Iternal battery gives error message 601 - Computers & Internet
    Guru:
  • 377 Answers
Error 601 takes place when the system is misconfigured or its essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.<br /><br />solution<br />To repair Error 601 correctly, download and install the repair tool below. This tool was design to successfully diagnose, find and fix the problems on your computer.<br /><a rel='nofollow' href="http://www.restoreguard.com/p/download/go2.php">http://www.restoreguard.com/p/download/go2.php</a><br /><br />hope that was helpfull<br />
Posted on Aug 30, 2010
How do you get to the internal battery on a G56 HP Laptop?
The error message refers to the battery on the bottom of the notebook that powers it when it's not connected to A/C power. If you go into the F2 at startup or use HP Support Assistant, you can run a comprehensive battery test
Mar 16, 2015 | HEWLETT-PACKARD HP G56-122US Notebook
How to replace the 601 battery
  • If Primary (internal) Battery (601) appears in the alert message, it means the measured storage capacity of the primary (internal) battery is less than 25% of the original storage capacity. The number "601" denotes the associated error code that is recorded in the system log.
To resolve a Battery Alert message, you should perform the Battery Test in the System Diagnostics (F2) environment, and calibrate the battery for best performance.
To access the HP System Diagnostics Battery Test , turn on the computer and immediately press the esc key to display the Startup Menu. Press the System Diagnostics F2 key, and then select the Battery Test option.
if it shows bad health You might need a new battery.
Aug 07, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
Internal battery 601
Replacing the bios battery will fix that.
Jul 14, 2014 | Computers & Internet
What does the internal 601 Battery do, and how to replace it
Do you use your power off the mains at all (not plugged in) It will be the main battery for the laptop.
If you always leave your laptop plugged in there isn't much point in getting a new battery. Perhaps you can turn off the error message on startup?
Feb 27, 2014 | HP Pavilion dv7-1129wm Notebook
Internal Battery Error
Time to replace your laptop's main battery.
Dec 17, 2013 | HP Pavilion Computers & Internet
Battery 601
This is battery error. You should install HP assistant that will show you how much battery life is expected and condition(normal, excellent, changeable)
Nov 22, 2013 | HP Pavilion dv7-1129wm Notebook
Error message 98.00.0C on HP 601 printer
how can i fix error 98.00.0c hp 600 m602.
Oct 29, 2013 | HP Office Equipment & Supplies
601 error message
Hello.
I am sorry that you are experiencing this error message. It generally indicates that your measured storage capacity in your primary battery is less than 25%. What this means is that your primary battery (601 indicates that it's primary) can only keep a 25% charge. To keep this quite simple for you, please attempt the following.
* Unplug your power cord.
1.) Start up your Laptop and hit the ESC key immediately.
2.) Press F2 to get into Systems Diagnostics.
3.) Select Battery Test. * Now, plug in the power cord.
4.) Start Battery Test.
The battery test will give you a STATUS. If you see the following;
- Calibrate: This means that your battery is functioning correctly but it is in need of calibration. Select the automatic calibration option.
- Weak: From here, please get a new battery to ensure that your getting adequate power supply to your laptop for use.
- Replace: Replace the battery.
- No Battery: If there is, indeed, a battery inserted. Remove it, check for dust/dirt and wipe it clear. Insert the battery and see if it works now.
- Unknown: Try to download all available updates from HP Support Assistant.
Feb 09, 2013 | HP Pavilion ze2000 Notebook
Internal battery error 601 hp compaq 6735s laptop
Remove the main battery and run the ac adapter only, if everything works fine the battery will need to be replaced, if the computer continues to shutdown the problem is most likely a bad cooling fan or it needs to be taken apart and given a good cleaning.
Jun 16, 2012 | HP Compaq 6735s Notebook
Computers & Internet Logo
481 people viewed this question
David Payne
David Payne
