Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
My clutch is so loose it wont drill through balsa
Loose clutch
  • dave_total May 27, 2008
    i recently replaced a motor on a dewalt dc925 18 volt hammer drill it seem's to my luck after returning it to it's owner that the clutch will slip no mater what setting it is on .i have been all through the transmission and everything look 's to be in order im thinking its possible in the nose peice any idea's ??? thanks
  • mustang_5l87 Jul 05, 2008
    Yes, I have been having the same problem. In the drill position the clutch still slips. It has been getting worse. It started happening in 3rd gear and now it happens in 1st. now It wont drill at all without the clutch slipping!
    Rob B.
    Champion:
  • 313 Answers
Give me more info pls of what wrong
Posted on May 27, 2008
  • mr aicnelav May 28, 2008
    if it is slipping while holding chuck its the transmission problem.
Motor works and spins but as soon as the drill touches the wall drill stops but motor keeps going.
Check the speed switch on top - sometimes it doesn't fully seat in the 1 or 2 position. Switch it to the opposite setting, run it, then switch back, until it seats properly. Also check the clutch control ring for the same issue.
Jul 21, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
Clutch problem on drill??
or it could be as simple as it became loose, open the chuck all the way , look into the hole in the middle,, you'll see a screw head,, tighten it
Aug 03, 2010 | Milwaukee Tool Milwaukee General Purpose...
The clutch wont engage
Sounds defective.. Bring it back for replacement or refubd
Mar 06, 2010 | kawasaki 19.2v 20 Pc Cordless Drill Set
Need to remove the chuck to access the adj. clutch
first remove the chuck ret screw it is LH threads, shift the tool to the low position and the clutch to drill only. Find a bent handle allen wrench about the chuck capacity and lock the smaller end into the jaws, next put the chuck on a workbench or block of wood with the long portion at about a 30 degree handle so you can hit it counter clockwise and strike it with a hammer, it might take a few hits but it will come loose.
Sep 26, 2009 | Dewalt Drills
My Craftsman 19.2 drill's adjustable torque clutch want allow drilling in forward gear.
Try with the drill chuck torque setting set to max. If no joy on that one, work tha low/high speed switch several times. If no luck there, you may need to open the drill and check for a loose linkage, or that something has slipped out of place. It's not difficult.
Regards, --W/D--
Jul 17, 2009 | Craftsman 19.2V C3 DRILL/DRIVER
When in drill mode the tork still kicks in on my dewalt
clutch is bad. can be repaired but ive always had a pro do it. bit spendy
Apr 22, 2009 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
My Makita handrill is not working. It's just like loose,and the drill is not rotating anymore.
Your bearings in the Clutch have fallen out of place.
Basically the tension screws pulling the clutch against the body.
Have became loose. If you Tighten them most likely wont fix it.
You should contact Makita. If you do open the drill. The Clutch assembly will be a task to reassemble. And the warranty might be voided.
Aug 17, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Clutch and speed selector problems
drill needs transmission and switch probably co'z it's loosing the varaible speed.
Jan 19, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Clutch
Get a torx bit, either 10 0r 15 & slowly undo screws about one third. There should be 4 of them. When screws are loose they will take pressure off selector & you should be able to free it up.
Cheers Lance
Nov 17, 2007 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
99 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Tyler Craig
Tyler Craig
Level 1 Expert
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
