Question about Sharp R-963 Convection/Microwave Oven
Sharp Covection Oven/Microwave stops after 1min on any setting
My 3 year old Sharp R957 Combi Microwave/Covection oven/Grill, stops after exactly 1 min on any setting or mode when using Grill, Oven, or microwave. You just press start for it to restart and then after another minute it stops again. No sign of any burnt out parts or circuits inside; heat coming from whatever mode in use for the minute it runs and microwave works fine and heats stuff for one minute. Any Ideas and is it likely to be expensive?
Thanks in advance.
  • 2 more comments
  • reesm Aug 16, 2008
    I also have this problem with a Sharp R-957 microwave. It will only run for 59 seconds and then stops, regardless of which power or time settings you enter. It cooks ok for those 59 seconds and will reset and start each time, but it always stops after 59 seconds. There are no apparent or obvious defects when looking inside the cover.The microwave is approximately 3 years old.
  • Anonymous Jan 02, 2009
    I had the same problem. After 59 sec the timer stops no matter in what mode the unit is. I disassembled the unit and found that the motor of the damper panel was not running although it was powered.
    Taking the motor out and carefully disassembled this part (be careful it is inside like a watch) After jogging the gear wheels gently it became free again. Reassembled all the parts again. The unit is working fine again thanks to the tips on this forum.
    Andre Peeters, Belgium
  • Anonymous Mar 12, 2014
    Can I fry/grill and roast in the Covection oven
  • Anonymous Mar 25, 2014
    grill is working,but microwave not heating anything ?
  • Sharp Master
  • 9,098 Answers
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Sharp Covection Oven/Microwave stops after 1min on - db711c4.jpg
Posted on May 09, 2008
I need to know the dimensions of a sharp r-1471 microwave. Mine has stopped working and I want to make sure the replacement will fit
29 15/16" W X 16 3/8" H X15 1/4" D (outside dimensions)
I copied this from my Sharp Carousel Operation Manual as I just
had to replace my 13 year old microwave.
Apr 04, 2012 | Sharp R-1480 Microwave Oven
I have a Sharp 963 combi oven.. The microwave has stopped heating everything else is working.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ]
Aug 01, 2011 | Sharp R-963 Convection/Microwave Oven
Sharp R957(W)M jet convection oven and grill. Trips the elcetric when I open the door? Any ideas please?
Check the door interlock switches and contamination around the lower switch.
Jan 23, 2011 | Microwave Ovens
Looking for operater manual for sharp covection oven
http://www.sharpusa.com/~/media/65B6B50076584AA0B66678537D761381.ashx
Mar 03, 2010 | Sharp R-1870 Convection/Microwave Oven
Changing the interior lightbulb of Maytag #MMV5207BCW over the range microwave? How the #$!% do you get the cover off to change the bulb?
I have a belling combi microwave, the covection oven works well but the microwave oven has stopped heating the food up and also the defrost isn't working ? Any tips or does it need repairing and wat are the costs?
Nov 24, 2009 | Maytag Appliances Over-the-Range Microwave...
Faulty microwave function on the SHARP R-957 model (900watt)
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 10, 2008 | Sharp R-930AK Convection/Microwave Oven
Sharp R-963 Convection/Microwave Oven Logo
1,274 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
