Question about Kyocera KM-1505 Copier
C-7 980 error code
Our photocopier, Kyocera KM-1500 is displaying this error code. Can you help me?
We have the same problem with our KM-1500 but cannot find the waste toner bottle. Can anyone help please?
  • 2 more comments
  • martinlaw May 08, 2008
    Yes, I understand what the code means. What I don't know is where to find the waste toner bottle. Can you help please?
    Yes, but where is it?
  • Anonymous Mar 19, 2014
    Can't fine the waste toner bottle on the Kyocera Mita model #KM 4530.
    Where is the waste toner bottle on a Kyocera Mita Model KM 4530?
    Sergeant:
    Champion:
  • 304 Answers
The waste tank of the copier is full, the only solution to this is to replace and fix the problem on the waste tank of the refill..
Waste tank is where the spoiled ink go..
Thanks.
Posted on May 08, 2008
    Sergeant:
    Novelist:
  • 166 Answers
Hello there.
That error means that there is a problem with the waste toner bottle either being too full, which means that it must be either emptied or replaced, or that the sensor that senses the amount of toner is defective.
You should have got an E-31 code in conjunction the C-7 980. the only thing that you can do is change the waste toner bottle, after that you're going to have to get technical help in person.
Hope this helps.
  • Ryan Harron
    Ryan Harron May 08, 2008
    Hello there, please click here to find pricing information on your toner. Alternatively if you want to pick up some locally to you, you need to tell the sales assistant you wish to buy some:
    Kyocera Mita FS1020D , KM1500 Toner ( TK-18 ) ( 370QB0KM )
    Hope this helps.
  • Ryan Harron
    I forgot the web address, sorry, its http://www.nextag.com/Kyocera-Mita-FS102...
    Genius:
  • 3,587 Answers
Ok..so you have two kyoceras with issues...let's address the error code first..do you have the users manual handy? It's usually in there. I'll check my reference on that, and also look into the waste toner bottle..
  • 3 more comments
  • Patrick Michaels
    Patrick Michaels May 08, 2008
    fascinatingly , that model does NOT appear on Kyocera's support site..can you confirm please? KM 1505
  • Patrick Michaels
    it's inside the unit. access is through the side panels. usually this is performed by service folks. and it can get messy too
  • Patrick Michaels
    straight from Kyocera's site..check this out
  • Patrick Michaels
    thankya for using fixya
  • Patrick Michaels
    thankya for the Fixya...and bows to all the other worthy experts..sure would be good to share a fixya with others, would it not?
  • Kyocera Master
  • 13,433 Answers
can you give us the error code?
waitin for your reply.
  • Ekse May 08, 2008
    Oh its on the title? c-7 890 error code?
  • Ekse May 08, 2008
    posted on Oct 11, 2007
    CopierOne
    Rank: Wiz
    Rating: 91%, 25 votes
    That code indicates that there is a problem with the waste toner bottle either being too full, which means that it must be either emptied or replaced, or that the sensor that senses the amount of toner is defective. You should have got an E-31 code in conjunction the C-7 980. the only thing that you can do is change the waste toner bottle, after that you're going to have to get technical help in person.
My photocopier km 3060 displays error code c0120.what is the problem and the solution
Hi
I have found a list of error codes at the link below and your code is described as;
Drum EEPROM error Reading from or writing to EEPROM cannot be performed. Poor contact in the connector terminals. Defective drum unit. Error Codes Kyocera Mita KM3060
It looks therefore like a drum unit problem which probably requires a replacement drum unless you can check and improve the contacts in the connector terminals.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Oct 17, 2014 | Kyocera Km 3060 Digital Copier With...
My Kyocera KM 1635 / 2035 displays error message: error call 600
Needs a service, either call your photocopier service company or find one on google.
Mar 19, 2012 | Kyocera Office Equipment & Supplies
I get an error message on my photocopier Kyocera KM-1500 Error C-06
The code 6 is a 'fuser' error code. It means that their are defective parts (like a blown lamp or thermistors/fuse, etc. It will require service.
Sep 24, 2011 | Office Equipment & Supplies
Erreur c7 980 kyocera KM-1500
Waste toner reservoir overflow
probrem (when the total number of
copies is less than 100 thousand
sheets)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds 5
g.
Jul 21, 2011 | Kyocera KM-1505 Copier
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
Can not find the waste toner bottle on km 1500
Hello sir; Open the front door, on the left handside have a white plastic box just next to the toner cartridge.
Sep 30, 2009 | Kyocera KM-1505 Copier
Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
May 26, 2009 | Kyocera KM-1505 Copier
Kyocera mita error codes of KM 1500
Hello sir; The error code you display A3200 is not available in our menual, we do have C3200 , if that's correct, it means exposure lamp burn out ( not on), replace it, or thermos fuse out.
May 13, 2009 | Kyocera KM-1505 Copier
Error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Mar 02, 2008 | Kyocera KM-1505 Copier
C-7 980 error code
That code indicates that there is a problem with the waste toner bottle either being too full, which means that it must be either emptied or replaced, or that the sensor that senses the amount of toner is defective. You should have got an E-31 code in conjunction the C-7 980. the only thing that you can do is change the waste toner bottle, after that you're going to have to get technical help in person. Sorry. Let me know if this helps.
Oct 11, 2007 | Office Equipment & Supplies
Kyocera KM-1505 Copier Logo
1,006 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
