Question about KitchenAid KSM150PS Artisan Series Stand Mixer
As I was using the mixer, the "kitchen aid" attachment insert cover fell into the bowl. The mixer stopped immediately. Now, when I turn the mixer on, the motor hums but the mixer will not turn. I hope this is a safety mechanism and there is a way to reset the mixer. HELP!!!
  • 185 Answers
There is gear damage inside unit. will need disassembly to evaluate damage.
Posted on Aug 31, 2010
I own the 6 QT Stand mixer. Is there a Is there a 4 or 5 qt bowl that works with this mixer?
Kitchenaid does not make a 4 or 5 quart bowl that would fit your 6 quart mixer, but other 3rd party companies do!
You may be in luck.
I haven't seen this bowl in person, but it apparently will fit your 6qt mixer. Here is a link to a page selling the mentioned attachment. It comes in a set, with appropriate wire-whip attachments:
http://www.chefscatalog.com/product/25686-kitchenaid-3qt-stainless-bowl-and-whip-set.aspx
Jan 13, 2015 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Kitchen Aid Classic Stand Mixer beater stops when it touches anything.
Very much the symptom of a worm (follower) gear needing replacement. Three are videos of this posted on the net and you can find the Service Manual at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Jun 09, 2013 | KitchenAid K45SS Classic Stand Mixer
Mixer arms shake when kneading bread
You have not supplied a model number and the bowl lift models are not all the same. A couple of items you could check, make sure that the bowl retaining clip that engages with the dimple on the pedestal side of the bowl is not broken. Make sure any bolts/screws holding the pedestal to the base or the pedestal to the motor are tight. Even if you supply a model number I can't think of anything else to look at unless the handle is not lifting the bowl up tight enough. I think on some models the arm holds the carrier up with some pressure which would help stop the wobbles.
Jul 13, 2017 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
Need bowl and mixer attachments for Kitchen Aid Artisan Mixer
We've found most all accessories at any place that sells the mixer. Bowls, beaters, meat grinders, pasta makers, etc.
Jan 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid 300 watt counter mixer model ksm90
no there is no adjustment . worn hinge on the base , no parts made , not that i have ever seen ...... sorry i wish i had better news
Jan 05, 2009 | Hobart A200 Stand Mixer
Kitchen Aid Classic mixer
There are 2 possibilities, the attachments are worn out where they go on the shaft, simply replacing them could fix it, the other is the shaft is worn out inside the planetary ( where it spins), if it moves allot, 1/8 " or more from side to side, the housing is probably worn, and the planetary needs to be replaced, easy job, don't know cost, a new mixer may be in order.
Dec 26, 2008 | KitchenAid K45SS Classic Stand Mixer
KitchenAid Artisan Stand Mixer - Tilt is Tilting too Much & hits the bowl!
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Sep 23, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Kitchen aide mixer
was the bowl snapped in to place.....push down on the back lip of the bowel until you hear it snap
Dec 30, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Kitchen aid mixer
Tilt the head back and remove your cardboard shim. You should see a screw head. Turning this screw adjusts the beater/bowl clearence.
Apr 13, 2017 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
149 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
