Question about Sony Walkman WM-FX195 Personal Cassette Player
My walkman which was given to me by my dad way back,i decided to use it and though the indicator light turned on,it refused to play the cassette
  • Sony Master
  • 17,130 Answers
The belt in the main drive as worn out as youhave kept it off from use. In period of time these belts age off and gets softened. There is now difficulty to get these small belts in the market after the arrival of the CD's and ipods. So carefully open the back side -only if precision work can be done than to spoil the gift-- remove the back ccover, the board and the belt can be seen. take sample to buy and replace in the same arrangement.
Credit if info is useful.
Posted on Aug 30, 2010
1.I use cassette player everyday....that stuff is running slower n slower n finaly stopped...the sound's not getting clearly also....How could I do? 2. And the probllem is the same with m CD...
there are little rubber belts inside that attach the motor to the gears that turn the tapes or cd's. over time they stretch out and turn everything slower and slower. you can try replacing the belts, or finding the speed adjustment screw for the motor and turning it up. either one is usually more effort than its worth though. they just weren't designed to last for a long time.
Mar 25, 2011 | Sony Walkman WM-D6C Personal Cassette...
Speedproblem. My wm-d6 walkman goes way to fast! More than twice as fast normal speed 4,75cm/s. Is there anything I can do about it myself or is it a component failing? /Mats
Inside the unit, theres a capacitor or something on the circuit board that has a little phillips head screw area on it, that if you turn it either clockwise or counter clockwise, you can adjust the speed of the cassette playback. This is usually a silver metal thing sticking up somewhere inside kind of shaped like a letter "U'. the inside of the "U' is a round insert like I said with a phillips head screwdriver cut out. just turn that inner piece left or right while playing a cassette to your desired speed.
Nov 08, 2010 | Sony Walkman WM-D6C Personal Cassette...
I have a sony walkman WM-3. It suddenly stopped playing. Do you do repairs ?
Please check for the belts if the battery you have installed is new and the set gives a hum on play. If not you will have to check the power switch, the mechanism switch and the line to the main board.
If the motor turns but not the capstan and the reel then change the belt, the rollers or the pulley. I hope this will get your set back to action. Good day
Jul 19, 2010 | Sony Walkman WM-D6C Personal Cassette...
It wont play tapes
If the walkman comes on but just wont play tapes then more offten then not the belt has broken or clutch has worn out and will have to be replaced.
you will have to open the walkman up in order to do it, you can get a new belt from any electronics parts supply store (not radioshack) there usualy around $1 and are easy to put on.
Jul 19, 2009 | Sony Walkman WM-FS399 Personal Cassette...
The power is on but the motor will not turn the tape drive. Does anyone know a good repair shop?
Hmm, when you press play, can you feel the motor turning, do the spindles turn on fast forward or rewind? If so you may have one of two problems. First check to see if the cue button is is depressed. If it is jammed, the deck will FF and RR but won't play. If it's not that, but the motor still spins, the motor is no longer making contact with the flywheel. If you have a repair manual, dismantle the deck and check out the motor contact
May 10, 2009 | Sony Walkman WM-D6C Personal Cassette...
Sony Walkman cassette tape player operating at slower speed
If this is the WMD6C then it is servo locked and can be fine tuned with the pitch control on the back of the unit just turn the switch to on then adjust to preferred speed.
Dave, Electronic Doctors email eledocs@hotmail.com
Mar 31, 2009 | Sony Walkman WM-D6C Personal Cassette...
Cassette drive turns, speakers hiss but no music
Mode switch trouble! no audio from cassette function?
Nov 11, 2008 | Sony Walkman WM-D6C Personal Cassette...
Plays too fast
WMD6C has a pitch control on the back of the unit that can change the speed of the tape, so switch it off, but if that is not the problem then inside the unit it has a servo set speed pot on the main board.
Nov 08, 2008 | Sony Walkman WM-D6C Personal Cassette...
URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
May 18, 2008 | Audio Players & Recorders
Sony Walkman WM-FX195 Personal Cassette Player Logo
117 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
