Question about Cobra 148 GTL 120-Channels Base CB Radio
On rx , i have a low carrier , sometimes cannot hear someone vs another radio
I own a cobra gtl ; it was modified years ago. for other channels . so when i had it hooked up years ago , as i do now, same problem. its not the hook up or antenna. because when isubsutute w/ another radio ; the other radios recieves well .i know its in the radio. i can hear some one w/ a 4 carrier , noise level at 1-3 . where the carrier should be at a 9 noise level at 1-3 ?
    Scholar:
  • 67 Answers
Depends on how it was modded? Were both the TX and RX broadbanded and tetuned?? Possibly poor work..
Posted on May 25, 2008
148 gtl cobra cb radio and the rx/tx light stay on
This sounds like a problem with the MB3756 Regulator IC. It controls voltage regulation and TX/RX Switching. It is a common failure in these radios. Check voltages with schematic that can be found at
CB Tricks Home Page
Sep 02, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Way low modgilation compared to the strong carrier on my 150 gtl
could be a bad mic cartridge or your radio needs to be tuned for more swing. Is it a power mic ? If so try changing the battery.
Jun 11, 2009 | Cobra 150 GTL DX Base CB Radio
I have a 148f gtl with no rx on am only,just noise.tx good and rx on side band fine,also tx on am. thanks ,bocephus
Check xtal X1 (7.3450 MHZ). It's in the am osc. I had exactly the same problem. I live in a highly corrosive coastline area
Apr 11, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Low dead key on my radio
If it is a 142 GTL your A.M. power is VR6 . Good luck and be carefull and DON'T get carried away remember AT YOUR OWN RISK NO LIFE GAURD ON DUTY!!!! You should'nt have any problems though......Dan
Apr 01, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148fgtl low power on am/ssb no swing all finals ok
try adjusting the L36,L38 to the highest reading on the external meter and then adjust VR10 TO 4 watts. If this doesn't cure the problem, you have a weak final transistor. Good Luck
Feb 06, 2009 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL steady tone though speaker
try rerouting your coax cable and make sure it's long enough
Jul 07, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 2000 gtl
cobra 2000
am carrier 4.4 volts will not ajust...ssb carrier will 3.5 volt will ajust but max out put is only 3.5 volts.losses all voltage at ssd carrier when switched to usd r lsb
Jul 03, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Can not recieve properly
IN your CB there are 25 tuneing slugs (square matal cans with
ferrite tuneing slugs) if you speaker output is low leavel but still
clear and free of hash the set should be ok , but you will need to tune these slugs with a small jewlers screw driver (WITH GREAT CARE) as the slugs break easy. If you want to email me it will not be a problem ,cheers , DENNIS FLYINGFOX@PEOPLE.NET.AU
May 08, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Mounted on the circuit board is a tiny black encased rx/tx
changeover relay. It is almost in the center of the board and one third to the left (facing the controls) and may be etched MRATA.
I would be looking at that. These sets are subject to a lot of problems as they age and can be fixed with a BIG HAMMER!!
CHEERS flyingfox@people.net.au
Cobra 148 GTL 120-Channels Base CB Radio Logo
100 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
