Question about Ovens
I have recently bought an ex display Neff F3470 range cooker. It would appear that all the ovens have been deactivated. Howver the lights for each oven and the fan all come on. I believe there is a button sequence that can be used to reactivate the oven - anyone know what it is? Any help would be apprecaited :-)
5 Suggested Answers
SOURCE: Neff u1271 oven not heating
Found the fault. It's the heat ring in the main oven. MAKE SURE THE MAINS POWER IS OFF PRIOR TO COMMENCING THIS WORK!!!!! 1.Simply remove the four screws that fix the fan surround in the main oven. 2.Remove the rear cover fixing screws and remove the rear cover. ( the cable passes through this so just rest it to one side ). 3.Remove the two push on spade connectors from the heater element ( positioned just down and to the right of the fan assembly ). 4.Remove the four heater element fixing screws from inside the main oven. 5. The tricky bit. . . There is one more fixing at the top of the fan in the main oven. I could not get the fan off its spindle, but the next step sorted this out. 6.Remove the three fan fixings from the rear of the oven. This allows the fan to wobble/move enough in the oven to remove the final heater fixing screw at the top of the fan. 7.Pull the heater element into the main oven. No doubt it has a very grey and flakey appearance to part of it! 8.Buy a new one and replace it in reverse order, remembering to replace all fixing screws as you go. 9. If you forget which way the cables on the heater element go, the one with the red marks on it goes to the left as you look at the back of the oven from the outside. ( nearest the fan assembly ) I know this all looks a bit long winded, but it really is quite simple if you follow the notes above! Hope this helps someone. Might just save a ridiculous call out charge from the professionals!!!! Best of luck, Keith.
Posted on Aug 18, 2007
barkencoa
  • 3463 Answers
SOURCE: neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Posted on Feb 10, 2009
SOURCE: Neff oven B1641
Turn the right hand button onto the ECS symbol. This is the cleaning cycle. Make sure you put some soapy water in the 'well' at the bottom of the oven. The oven is then steam cleaned.
Posted on Mar 08, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
I have a neff double oven - When i try to use the top cooker the functions light up when selected then go off. The display shows -5- & the temp does not show on the screen when i turn functions on.
although it looks like a five it means safety activated or to be more precise child lock to switch off turn oven selector switch quickly 3 times off and back on between off and light only this will turn child lock off.
May 25, 2016 | Neff Ovens
Just bought a Neff oven and they left the demo mode on. The manual doesn't tell us how to remove it..
To deactivate the demo mode, touch * and the ( buttons for 5 seconds.
Jul 01, 2015 | Neff Ovens
Oven light switching on and off
which model is it?
switch it off at the mains ie fuse boad...label cooker switch....for 10 seconds, then back on.
Sep 04, 2014 | Neff Ovens
We bought a discounted display model Neff single oven from Comet and have booked an electrician to wire it in however there don't appear to be any cables coming out of the back of the cooker so how is the...
He will probably hard wire it from the terminal block inside the back panel of the oven into the cooker switch or outlet plate on the wall.(providing there is one, if not he will have to wire it back to the main fusebox) .
Dec 17, 2010 | Neff Ovens
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
Mar 21, 2010 | Neff B1421 Electric Single Oven
Hello could you tell me were i can get the glass front door from for a neff b142wogb/01
yes you need to go online to bosch website and look for quickfinder this is the tool used to locate spares, the site is for bosch neff seimens as they are all one company put in your enr number or model number and you will get an exploded diagram of your oven you can then find part number.
I looked and it appears to be 297595 in brown or 297601 in white retails at £61.03 ex vat
HOPE THIS HELPS.
May 09, 2009 | Neff B1421 Electric Single Oven
Fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Dec 19, 2008 | Neff U1721 Double circotherm Electric Oven
Neff cooker model b1422nogb bulb replace
Apr 28, 2008 | Neff B1421 Electric Single Oven
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Ovens Logo
132 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
