Question about Iomega Computers & Internet
My IOmega 500GB HDD worked excellent when one day it fell off from my bed (2 feet high). Since then, the drive wont function normally. The read/write speed is terrible.. The company claims it to handle falls upto 5 feet.. Please advice
  • 903 Answers
Whatever you choose to do, the first thing you should do is back up all of your data immediately, in case the drive completely fails and you can't get to it.
Do you have a warranty on the hard drive? If so, you should send it back to the manufacturer after advising them of the 2-foot fall and have them either repair or replace it.
In case the problem is not actual damaged parts, you can run Scandisk or Chkdsk in Windows or DOS (with all of the options checked) to inspect and repair the drive and hopefully improve its performance.
Posted on Aug 30, 2010
Hi there. I have a 500gb Iomega Prestige external HDD. I was in my external HDD files, moving some photos from one file to another (nothing I haven't done a million times before). When I moved one...
you could run the chkdsk utility
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
hope this helps
Jun 07, 2011 | Iomega 500GB Prestige USB 2.0 Portable...
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
Feb 28, 2011 | Iomega eGo BlackBelt Portable Mac Edition...
Hard drive fell can't read info
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 13, 2010 | Iomega 34512 eGo USB 20 500GB Portable...
My new Dell computer will not recognise my iOmega external hard drive - both are still under warranty. I have spoken to Dell who have referred me to iOmega - I cannot get in touch with iOmega to speak to...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Aug 27, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have a new 500GB Iomega external harddrive. It is now loaded to near capacity with films etc. When I plug it into my USB port on my Sony TV it does not seem to be recognized. When I plug it into my...
1. The TV and drive may not be compatible with each other. 2. The formatting of the drive could be the problem. The USB memory stick would be formatted as FAT32, but the Iomega drive would have been formatted as NTFS. Maybe the TV can only read drives formatted as FAT32 and not NTFS.
Jun 28, 2010 | Iomega 34512 eGo USB 20 500GB Portable...
I have got a 500gb iomega hdd. I have got it plugged in to my laptop but my laptop will not reconise it. It has a blue power light flashing on the front. I have also tried it on the home desk top and its...
I had the same problem with my external hdd. I had installed Paragon disk management suite 2009. I ran the program with my hdd plugged in and after sometime(15 minutes) i found my hdd was recognised and working fine. Try it. How it worked for me have no idea but it somehow worked.
Dec 30, 2008 | Iomega (33654) Limited Edition 500 GB USB...
Seagate Barracuda 7200.10 Not being recognized
Clicking is not good. You need to contact IOMEGA SUPPORT on their web site and run through the troubleshooting steps then call for possible warranty action. The clicking is consistent with a failed hard drive. If you can remove the hard drive to read the part number and serial number, contact SEAGATE on their web site and go through the troubleshooting procedure for a possible warranty replacement. All hard drive manufacturers will cheerfully replace drives still under warranty if you carefully follow their procedures. Good Luck!
Feb 23, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
LaCie Mobile 500gb not working
Just buy new external ( HDD ini is fine) just change the external for both off you
Dec 28, 2007 | LaCie Design by F. A. Porsche 160 GB Hard...
Computers & Internet Logo
64 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
