Question about Whirlpool Refrigerators
Phillips whirlpool built in fridge /freezer smell coming from the fridge section,we have tried various things but the smell still persists
  • Whirlpool Master
  • 17,129 Answers
Could it be that there is degradation of the plastics due to heating of the defrosting coils or is it the smell off leaked gas.
Remove all the food stuff from the fridge and clean, wash the inside throughly. Now restart the fridge and after aboutone hour check for smell, continue this till you notice, if the smell comes in after about 10 hours then you must look into the defrosting heater for any traces of material on it causing the smell on heat.
Posted on Aug 30, 2010
When opening fridge, I smell a burning rubber/metallic smell- freezer is not as cold as normal
Do you happen to have a Model number?
Inside around the fresh food section door or wall
Appliance 911 Sea Breeze
Sep 18, 2015 | Whirlpool Refrigerators
Funny smell coming from under my whirlpool, side by side fridge freezer. I've often noticed this smell in shops with freezer sections. The only thing I can liken it to is stale ****!! Sorry!!
the smell is urea,it is the gas they use to make the injection mouldings (plastic and foam) it is HARMLESS,but does smell like **** cos its the same gas.........(the best leather is processed with femail ****.)use male **** to accelerate your compost heap... if you think im joking try it.....
Sep 07, 2010 | Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
My express thaw won't turn off
You have a bad main control board problem . Stuff a shelf in the refrigerator section with crumpled up newspaper and leave running ( the ink in the paper absorbes odor . Takes several days to eliminate .
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
WHIRLPOOL CB18M FRIDGE FREEZER
3 things to check. If you didn't adjust the damer from the freezer to the refrigerator, like closed it off. Is the freezer fan running? The fan blows air from the freezer to the refrigerator section. Some fans shut off when the door is open so you may have to push in the door switch to check this out.
Look for ice on the back wall, of the freezer section, If present then the defrost cycle is not working. The evap. coil is icing up and there is no air blowing into the refrigerator. Set the thermostat back to the normal setting it just causes a longer run time on the freezer section.
Oct 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Bad Smell In Freezer
Could be dead bugs in the drain line and other sludge built up in there...have your guy flush the drain!!
Jul 28, 2008 | Whirlpool ET0WSRXML Top Freezer...
Whirlpool fridge
3 things can cause this:
1) Inoperable fan in the freezer.
2) Defrost problem (frost build up on back panel in the freezer)
3) Damper inoperable (vent in the fridge section)
Look for these symptoms and let me know what you find.
Nov 17, 2007 | Refrigerators
Fridge Smell
i have a whirlpool fridgefreezer and their is a very bad smell comming from the back of it what can it be
Aug 02, 2007 | Hotpoint FFM70 Bottom Freezer Refrigerator
Refrigerators Logo
267 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
