RCA, 52", 16x19 HDTV Projection Monitor, serial #D52W20BYX1E222C30FT won't turn on. When I push power button green light powers on blinks once then blinks eight times and that process just repeats
  • 1 more comment
  • Rey Garza Sep 02, 2010
    thank you for answering . the tv when powered blinks once then eight times . it does it continiously 1 then 8 any idea where i could get the fault codes for this tv
  • Rey Garza Sep 06, 2010
    RCA, 52", 16x19 HDTV Projection Monitor, serial #D52W20BYX1E222C30FT won't turn on. When I push power button green light powers on blinks 1 then blinks 8 times and that process just repeats 1 then 8. Anybody know where i can find fault codes
  • Rey Garza Sep 08, 2010
    awsome.. thanks for the codes will get back with results.
  • 5,807 Answers
Initial thing to do is check if the Flyback is oscillating.
if it does then check for bad capacitors on the Deflection
Board later.
Posted on Sep 06, 2010
  • 8 more comments
  • Rommel Cana
    Rommel Cana Sep 06, 2010
    here are the fault codes:
  • Rommel Cana
    continuation:
  • Rommel Cana
    you can try these out:
  • Rommel Cana
    continuation:
  • Rommel Cana
    If you need parts :
    like communication cables and the the likes :
    http://www.partstore.com/Model/Thomson/R...
  • Rommel Cana
    Additional info:
    The +1.8Vs voltage is the main supply for the main microprocessor, IR001.
    Without it, nothing will fire up
    If missing, troubleshoot the Standby Power Supply.
    Once the +1.8Vs supply has been confirmed as operational,
    check the clock (pin 6)
    and data (pin 5) lines to the main NVM, IR005.
  • Rommel Cana
    hope these answers your blinking once and 8 times.
  • Rommel Cana
    Rommel Cana Sep 08, 2010
    On some they have resoldered the
    Flyback pins , if power
    supply and the microprocessor is working
    here is a sample image:
  • Rommel Cana
    Might as well check your communication Cables
  • Rommel Cana
    Good luck to you and regards
  • 2,335 Answers
I can help you with your RCA projection television problem.
Eight blinks is most likely a solid-state power supply fault. This means your TV can no longer supply the high voltage required to project your TV image. Service by a technician is required unless you are handy at solid state component replacement.
I hope that helps.
Posted on Aug 30, 2010
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Does the monitor shows any standby light or does it give any sign of power entering into it?
If there is no standby light at all on your Monitor, then it means your Monitor is having a power problem. The power supply board is defective that's why the Monitor won't power up. Its receiving power but it cannot transfer the current to the necessary part of the Monitor because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the Monitor might not come on.
If you know about Monitor repairers, I would suggest that you open the Monitor and read the power board/panel with a meter, detect the bad component and replace it. Take note that Monitor stores a lot of current that can shock just like TV, so leave the Monitor for a while before you open it.
If you don't know about Monitor repairers, take the Monitor to the nearest repairman to fix the fault for you.
I wish you good luck.
Jul 29, 2010 | Dynex DX-L42-10A 42 in. LCD TV
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
Won't turn on after reset ws-55511 hdtv
YOU GOTTA REPLCE THE STK ICS OR THE CAPS ON THE DM BOARD
Jul 18, 2009 | Mitsubishi WS-55511 55" Rear Projection...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Flashing green power light on TV
have the power supply checked out sounds like it went out
Jul 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
