I have a flickering yellow line on my laptop screen.It shows up once every 5-7 mins or so. My laptop is just 2 months old and i have hadled it delicately. What is the reason for the appearance of the yellow line and how can i solve the problem?
    Scholar:
  • 166 Answers
Such occurrence can be due a to defective LCD (inverter, flex cable or the LCD itself). On the other hand it can be cause by a faulty video graphic card. Try connecting an external monitor and let me know of the outcome. Thank you and regards.
Posted on Aug 30, 2010
Yellow screen hp dv6000
The screen is faulty or the screen cable has become dislodged. Best take it to a repair shop.
Oct 12, 2017 | HP Computers & Internet
FLICKERING AT THE BOTTOM OF LCD SCREEN
On a 3 month old laptop don't even bother finding out why just get it back to get fixed under warranty. The flickering can be from several things but unless it has been damaged there is no way you should have any problems even small ones with that new a laptop.
The flickering can be a bad connector or power problem which you might see on a 3-5 year old tired laptop but definitely not acceptable on a new one.
Sep 26, 2009 | Gateway NX560X Notebook
The screen on my dell inspiron nootbook started flickering last month, two weeks ago it started to turn completely dark at times and today 3 min after i turned it on a blue screen popped up and it told me...
windows dose not control any flickering unless the driver is being updated if thats not the case your flourecent bulb might be getting old inside the lcd!
Aug 29, 2009 | Dell Inspiron 1525 Laptop
My tv is 2 years old and in the last month or so in the middle of a show the screen will go black and a red line runs down the middle and it lasts for about 5 min and a little pop sound and the picture...
It appears you may have had a line collapse caused by a poor connection in the line output stage, it would be a matter of resoldering around this area. Now that you say it will come on could indicate that a component has now failed as a result of the line collapsing, more than likely the line output transistor has now also failed & would need replacing.
Jul 01, 2009 | Jensen Q2749J 27" TV
Vertical lines in my laptop screen
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Aug 11, 2008 | HP Pavilion dv8000t Notebook
BSoD, Garbled Screen, Boot Failure.
If you are getting garbage on the screen before windows tries to load the laptop probably has a bad motherboard.
It's possibly only the video output is going bad on it, try hooking it to an external monitor and see if you get the same weird stuff on that screen.
Good luck, let me know how it goes
Nov 15, 2007 | Compaq Presario X1000 Notebook
Flickers on cold startup after 5 min then goes away in 2-3 min.
I had same problem. Tech's said the power was noisy. I cleaned up the power but the TV still did exactly as you describe. Problem will progressively get worse with longer bouts of flickering. I was under warrenty and sent the TV back. After 3 months I am still waiting for a repalcement.
Jan 12, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
