GOODMANS LD3761HDFVT TV has stopped working (lost picture) on pc mode but ok on tv and dvd mode
nevillesears
SOURCE: i lost the picture on my Sharp LC-20DV20U LCD HDTV. sound is ok
check your heater voltage coming of your flyback transformer going to your crt board.
Posted on Dec 19, 2008
  • 9 Answers
SOURCE: no picture or sound
Did you double check your connections with your AV cables. Otherwise you may want to try a new cable. Still make sure all connections are tight and secure and plugged into the right ports. If this doesn't work I would suggest call customer service for your DVD player.
Posted on May 28, 2009
kb8dns
  • 494 Answers
SOURCE: Goodmans TV needs re tuning
Very likely that where you are the over the air signals are now broadcast in digital format and you need to by a converter box to use an older television. Check places like Walmart or Best Buy or Radio Shack
Posted on Apr 13, 2010
SOURCE: Toshiba 26 inch lcd tv/dvd combo lost picture
I have same problem with a 7 month old Toshiba 26LV610U LCD TV/DVD combo.
Posted on Jul 12, 2010
taran_2005
  • 10515 Answers
SOURCE: My RCA 32" HDTV LCD
Please shine a very bright flashlight into the screen of the TV when it has sound. Tell me if you can see a very faint ghost like image in the screen.
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 20, 2010
I have a goodmans ld3761hdfvt tv and the red light on the front flashes but wont turn on
how many times does the light flash?but if that is so it sems that yhe tv has a problem in the power supply can be your HOT ...flyback..diode that is attached on to the B+ current or your microchip in your standby power supply.good luck.
Sep 13, 2011 | Televison & Video
Does anyone know the sky remote code for my goodmans GTVL19W17HDF ? please
Hello
Setup codes for Goodmans TV with Sky remote are:
065 064 100 588 285 037 292 544 207 318 363 399 402 515 527 392 371 245 563 297 584 060 103 263 508 063 616 055
527
055
402
563
662
696
652
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 25, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Apr 13, 2010 | Goodmans 15.4 in. LCD TV/DVD Combo
I cannot tune my goodmans gtvl19w17hd tv
If you have sound, then your tv doesn't need tuning. Shine a bright light onto the screen, can you see a very dim picture? If so, your backlight has stopped working. This is almost always due to the inverters failing and can be repaired.
Jan 26, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
I lost the picture on my Sharp LC-20DV20U LCD HDTV. sound is ok
Dec 19, 2008 | Sharp LC-20DV20U 20 in. LCD HDTV/DVD Combo
Hi I bought a goodmans dual format dvd recorder GDVDR319, tuned in fine, plays fine etc but the picture is pink. Instructions say check the video output but no idea what that means. Thanks
If your normal TV pictures are ok then carefully check your scart plugs are pushed right home and fitting squarely at the TV end and the DVD end.
Jun 14, 2008 | Televison & Video
Goodmans Tv wont show dvds
Usually with DVD players, picture & no sound, or sound & no picture is caused by the scart lead not being plugged in properly.
Sound pins are at one end of the connector and audio pins at the other.
If you are using scart make sure that the plugs at both ends are pushed in all the way. The plastic part of the plug should just touch the socket.
If you are using S-Video (Round connector with 4 pins) you also need to connect a twin phono-phono (Red & Black or White) lead to carry the audio, as S-Video only carries video.
Feb 09, 2008 | Goodmans 1475TS 14" TV
Goodmans tv/video/dvd all in one
Perfect picture on TV, DVD and VCR, but no color means you have selected the wrong color system.Since you are in the UK, make sure that the VCR Color system is also set to PAL. Perhaps it is wrongly set to SECAM?
May 04, 2007 | Goodmans 217NS TV
Goodmans DVD Recorder/Freeview Problem
My Goodman's built-in dvd has just gone green and purple on the TV screen,TV is ok but dvd is now just showing the 2 colors,what can I do,
Mar 14, 2017 | Goodmans DVD2100B DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
