Question about Dometic Rooftop RV Air Conditioner
I have a dou therm A/C unit model #03869and it appears to have a blocked drain[it is raining]inside!!! what do I have to do to unclog drain
  • Dometic Master
  • 17,130 Answers
The tray below the evaporator has a drain tray with a drain hole to fit in a hose. Due to high level off dirt accumulation it is possible that the tray drain is clogged and prevent the condensed water to flow out. Open the unit and look under the panel to find this, use a thin flexible cord to push into this drain hole to clear it. You can also use a good air jet with the flexible nozzle pointed to the hole to push out the dirt.
Posted on Aug 30, 2010
Testimonial: "thanks for the quick reply. it was very helpfull and the reply was sent in a timely fashion zenkayaker "
Doors collect water when it rains, on both sides
THE BEST WAY TO UNCLOG THEM WOULD BE TO TAKE THE DOOR INSIDE PANELS OFF AND CLEANTHE BOTTOM OF THE DOOR INSIDE.
Sep 21, 2014 | 2000-2005 Chevrolet Chevy Side View Mirror...
Dou therm thermostat
Make and Model of roof top unit please?
Nov 06, 2012 | Dometic Rooftop RV Air Conditioner
Looking to unclog the a/c drain hose/tube; no water anywhere in the car but when making turns sounds like possible water sloshing around.
Look around the firewall for flaps or holes that are blocked at the bottom.
Rain water or wash water accumulates in the body and sloshes around.
Debris can block the drainage holes, just like in a gutter.
Good luck to you on this one.
Jul 08, 2010 | 2006 Toyota Corolla
How can I unclug my sunroof?
The best item is weedeater (weedwhacker or whatever you call it) nylon. It is thick enough to push blockage out and flexible to handle any bends. Also check the exit of the drain tube (behind a cover near the front wheel on my GTV6) as an accumulation of mud will prevent the gutter from draining out.
Jan 25, 2010 | 1996 Saab 9000
The drains on my sunroof leak when it rains and water comes inside the vehicle. How do I unclog the drains?
A big leak with that model is the drain tray in the rear under glass has broken loose. To check the drains, park vehicle on an down grade, open the glass and pour a cup of water in on each side and the water should come out the front, Turn the vehicle around to check the rear the same way.
Dec 10, 2009 | 2000 Jeep Grand Cherokee
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Dou Therm Brisk Air not running
Turn the ac off go up top the coach and remove the cover. Look for fan blockage, Wasp, mud dauber etc. Caution if it is wasps they will chase you off the end of your coach. Take some spray with you. If there is no blockage the fan motor is toast.
Thanks for using Fixya
Jerry
Mar 27, 2009 | Dometic Rooftop RV Air Conditioner
I have a dometic dou therm roof mount a/c model number 59136.331 with a comfort control center 3109228.001. I get an error code ee and have no information as to what this code is this is the only thing...
The thermostat needs to be reset. Turn it off and hold the top and bottom buttons in at the same time and turn the thermostat on. In a few seconds will read FF and you should be good to go.
Jan 11, 2009 | Heating & Cooling
Dou therm ac
could be low freon, could be a bad capasitor, could also be a bad fan motor
Jun 25, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
122 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
