Question about Ingersoll Rand (IRTC2545E10VFP) 2545E10VFP Type 30 Fully Packaged (2304603 V) 10 Hp Air Compre
Takes a long time 2 build 130 lbs. of pressure & cannot keep consistent amount of replacement air refilling tank while i use my angle grinder for more30 -50 seconds. oil level good, could motor be wrong or pulley or both?
  • 17,129 Answers
Check the oil in the cylinder, check if single phase type on the capacitor to the motor, replace if the speed/torque is low.
check belt for slippage ,if so tighten by pulling the motor backwards after loosening the mountings and then tightnening.
If the motor speed is good and still the pressure build up is low then it is possible that there is low compression in the cylinder. Might have to overhaul to better efficiency. Hope there is no leak in the tank or drain or the cut off valves.
Posted on Aug 30, 2010
When i refill the fuel i can refill only 2 ~ 2 gallons
Generally speaking, the problem is a blockage in the filler pipe.
Something is keeping the air pressure inside the tank from being equal to the air pressure outside.
Oct 28, 2014 | Cars & Trucks
At what torque should lug nuts be tightened
Instructions
    • 1 Check the maximum pressure rating of the air tank. The rated pressure is indicated in pounds per square inch (psi). If there is no indication of limit on the tank, do not use it.
    • 2 Drain any accumulated moisture from the compressed air tank before filling. If the tank has no drain valve, you may skip this step.
    • 3 Remove the cap from the fill valve. The valve is the same size and type as used on automobile tires. The location of the valve differs depending on manufacturer.
    • 4 Attach the fitting of the air supply hose to the valve stem of the air tank and depress the fitting firmly. If the air tank has its own pressure gauge installed, keep a close watch to avoid over-pressurizing. Wear safety glasses when filling the air tank.
    • 5 Stop filling the air tank periodically and check the tank pressure using an air pressure gauge if the tank does not have one installed. As the air pressure in the tank increases, check more frequently until the maximum amount is reached.
    • 6 Remove the air supply fitting and replace cap.
Jan 20, 2013 | Campbell Hausfeld 3/8" Ratchet
I have a flotec 1 hp pump. Wife washed 3 loads of clothes in a row and noticed we run out of water a while later. I shut pump off and noticed pressure tank low on air. I put 18 lb. air in tank and...
If in the past your system can build-up pressure up to 40 psi even if the supply valve is open and water is being used in your house, then your pump impeller maybe already worn out that's why its pumping capacity was reduced.
Nov 12, 2012 | Flotec Corrosion Resistant Shallow Well...
The tank pressure is 150 Psi but the regulated pressure is 0. I have never used this compressor.
150 lbs is the amount of pressure in the tank. When you connect a nail gun for instance you cannot nail everything at 150 lbs of pressure, it will blast through. The regulated pressure is at zero because you have the ability to regulate it by turn the know under or beside it to increase the output pressure to your desired amount. I was building a shelf last week and set my regulated to 80lbs with a brad and it blew through the panel and stuck in the floor. After you get to know your nail gun you will be able to regulate it between 60 and 80 depending on the type of wood. Panel - 50 lbs, Oak, 90 lbs, etc. Pleas remember to rate this solution high if it was helpful and explained it to your satisfaction.
Jan 30, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Air compress pumps up120 lbs of pressure but will not run the die grinder or air drill
These tools use to much air for your mechine.SCMF and cmf refure to cubic feet per minute die grinders air tools air chucks air sanders ECT. need a larger air storage tank to matain the constant level of PSI to have the tool opperate at max profromance for long periods of time. So there is not realy anything worng except the compresser can't keep up with the air output needs of the tool
Dec 14, 2010 | Air Tools & Compressors
Hi i have a question about car engine, i have a projekt im am building and for that i have a stock 130 hp 2 l 4 cylinder engine no mods or tuning done ion it its just stock, but if i want to have...
it would have to be a high pressure tank to do you much good, 2000 to 3000 lbs pressure regulated down, it would be close to a nitros setup, you'll have to dial in the right manifold pressure,these setups are like a passing gear,top gear, pedal to the metal and hit the air, It's nice to see young folks still out there experimenting, good luck
Jan 19, 2010 | 1992 Saab 9000
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
2-stage air compressor's recovery time takes twice as long
hi is your machine reaching full pressure? if so maybe your problem is with your tool?
Mar 23, 2009 | Air Tools & Compressors
Kicking overloads but not consistantly
First: Most all compessors use check valves at the tank and an unloader to allow the compressor to start without a load. Make sure that system is unloading and that check valve is not leaking causing head pressure at start. Second: Too frequent starts and stops will cause motor to overheat. Check Quincy manual for max starts per hour. enjoy
Nov 14, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Ingersoll Rand (IRTC2545E10VFP) 2545E10VFP Type 30 Fully Packaged (2304603 V) 10 Hp Air Compre Logo
248 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
