Question about Equator EZ 1500 Front Load Washer / Dryer
Spin problem suddenly stopped extracting water during spin
    Problem Solver:
  • 4 Answers
Try..empty machine and check if filter is blocked or pump may have developed a fault
Posted on May 08, 2008
I have a Whirlpool duet front load washer model # GHW9150PWD. I have an error code of F 02 and SUD. I have so far cleaned the filter and the lines, replaced the pump, replaced the water pressure swith and...
6 - 1
DIAGNOSIS & TROUBLESHOOTING
SUDS DETECTION
During Drain Routine
During the Drain Routine, the water level is checked continuously. Normal drain will occur until the
pressure switch senses no water in the wash tub and there is no foam (suds). The drain pump will
operate an additional 15 seconds after the pressure switch reports no water or foam.
If the drain routine operates for four (4) minutes and the pressure switch senses any foam (suds) in
the wash tub, the Central Control Unit will start the "Kill-Foam" Routine. (See description of this
Routine below.) After the Kill-foam Routine is concluded, the Drain Routine will restart. If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
During Spin (Extract) Routine
During the Spin/Extract Routine the water level is checked continuously. If, during this routine, the
pressure switch senses the presence of foam (suds) in the wash tub, the Central Control Unit will
stop the drive motor and the basket will stop spinning. The electronic control will count the number
of spin repetitions that are attempted due to foam (suds). There are a maximum of three (3)
attempts for each Spin/Extract Routine.
Kill-Foam Routine
1.
The Remaining Time counter is stopped.
2.
The digital display shows Sud.
3.
The Drain Pump is turned OFF.
4.
The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5.
While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6.
Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
movement for five (5) minutes.
7.
After the five (5) minute rest, the remaining time counter will restart and the digital display
will show the remaining time left in the routine.
NOTE:
If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
will be reduced to a cycle of 3 sec. ON/13 sec. OFF. If, at the end of either the Drain or Spin/
Extract Routines, a suds condition still remains, the digital display will show Sud.
Sud will also be displayed for a short period at the end of a cycle, if a Suds condition was
detected during the cycle. This will alert the consumer to reduce the amount of detergent in
subsequent uses MANUAL
Oct 31, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine stopped and says "sud". What does that mean?
SUDS DETECTION
Kill-Foam Routine
1. The Remaining Time counter is stopped.
2. The digital display shows Sud.
3. The Drain Pump is turned OFF.
4. The Central Control Unit will fill the wash tub with 1 gal. (4 L) of cold water.
5. While the tub is filling the basket will tumble 1 sec. ON/15 Sec. OFF.
6. Once the tub is filled, the drive motor will turn OFF and the basket will rest without any
7. After the five (5) minute rest, the remaining time counter will restart and the digital display
NOTE: If the Kill-Foam routine was initiated during a Spin/Extract Routine, the tumbling action
subsequent uses.
Oct 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
WHY DOES MY WATER PUMP, ON MY BOSCH NEXXT 100 SERIES, RUN LITERALLY ALL THE TIME DURING SPIN. THE PUMP REMOVES WATER AS IT SHOULD, BUT JUST KEEPS CAVITATING AS IT KEEPS RUNNING. I CAN TELL IT KEEPS...
Welcome to FixYa.
Completely normal. The pump will indeed run through the entirety of the spin cycle, it is by design.
As the items spin, more and more water is extracted and if the pump should fail to operate during this time it would cause increased vibration and inadequate extraction to achieve it's superior spin cycles.
Hope that helps quell your concern. Let me know if I can assist you further.
Thanks for choosing FixYa. Please take a moment to rate the info provided here today.
Regards,
Macmarkus :)
Sep 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Thumping sound when the water turns on or off? during a normal cold cycle, we especially hear it during the spin cycle. It's not the spinning action it's the water turning on or off that makes a pretty...
Sounds like you are experiencing "water hammering". When the water valve shuts off quickly, the water which was flowing in the pipe must stop, and the momentum of the water suddenly stopping can cause the pipes to rattle or bang. Adding an air chamber would cusion that, and eliminate the banging. I have seen some (at a local Home Depot) which can screw onto the hose right where it connects to the hosehold shut off valve behind the washer.
Feb 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Washer 110.24992300 spin problems
The pressure switch is mis-reporting the water level to the ECU.
Test/replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
During short spin cycles between rinses it doesn't pump water out
Try looking to see if the little motor is spinning the drain pump. It is in the bottom right. Occasionally I get a small metal shard which locks the pump and therefore-no draining. You can undo everything and check the pump for blockage. Then if need be, replace the mechanisim. The parts are all on line, as is the manual. or call 800 776-3538
May 11, 2009 | Equator EZ 3600 CEE Front Load Washer /...
What does the max extract feature do
If the washer is removing all of the water from the washer during the spin cycle it is likely working properly. Not an expert but I believe max extract causes the washer to spin for a slightly longer period of time in order to remove more water from the clothes. We use it regularly because our clothes come out to wet otherwise.
May 03, 2009 | Maytag Neptune MAH6500A Front Load Washer
Pump not stopping
If you have to bang the float to stop the the float switch is not working correctly.. you may have somthing holdig it up or the switch itshelf is failed...
Sep 24, 2008 | Bosch 24 in. SGS43C12 Classixx...
Washer spins but not enough to extract water from clothes or tub.
could be a loss belt or a kinked hose, since you say it feels weak i would think it is not getting up to speed which would be a loss belt or drive train issue, of course it could just be to big a load or on slow spin speed setting
May 22, 2008 | Washing Machines
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
Equator EZ 1500 Front Load Washer / Dryer Logo
73 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
