runs off. Turn the spool up the other way. Using a felt disc under the thread spools also aids in a clean flowing thread. You can always make your own by just cutting a circle of felt about an inch diameter and punching a hole in the middle with your awl. Have you got the little thread eyelet out from the top accessory box and have the thread running through this?
Now check needle isn't bent blunt or has a burr on it and look around the needle bar or the eyelet above it to see if there is any sharp protrusion that is rubbing or catching the thread. Put in a new needle, flat shank to the back, and rethread down to just before the needle. Lower the pressure foot to engage the tension device and pull the top thread, there should be resistance but if it feels like its just not releasing at all, then the tension device could be faulting.
Remember, to always hold the two thread tails firmly behind the sewing area at the start of every seam to avoid them being pulled into the bobbin area.
Test sew again after trying the above; if no joy then take it to an Elna dealer. In face if the machine has not had a service clean in past two years then I'd definitely recommend you look up your nearest Elna dealer and take it in for one. Well worth the money for this little gem of a machine.
May 04, 2011 | Elna 2007 Mechanical Sewing Machine
Have a euro-pro 9110 lcd screen lights up cant see the lettering ?
There should be a small round button on the front of the machine just big enough for your finger tip with lines around the outside like the rays of the sun or an eyelet.It should turn with the tip of your finger.Turn it back and forth for the desired light.If this dosent work you have a a bad display screen.
Feb 01, 2011 | Euro-Pro 9120 Computerized Sewing Machine
I have a White model 2037 and am sewing a quilt. I am having problems with the thread becoming disengaged with the arm at step #2 of the threading process. When I slow the machine down, the threads comes...
I think you mean the take up lever? are you sure that the thread is threaded correctly into the eyelet/thread guide above and below the take up lever?
If it is an open ended take up lever (many are now) then the thread may be coming loose from it on the upwards stroke because the thread is not being held in an eyelet after it passes through the take up lever, or there is insufficient tension on the top thread.
If you are sure that the threading up is correct and it is still happening then you may need to make a modification to the take up lever and turn it into a closed eye. You could take it to a professional and see if they can maybe remove the takeup lever, close down the loop at the end with pliers and then reposition it on the machine.
Or maybe try a home solution by finding a grommet or metal eyelet part and somehow mounting this into the open part of the take up lever carefully with a small amount of plasticine or bluetack perhaps. Just a guess though, never needed to do this, if my thread comes out its because I don't have it threaded fully somewhere.
Jan 16, 2011 | White Sewing 2037 Mechanical Sewing...
My machine skips stitches, and the thread wears at the needle, causing it to snarl and break. I've looked in the manual and tried everything they suggest.
This sounds like the thread is not in your take up lever, are you sure that it is threaded correctly? Maybe it is wrapping around one of the eyelets or the take up lever rather than just going through the eyelet. The fact that the thread is wearing at the needle is indicative that the thread is too tight when the needle goes downwards. Is your top tension set too high perhaps. The skipping stitches part is normally indicative of either a blunt needle, using a sharp needle on knit fabric, or the timing is out slightly.
You should be able to trouble shoot the first two options. For the timing, will it sew a zig zag stitch at all? If timing is out or you've tried all the other trouble shooting; I'd suggest a trip to the serviceman.
Oct 27, 2010 | Elna 3210 Mechanical Sewing Machine
Hi, what is a eyelet?
An eyelet is a small hole with a metal ring-like you put shoelaces through or those on a belt. On a sewing machine it would be the same genally in shape-a small hole with stitches around the edge to suit the same purpose-threading a ribbon through or suchlike.
Oct 04, 2009 | Brother XL-5500 Mechanical Sewing Machine
Sewing Machines Logo
125 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
