On my F&P Kelvinator Smart Drive 085, I turn the power on, programme the cycle and press Start. The water flows in fits and starts approx 1/2 second on 1/2 sec off for 35 seconds , then stops and shrill alarm bleeps til i switch power off. I gather from reading other cases this is likely to do with the lid/balance reed switch. I'm not clear as to exactly where this switch is and what I can do to repair it?
  • ironnik Sep 07, 2010
    Thank you for that advice. I noticed the connection filter was clogged as well and considered that this may be the trouble, but while cleaning it out unfortunately I've made the problem worse by breaking the bit that connects the hot water line to the machine, and now there's no activity at all. Do both the hot and cold lines need to be attached and/or is there any way to bypass this?
  • ironnik Sep 08, 2010
    Hi, thanks for your advice.
    I've made my problem worse now by snapping the plastic bit that connects the water line to the washing machine whilst clearing out the filters! It would seem I need both hot and cold lines attached for the machine to go at all, is there any way I can bypass that or will I need to purchase a new hoseline?
  • 11,896 Answers
There is a plastic piece on the lid that goes down inside the machine where the switch is. This switch could be bad. You can remove the wires from the switch and test the switch itself with an ohmmeter to determine if it is bad or not.
If the water starts to fill but stops and doesn't fill the machine up all the way, that could be a bad water valve which can be tested with a voltmeter to see if there is constant power going to the valve. A faulty water level sensor can also cause this and that can be tested with an ohmmeter, it would be behind the tub
Posted on Aug 30, 2010
  • Nate Stansfield
    Nate Stansfield Sep 08, 2010
    That is attached to the water valves. So if you already going to purchase that part, it should come with it.
Kelvinator 085 Smart Drive. Why won't it start?
kelvinator smart drive 085 washing Questions & Answers ...
www.fixya.com > Forum > Tags
smart drive 085 not filling with water when start button depressed Could be the magnetic latch on the lid that tells the machine when its closed you can by pass
Sep 30, 2015 | Washing Machines
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
Kelvinator smart drive 085 washing
Your lid magnetic reed switch could be faulty.
May 09, 2014 | Fisher and Paykel Washing Machines
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
Hey, my f&p smart drive 9 excellence washing machine does not start wash cycle after entering water level etc.... upon pressing the start button nothing is happening any thoughts?
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
May 24, 2010 | Fisher and Paykel (IWL12)
F & P Kelvinator Smart Drive 708 - Faulty power switch and cycles
I have a smart drive 708 that will turn on but won't fill, any suggestions?
May 25, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Bosch WFL 2872 washing machine has just started beeping (3 beeps) at approx 1 minute intervals at end of program until I turn machine off. washer is 3 years old & has never done this before - does it...
A similar thing happened to mine. I think it starts when there is a power cut or something similar mid cycle. The solution (which you would never guess!) is the following:
Select any programme - say 30 Cottons
Press and hold any function button - NOT Start Signal will sound at varying levels - release button when it gets to the level that you want, off in your case. De-select programme Good luck!
Jul 24, 2008 | Washing Machines
Kalvinator smart drive 085 not filling with water when start button depressed
Could be the magnetic latch on the lid that tells the machine when its closed you can by pass the switch just dont open it whilst its going
Jul 12, 2008 | Washing Machines
When filling my F&Paykel washer the water is not a constant flow, it is filling in 'spurts', ie stop/start/stop/start etc...... I have tried cold, hot & warm water, all combinations of temp are...
You most likely have a smart water temp sensor on your machine. It makes sure you have the proper water temp to dissolve your detergent. Even when set to cold, it will add some hot water. It sounds like your machine is working properly. If you feel you are haveing a problem check the water temperatures in your owners manual and then check them with a thermomater in the washer. If they are not correct you may have a bad temperature sensor. Good Luck and I hope this helped. Mca0824@aol.com
Apr 30, 2008 | Washing Machines
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
