Hi I bought this machine as not working for 1 dollar. And i love to tinker its a LG WF-T802 it has a small water leak from the water pump about 2 drops every second. but the bigger problem is, the water fill pressure switch isn't working it will overfill if I allow it, even on the small setting. Just wondering if this has to do with the water leak or the pressure switch? I do not get a error message on the control panel. Also should the tube from the pressure switch be one full unbroken tube? As this one has a short tube at the top and a red plastic adaptor (which is basically a tube with a hole in the middle) then a second tube down to the tube I haven?t seen this before, but I normally work on older machines so this maybe normal.
  • Michael James
    Michael James Aug 30, 2010
    Wow Fast Response. It was so help they confirmed my suspensions before i spent more money on parts it was very helpful. And they even gave me a link to a service Manuel and part number list wow what service I will be using you guys again and again cheers Mike
  • Washing Mach... Master
  • 19,396 Answers
Hi.
RE "it has a small water leak from the water pump about 2 drops every second."
Check the hose attachment to pump, if the hose is not leaking, then the pump must be replaced.
RE:"the bigger problem is, the water fill pressure switch isn\'t working it will overfill if I allow it,"
First blow in the tube and clean attachment, if that does not work replace the pressure switch, that is a cheap part. Part nr is 6600FA1704M. Here part at Au$42.
Here different seller.
RE:Also should the tube from the pressure switch be one full unbroken tube?
Not necessarily, this one is in two parts with a rubber joints.
I think that you will also appreciate service manual and part list, available for free clicking here (select GET MANUAL in opening page).
In case this was helpful, please do not forget to accept.
Regards.
Ginko.
Posted on Aug 30, 2010
I have a LG Fuzzy Logic WF-T5001PP washing mashine. It is taking longer for the water to enter. Does it have a water inlet filter that I can clean?
HI... If u see your backside of your machine there is a inlet valve (water inlet valve) open that water tube and see one small netted filter is there you just remove that filter outside and clear that filter with a tooth brush and insert it again....
Jan 15, 2017 | LG Washing Machines
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
LG WF-T652A I have a leak when the machine is on. I have checked both the outlet pipe and the pump , neither are leaking or show signs of water. Is there an overflow from the bowl which may be the s
when the cover is off turn the machine on and trace the leak if you can it could be from a faulty valve. also see where the leak is on the ground so you can get a idea where the leak is.
Jan 09, 2015 | LG Washing Machines
Lg wf-t9230tp is not pumping
Open small door at bottom front of washer. get a pail and put small black hose in pail and remove plug. After machine is drained remove large screw cap. probably a sock or something in trap remove and put back in place.
Apr 23, 2014 | Washing Machines
My washing machine LG WD1238C keeps showing error message OE hose is not blocked or filter blocked does not finish any cycle or work correctly
This sounds like a blockage in the small hose connected to the waste pump. Take the lid off and find the waste pump down near the bottom of the machine below the drum, then remove any one of the hoses connected to the waste pump and check inside the pump to make sure the fan can spin using your fingures, maybe a small kids sock or similar jammed in there, if nothing in the pump check both pipes on the waste pump
Dec 27, 2010 | LG WM-2277HW Front Load Washer
WF 860 Has F05 Wont drain
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
LG washing machine WF-F 6861 CN Problem
ne yabba ardhamayye la rayye bae
Nov 08, 2007 | LG Washing Machines
Water leaking
Leaking pump or drain connexion most likely you will have to get under to check it out. Put a several sheet to news paper under the machine and pull it out as it stands to see where the water is coming from front/back/sides Do a wash and repeat. But you will need the service of an engineer I guess unless you are good with a wrench.
Aug 05, 2007 | Kenmore 43142 Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
