Question about Cuisinart DCC-1200 Coffee Maker
Replacing water hose
Is replacing the water hose simple to do? Where can I get the replacement hose?
I just un-clogged my coffee-maker, fortunately didn't damage the silicone rubber hose.
But here's a good place to get replacement hose-- or any other ridiculously obscure component-- They don't do appliance parts, just general industrial stuff.
www.mcmaster.com
I didn't measure my hose before I put mine back together, but it looked like about 1/2" ID x 5/8" OD, and very soft, looks like 50A durometer to me. Here's the part # you can type it in, and get to the correct page in their catalog.
5236K38 $1.26 per foot- you might have to buy a whole foot and cut to length -should be easy with scissors-- opaque red (but you can get any color) CHECK the SIZE FIRST. Most of the cost will be in the shipping. You could also call up a local distributor of industrial supplies/or maybe a general appliance parts store, but they often have minimum orders.
Posted on May 15, 2008
Thank You BillCin-CO
Posted on Apr 09, 2013
Water doesn't enter into washer after turn power
"Usually" a simple fix. There a hot/cold/warm solenoid switch that is actually the part where the hoses connect. Now, depending on the make and model, it's a question of how easy is it to get to and replace ??
some of the simplest ones are mounted to a plate that you can remove from the back and replace making sure you reconnect the wires to the same connections as the old one.
Some of the older models it was as simple as popping the front of the top section open like a lid and raising and removing it, marking the wires on the connections to the solenoid valve, replacing it, replacing the wires to the proper connections and replacing the top...
Nov 05, 2015 | Danby DDW2406 Stainless Steel Built-in...
Water is filling the tub when not in use
The machine's fill valve needs to be replaced, it is no longer closing (shutting off) completely.
This is a fairly simple repair, you won't need to remove any panels from the machine other than the small one to which the valve is attached.
In the meantime, you'll have to manually turn the wall valves on and off whenever you need to wash clothes. Don't forget to turn the valves on BEFORE starting a cycle, or you may toast the fill valve completely.
In my experience, I've had the replace this valve about every four years, but it is a simple repair. While you're at it, you might consider replacing the water hoses as well, especially if they are the plain rubber variety. Stainless-braided, long-life hoses are now available.
Jan 03, 2013 | Maytag Neptune MAH5500B Front Load Washer
Leaking water sometimes not overheating, is it the thermostat
If the water is coming from your overflow tank or radiator cap, replace them. The seals may have went bad. If the water is coming from a hose connection in the engine compartment, fix the connection. Depending on where/what is leaking it could be as simple as tightening a hose clamp and/or replacing a hose.
Nov 19, 2012 | 2004 Kia Sorento
How do i replace the water pump....3.3 L
first find the water pump for every vehicle ive ever worked on the water pump is always right above the main pulley once you locate the pump unscrew the hose from the pump to the radiator and then take all the bolts off the pump slowly wiggle the pump off so you don't damage the gasket on the water pump then take your new water pump and line it up to the holes for the bolt and put all the bolts back in and then reattach the water pump hose to the pump and to the radiator and then fill the radiator up and your good to go
May 07, 2012 | 1991 Dodge Dynasty
Clothes wont spin dry and water coming out bottom on Maytag LA412
YOU HAVE WATER PUMP NOT WORKING. IT WILL NEED REPLACING.
IT MAY BE AS SIMPLE AS A HOSE THAT IS BROKE OR CLAMP ON A HOSE COME LOOSE, BUT IN EITHER CASE YOU WILL NEED TO PULL OUT THE WASHER, OPEN IT UP AND TAKE A LOOK. IF THE HOSE IS IN GOOD SHAPE AND THE CLAMP IS TIGHT, THEN YOU HAVE A PUMP THAT NEEDS REPLACING.
Feb 20, 2011 | Maytag Washing Machines
Water pump leak
water pump should not leak. It is very simple to replace just google how to replace water pump. first make sure you do not have a pin hole in the hose.
Apr 09, 2009 | 1998 BMW 7 Series
Lots of tiny bits of rubber flakes have comeoff door seal and are stiuck to washing
hi Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
Sep 13, 2008 | Washing Machines
The water does not drain out. Water in tub bottom
Sep 13, 2008 | Amana Dishwashers
BOTTOM DRAIN HOSE LEAK
http://136.166.4.200/contents/Laundry/WM2277.htm
Try that website and download the service manual..
Hope that helps...
Aug 07, 2008 | LG WM-2277HW Front Load Washer
Cuisinart DCC-1200 Coffee Maker Logo
1,199 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
