My Bosch WFL 2450 WASHING MACHINE MAKES NOISE BUT WON'T SPIN , IS IT THE MOTOR?
  • 2,272 Answers
Yes its the motor fault.It can be blocked or faulty motor or short in motor connections.It has to be checked and confirmed.but if motor and its connections checked ok then other possibility is your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 30, 2010
How to remove *** wire from bosch wfl 2450?
Here you go....
http://www.scribd.com/doc/187416757/Bosch-Maxx-Wfl-2450
Aug 21, 2014 | Bosch Washing Machines
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Bosch classicxx
could be the engine check if the motor in not dirty the coper motor next to the brushes has got gold ish colour if not just clean with sand paper
the noise could be the bering ( if the noise is cracking ) ( if the noise is metal could be somthing in iner drum )
Jan 17, 2013 | Bosch Classixx WFL 2066 Front Load Washer
I have a bosch classixx express 1200 washer and when its on rinse it makes such a loud noise and also when its on spin, its like a grinding noise. hope u can help.
The noise is relative to the motion and so the areas to check must be the moving parts of the washer. So shut down unit , disconnect power and check manually the movement of the motor, the rotor and the drum.
the bush can be worn out the suspension can be weak or the belt can be faulty.
your observation while the motor works is important.
Check these links below for some help :\
http://www.washingmachineadvisor.com/how-do-washing-machines-work-.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
Feb 15, 2011 | Bosch Classixx WFL 2066 Front Load Washer
What is the life expectancy of Bosch front loader (under counter)? Making loud noises during wash - not spin - cycles. Worth repairing?
not long. have a Bosch Axiss WFL 2060. It started making buzzing noises starting about a year ago and I ignored them. It failed and I am replacing either the motor or/and more things. If ur a DIY its definitely less expensive than a new machine. dwkendall sends
Dec 27, 2010 | Bosch WFK 2401
Doesnt spin on spincylce and just makes a rattling noisewff1475 bosch
The rattling noise is probably something in the pump.
If it is not draining properly, this will stop it spinning.
Check pump filter, if clean, then I would suggest you check the brushes in the motor for wear, as badly worn brushes will also stop it spinning.
Please rate my solution.
Thanks.
Nov 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Maxx WFL 2450 Washing machine Electric fault
hi there ...it sounds as the watyer leak has found its way into the motor windings and damaged the motor..and the control module.....could be a very expensive repair
regards Sir Galahad
Aug 18, 2009 | Washing Machines
Changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Washing Machines
Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Jun 01, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
