Question about Intel D101GGC Motherboard
No display when bios setting is normal. but when setting is changed display is com.
    Problem Solver:
  • 16 Answers
Your ciom bettry has been loosepls repalce it then u can set bois setting motherbaord will be give display.
Posted on Aug 30, 2010
Cannot get into set up to check bios
  • 1
    Turn on your computer. If your computer is already on then reboot it. You need to see the initial display screen to get into the BIOS.
  • 2
    Press the "F2" key when you see the initial screen displaying the BIOS provider information. If using the Optiplex and Dimension models, press the "DEL" key instead of the "F2" key.
  • 3
    Enter password if required. When finished in the BIOS be sure to save your changes. For changes to take place you must reboot the computer.
    Read more: How to Get to BIOS on a Dell Computer ' eHow.com http://www.ehow.com/how_4745021_bios-dell-computer.html#ixzz1VDktcHYE
  • If the bios is password protected you will have to dump the bios batter first, then reconfigure the bois.
    Aug 16, 2011 | Dell Dimension 3100 PC Desktop
    What does out of range error means? this error occurs appears after windows initialization
    It means that the Monitor is not able to pickup the Display signal of your Computer's display settings. Most probably the resolution of your display settings is higher than what the monitor supports. Boot into Safe Mode and make the changes with your display settings and then reboot it normally. That should help you fix it. Sometimes resetting the Bios settings does help. Let me know if you need further help.
    Good Luck.
    Jul 15, 2011 | Computers & Internet
    Hello, last week I change the partition of my fujitsu E8420. and now there's no OS on it. I want to install Windows XP, but it always show a blue screen said that there's problem that Windows...
    YOU NEED TO FORMAT YOUR HARD DISK THROUGH PARTITION MAGIC PROGRAM
    OR ANOTHER PARTITION PROGRAM
    DOWNLOAD IT FROM INTERNET AND COPY IT TO A CD OR USB FALSH
    THEN TREAT YOUR HARD DISK WITH IT
    May 13, 2011 | Fujitsu LifeBook E8420 PC Notebook
    I have an IBM ThinkCentre S50 PC Desktop 8183... problem is that the BIOS wont load or save default or customised settings so I cannot change the boot order to load OS from CD... I have removed the CMOS...
    Regarding settings not saving
    You mention that you removed the CMOS battery... You normally need a working CMOS battery [one that is not flat] for the computer to be able to remember changes to the BIOS settings.
    Regarding BIOS being in Spanish
    I would hope there would be a language option somewhere in the BIOS settings where you might be able to select English as the display language.
    Nov 08, 2017 | IBM ThinkCentre S50 PC Desktop
    Green display on boot up Please help
    Check to see that there are no machine BIOS settings that could affect the monitor. Normally, the bios controls display until the OS takes over. If your XP screen after bootup looks fine, I don't see how you have a problem with your monitor setup under Windows.
    Jul 03, 2009 | Computers & Internet
    My ASUS P5SD2-VM Is Having A No Display Problem
    If you are using the motherboards built in VGA graphic display, check your bios settings. Open your manual to page 2-22. Read the page.
    Make sure you have the bios set to, Primary Graphics Adapter [PCI-E] set to, [IntVGA].
    Set the internal VGA to, [Enable]. You will also need to set an amount of your system memory for the VGA to use. It is recommended if you are using Windows Vista that you increase your 1GB of system memory to, 2GB. Or instead you can buy a decent PCI-E video card that will use its own memory instead of your system memory. If you do this you'll need to change the bios settings to, Primary Graphics Adapter [PCI-E].
    Also change, Share Memory Size to [Disabled].
    If you need the manual for the Asus P5SD2-VM. Click on the link below;
    http://support.asus.com/download/download.aspx?modelname=P5SD2-VM&SLanguage=en-us
    Click the dropdown menu & click on your operating system. Than click Search. Asus list all drivers, manuals, FAQ's ect.
    To view the manual you'll need Adobe Reader. You can download Adobe for free at this link;
    http://www.adobe.com/products/reader/
    Again, if you do not have any display & your using the built in VGA graphics card try resetting the bios. Doing this will reset the bios back to normal default settings. The bios will auto use the built in VGA. To clear the bios see page 1-22.
    Mike
    Apr 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
    Ok i have a emachine c2280 we put a new power supply changed the ram and i have no video, there is also a red light next to the ram what isit..
    Anytime. Just in case you there is any way you can get video to display. There is a setting in bios to change what controls the display adaptor. You might want to try to reset your bios and see if you can change this setting. Figure there is nothing you can hurt at this point.
    Just remove the "watch battery" that is on the motherboard for a couple minutes and try to start the computer. Also you might want to look for some pins on the board that say something about bios reset jumpers. Normally you short the two pins then remove and boot. Sometimes you short-boot-shutdown-unshort-boot again.
    I'm thinking though if you can get in there you can set your display to pci or agp or whatever kind of video card you have.
    Jan 29, 2009 | E-Machines eMachines Desktop PC
    BOOTING ON MAINTANANCE MODE BUT NOT ON NORMAL MODE
    Clear your bios, remove your all pci cards & then try.
    Feb 23, 2008 | Intel D845GVSR Motherboard
    Your CPU had a problem
    TRY TO RE SET THE CMOS BATTERY
    Dec 18, 2007 | Albatron Nforce2 (KX18D PRO II)...
    Asus A8N SLI RAID showing both drives as "degraded"
    This problem usually occurs if: 1) The computer never finished booting 2) A sticky button on you keyboard (F8 or Control Key for win98) 3) Less Memory for windows xp and ME. Try checking if all the memories as well fixed on the board and are being read. 4) Corrupt system files. 5) Incorrect bios configuration (Try changing the bios settings to optimum performance of fail safe to confirm that. All the best.
    Aug 25, 2007 | ASUS A8N-SLI Motherboard
    Intel D101GGC Motherboard Logo
    47 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
