I have TV Model #DS27425. Does it have a built in digital tuner, or will I have to buy a box to be ready for HD TV? Thanks. daisypc@insightbb.com
  • 4,234 Answers
This particular set does NOThave a digital tuner. However, if you have cable or satelite, a converter will not be needed. Only if you use an external antenna will you require a converter box.
Dan
Posted on May 08, 2008
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
Idk if my tv is digtal ready it says its hd
The TV will provide an HD picture with a set top box connected to the HD input (AV4 or AV5). It does not have a digital tuner (only a NTSC analog tuner).
The manual is available here: http://download.p4c.philips.com/files/5/51pw9303/51pw9303_dfu_aen.pdf . See appendix B on page 58 for the specifications.
I hope this helps.
Apr 19, 2011 | Philips 51PW9303 51" Rear Projection...
How do I get my tv to scan the digital channels? I have used the channel scan and it will not let me scrowl over to scan them . I do not have a digital box but was told that this tv has one bilt in.
Hi
Although your TV is hd ready, it does not come with a digital tuner built into it.
You will have to add an external tuner box to receive digital broadcast stations.
I don't suggest getting one of the cheap ones, as the only provide an SD signal at 480p, clear compared to old analog tv, which was usually 320, but still a far cry from 1080p.
A good tuner box should only run around 60-70 dollars or so, and the picture quality will amaze you on your 51F510.
The tv has a 1080p engine built into it, so if it receives an input with a 1080 signal, it can display it properly.
Cheaper boxes may only offer 720p as it's highest definition output, so get the better box.
You can find them at all major electronics stores, like Fry's and Best Buy.
Hopefully, you do get a digital box for your set, it would be a shame to not get the most out of what is arguably the best quality rear projection tv that was ever made.
I hope this helps you out.
Feel free to give me a top rating if I helped you out, it helps to keep my status up on Fixya.
Thanks, and have a good day !
Apr 07, 2011 | Hitachi 51F510 51" Rear Projection...
If i buy a full hd tv,instead of hd ready,can i view HD PROGAMS from outdoor arial without anymore setup. thank you A R SHEARING.
You do not want to buy HD ready (ready means it will accept HD sources), Ful HD TV will have ATSC digital tuner for off the air signal, you will want it to have QAM tuner also so if you decide to get cable, you can get unencryped HD programs without using the cable box (that is what I am using with my Entended BASIC Comcast cable without using/renting their box, Comcast gives three free boxes, then you have to rent the rest if you have more than 3 TVs at about $7 a month).
Nov 19, 2009 | Televison & Video
Is my Hitachi 60V500A tv digital ready for local tv? or do I have buy one of those digital convertor boxes.
You do need a separate HD Receiver, HD Satellite, and or HD Cable Box to receive HD. It only has a Standard NTSC Tuner built in.
I hope this helps,
Sky Assoc
Oct 28, 2009 | Hitachi 60V500 60" Rear Projection...
Toshiba Tv - Does it have a digital tuner?
That unit has a NTSC tuner. May be HD Ready but it does not have a digital tuner. Unless you live quiet close to a local Broadcaster, rabbit ears would be useless.
The only way you would be able to get HD is using a HD Set Top Box, HD Satellite System,
or HD Cable BOX, using the Componet or HDMI inputs.
Hope this helps
Skyassoc
Jun 22, 2009 | Televison & Video
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
I have a Samsung LCD HDMI 37inch TV series 5 do I need a set top box
You have a really nice TV, you have a built in ASTC tuner(digital).
If you want to recieve OTA(over the air) signals, all ypu will need is an antenna.
Visit this site for some great info on digital TV.
http://www.antennaweb.org/aw/welcome.aspx
Let me know if I can provide further assistance
Please rate this solution.
Lone99star
Apr 16, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
Ready for nat'l digital transition?
If it is an older model (i couldn't find anything on it either), it most likely does NOT have a QAM tuner. Be aware that only the "un-encrypted" cable channels will be free otherwise you will have to buy or rent the digital box from the company to get the rest of the regular digital channels. The un-encrypted channels are like 71.2, 83.7 so you should know if you are getting those or not.
May 23, 2008 | Recoton Advent Advent HT3251A TV
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
