Question about Hoover Nextra HNT 2135 Top Load Washer
My washing machine doesn't drain - Hoover Nextra HNT 2135 Top Load Washer
  • Hoover Master
  • 17,129 Answers
Look under the machine to find the drain valve/pump. It might be clogged or faulty. When in the drain mode soon after the completion of the wash cycle , check for voltage to the drain valve/pump. If voltage is present and it does not work we are sure of the unit to be faulty but if there is no voltage then the program controller is faulty.
Check out the controller if faulty replace or clean the valve after removing for dirt, back flush test and refit. or if faulty coil replace.
Posted on Aug 30, 2010
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Miele honeycomb care w 1712 drain fault comes on every wash
see this possibles causes:
God bless you
attached diagrams
t spins, but doesn't pump
see line clogged and fix it.
It doesn't spin or pump
frozen pulley
It pumps, but the water returns
improve the drain laundry, if drain hose reaches more 4 inch cut off the excess
May 16, 2012 | Miele Washing Machines
My washing doesn't spin, It doesn't pump or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | Washing Machines
GE frontload washer doesn't spin
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
Water doesn't drain
heatman101
Aug 08, 2011 | Whirlpool Washing Machines
I have a MW511, it doesn't drain it just makes a humming noise
heatman101
Jul 05, 2011 | Fisher and Paykel GWL11 Top Load Washer
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
Machine doesn’t spin,
heatman101
Oct 10, 2010 | GE WDSR2080D Top Load Washer
Hoover Nextra HNT 2135 Top Load Washer Logo
82 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
