Question about Goodmans W280NS Television
My Goodmans X-Pro 42" plasma TV got turned on and off at the wall socket several times in short succession. The picture now consists of nothing but fuzzy vertical coloured lines. The sound is still ok.
  • 4 Answers
Common problem, one of 2 boards.......I have same problem but cannot find a fix......according to the crack the boards are foreign and are no longer available :(
Posted on Sep 26, 2010
Tv won't come on tried all the trouble shooting ideas in book but nada
hi if you brought the tv in november might best to get in contact where you got it from ask them to send a tech out, you won't have to pay as it should be covered by the warranty good luck
regards
shaun
Jan 23, 2014 | Universal 40-42 Inch Flat Screen Panel...
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
My Pillips 42" TV works
Is this a plasma TV? I have worked on several of these. Please provide the model number so I can better help you.
Mar 23, 2011 | Philips Televison & Video
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
50" lg plasma tv will not power up
The problem with the set is bulged electrolytic capacitors in the power supply.
May 16, 2010 | LG 42PX5D 42 in. Plasma HDTV
I hace a pc cab i connect it to the goodmans x pro
Cant see why not if you have a VGA (usually blue 15 hole (3x5 rows) connection on the Plasma TV, it should be ok. Connect the VGA cable to your PC and then to the TV, then power both up, Search through you TV Sources till you find VGA or sometimes AUX and you will see your PC booting up as normal. Also you might want to put sound to the tv too, in which case you'll need a 3.5mm jack lead at one end (into the sound card Green Jack Socket), to what ever the sound input is on your TV, usually the same 3.5mm Jack. If you want to still use your PC monitor too, you will need a VGA Y splitter, only a couple of quid off ebay, and another VGA cable, about the same price. Hope that's of use to you.
Dec 06, 2009 | Archos AV 500 400-Hours Video Recorder
I have a panasonic onyx 42 xvs30 plasma. Will not turn on. Moved from my sons home. Is there a card that is supposed to be in the media box? Blue light turns on for 2 seconds and then goes off quickly. It...
hello, make sure your ac power is correct as far as gounding and proper polarity.
some homes are wired incorrectly and the tv wont operate like this.
first step is to check your sockets with a (ground fault tester) its a small plug in unit with led lights that indicates if there any electrical fualt in your power lines.
if it isnt your wall sockets then it is inside your tv set. the media slot is for a media card it shouldnt have anything to do with your tv working or turning on.
if your not able to see a welcome screen menu when you turn it on, this indicates a shut down circut or power issue.
you may want to find a tv service center to check it for you
this is your best chioce.
hope this helps
Dec 22, 2008 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
LG 50PC5D 50 Plasma Won't turn on
If you check underneath the t.v there may be a button that you need to push. then you can use the remote to turn it on. took about 2 hours before I found it.
mine is located on the bottom left, right underneath the screen.
Dec 26, 2007 | LG 42PX5D 42 in. Plasma HDTV
I'm trying to connect my Wi i with my goodmans tv/dvd
it can't becoz it is not the desired model
Oct 17, 2007 | Nintendo Wii Console
Televison & Video Logo
347 people viewed this question
Top Goodmans Televison & Video Experts
Raj Patel
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
