Question about Car Audio & Video
WHEN ENTERING THE cODE i MADE A MISTAKE AND THE INSTRUCTION CAME UP WAIT 1 HOUR. THAT WAS TWO DAYS AGO AND IT STILL SHOWS WAIT 1 HOUR Can you please advise on the action to take next. Thank you
    Genius:
  • 1,224 Answers
Disconnect the battery for about 30 seconds and reconnect it this is the fastest way to reset sterio so you can punch in code
Posted on May 09, 2008
    Scholar:
  • 98 Answers
Have you actually left the ignition on one hour?
if not, do that and see what happens. One full hour without touching it,, key on.. theyre on a timer, it should come back and want you to enter the coder after that hour...
How can you get your radio to work in you 1994 saab? when you disconnect the battery what is the next step to resetting the code?
Anti- Theft Lock
1. Switch on the ignition
2. Press the VOL/ ON switch to turn on the system on, CODE IN will appear in the display.
3. Enter the 4 digit code using the preset buttons. The system will now appear.
- I believe the code for your car is 5253, but you might want to call the Saab dealer for the code
If yu make a mistake while entering your code, finish entering all four digits. Press and hold BAND switch until CODE IN appears in the display. The correct code can now be entered.
NOTE: If you enter an incorrect code three times in succession, you must wait one hour with the Audio Sysytem turned on before making a new attempt. After the one hour waiting period, the system will allow only one code entry attempt. If the code entry is incorrect, you must again wait one hour before another attempt.
Apr 22, 2011 | 1994 Saab 900
I cannot find my owners manual of my 2004 Honda CRV and need to reset my radio. I have the reset code but need the instructions on how to reset it.
Method for all Honda/Acura vehicles except '03-'07 Accords with navigation system
1. The code is five digits, which will correspond to the radio station preset buttons that are numbered 1 through 6.
2. While the radio's display is showing COdE, punch each preset button once, IN THE ORDER GIVEN.
Example: Code is 62531. Hit the right-hand (6th) button first, then the 2nd from left, then the 5th from left, and so on.
3. If you have done the order correctly, the radio should start working after the last digit has been entered. If it does not, then you have made a mistake. You may try up to ten times (only three times on some models!), after which the radio will lock up and you need to then either disconnect the car's battery or wait one hour before trying again. If you disconnect the battery, disconnect both cables from the battery, then touch the cable ends together. Some radios have capacitors that will keep the memory alive for up to ten minutes. Touching the cable ends together will discharge the capacitors.
4. If you make a mistake in code entry part way through, CONTINUE entering ALL digits of the sequence of five, even if they are just random! You MUST finish the sequence of five in order for the radio to allow you to restart the sequence. or you can go to a honda dealer for instructions on how to reset radio. have a good day !!
Apr 09, 2011 | 2004 Honda CR-V
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Release clock button
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
Hi , i have tried what you mention for hb88rc let say i am doing the programing and it is currently 10 am. (example) i want it to be on at 7am and off at 7pm for the entire week i do as the instruction...
You happened to catch the same guy that answered before.
Lets go through the exact programming steps:
Your schedule is ON at 7am and Off at 7pm ALL week.
1) Set the clock to current time:
Hold down clock button while doing next steps
Press Hour button until correct Hour am-pm shows (10:00am for example)
Press MIN button until correct minute shows.
>>> Now wait, the manual seems to leave off a step here... it doesn't say to enter current day.
OK, lets make sure current day is set.
I guess you press Day button until current day shows.
Now release the clock button.
2) Program the timer to your schedule:
Press and release PROG button.
press it once and Program1 ON is ready to be programmed
The screen looks like the picture below:
3) Ready to set Program1 ON:
The display shows the number 1 and it shows the word ON.
Press DAY button as many times as it takes until all days show at top of display.
Press Hour button until 7 am shows in display
Double check that the time is AM
Press MIN button until :00 shows in display
4) ON time for Program1 is set
We are ready to set OFF time for Program1.
5) Press the PROG button until the display shows Program1 OFF just like photo below
Notice that the number 1 and the word OFF appear on display
6) Ready to set Program1 OFF
Press Hour button until 7 pm shows in display
Double check that the time is PM
OFF time for Program1 is set
7) Programming is complete, and we are ready to use the timer
(If you want more programs, press PROG button until program2 ON shows in display)
8) To exit programming, press the CLOCK button.
Current time show in the display.
The timer should be operating correctly now.
Add a comment, if you want to contact me directly.
Nov 09, 2010 | Intermatic HB88RC - 7-Day Programmable...
Time and outdoor temp not functioning
You probably need to set the time zone. Hit the set button until it shows the time zone (ie -7 MST), then hit the "+" button until it shows your time zone and the correct time. Continue hitting the set button to cycle through to the end of the settings.
Jun 24, 2010 | SkyScan 86709 Atomic Wall Clock
Car radio code
Leave SWITCHED ON....UNDISTURBED for at least 1 hour
Make sure you have the correct code
Jan 17, 2010 | Car Audio & Video
How to enter radio code for 2003 honda pilot, have code but don't know how to enter it
Try this:
Use the Preset buttons to enter the five-digit code. If it is entered correctly, the radio will start playing.
If you make a mistake entering the code, do not start over or try to
correct your mistake. Complete the five-digit sequence, then enter the
correct code. You have ten tries to enter the correct code. If you are
unsuccessful in ten attempts, you must then leave the system on for
Hope it gets you there.
Dec 12, 2009 | 2003 Honda Pilot
Car radio wont work after battery going flat.
did you leave the radio powered up for an hour?????????????
May 25, 2009 | Car Audio & Video
I put the wrong code in twice by mistake and now it is locked on safe and shows I have tried twice, it is supposed to let me try again after an hour, but it has been two days.
Radio must be left on for one hour. If you entered the same number twice, then the code is incorrect. You have to get the 14 digit number off the side of the radio and give it to an Audi dealer to get the correct 4 digit security code.
Apr 20, 2009 | 1999 Audi A6
VIP722 Shows about 1/2 of recorded show and quits
The short answer is that you have a corrupt hard drive and the receiver needs to be replaced. Thanks for using Fix Ya.
Apr 10, 2009 | DISH Network DVR-625 DTV Receiver /...
Car Audio & Video Logo
76 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
