Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Upgrading memory from 512mb to 2gb but the memory i have seen says 800MHz yet i have seen somewhere on my computer 533MHz is this something else?also i can go to 4gb would this be to big a step and a waste of money?iam a bit confused and any advice would be welcome.
  • 3,940 Answers
Upgrading to 2GB will have a significant increase in speed, the jump from 2GB to 4 GB will be faster but the additional speed increase will be less than the 512 to 2 GB jump. In my book, get as much RAM as you can afford, for go with 4 GB. THe 533 Front side bus is set by the processor installed on the MB, using 800 Mhz RAM will have no ill effect as it is backwards compatible to 533
Posted on Aug 30, 2010
Testimonial: "thanks for advice and think i will just add the 2gb to the 512mb i have for now then add again if i feel i need to."
  • IQUIT Sep 01, 2010
    NOTE: If you do not install RAM in "MATCHED PAIRS" the system will run in single channel mode. So if you have a pair of 256's and a pair of 1GB modules, that should work ok
  • anthony bartlett Sep 15, 2010
    i have added 2 gb and the difference is unbelievable also it was only 30 pounds and really easy to do
My laptop is too slow even if i am just surfing internet like FB. can the memory be upgradable? up to how many gb?
you can upgrade up to 2GB (DDR2)
Your computer has 1 memory slot you remove the memory and install a new one.
you can use either
2GB 800MHz DDR2 Non-ECC CL6 SO DIMM
or
2GB 667MHz DDR2 Non-ECC CL6 SO DIMM
Jun 22, 2011 | ASUS Eee PC 1000H Laptop
Can I upgrade my Ram on Gateway Desktop . I have 512mb, 2.0MHz. It's a good computer that I would upgrade for a project.
Hello
Number of Slots:4
Slot 1 Slot 2 Slot 3 Slot 4 Each memory slot can hold DDR2 PC2-5300, DDR2 PC2-6400 with a maximum of 1GB per slot.
Not to exceed manufacturer supported memory
Good Luck, and do rate the solution if got help
Dec 24, 2010 | Gateway GT5220 PC Desktop
Acer Aspire ASE571-ED450A configured with 2x1gb My acer is configured with 2x1gb memory. I have two additional 512mb memory chips HYS72T64000HU.3.7-A 512mb 1Rx8 PC2-4200E-444-11-A1. Can these be used in...
The 512MB PC2-4200 DDR-533MHz ECC Unbuffered CL4 240-Pin DIMM Memory Module Mfr P/N HYS72T64000HU-3.7-A will run with you're current 2GB DIMMS.
Cheers'
Mike
Feb 23, 2010 | Computers & Internet
ACER Aspire AX1200-U1510A: What mother board and socket is in this computer? AM2, AM2+, or AM3
you have given the memory chip number and not the computer model the chips you have are 533 MHZ DDR so I would suggest you click on start go to my computer right click on properties and it will list the chip set. here is a web page you can go to to see the memory you have.
acer-aspire-ax1200-u1510a-tower-desktop-memory-1x-512mb-91ad346008-pc2-4200-ddr2-533mhz-unbuffered-dimm-upgrade.html">http://www.memoryupgrade.pro/512mb-acer-aspire-ax1200-u1510a-tower-desktop-memory-1x-512mb-91ad346008-pc2-4200-ddr2-533mhz-unbuffered-dimm-upgrade.html
Feb 11, 2010 | Acer Computers & Internet
Whatis the maximum memory the medion rim2520 pc
Standard Memory : 512MB or 1GB Maximum Memory : 2GB ( 2 x 1GB) Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM
Oct 08, 2009 | Computers & Internet
Upgrading memory card from 512mb to higher memory capacity.
We actually need to know what your motherboard is. You or let us check if your motherboard can support that memory or not.
Please ask if more help needed
Apr 03, 2009 | Intel Pentium 4 2.4GHz 533MHZ 478pin 512K...
Memory upgrade 512MB > 2GB
Thermal problems becuase of inadequate power . Your power supply to be looked into.
Apr 12, 2008 | Foxconn 760GXK8MC-S Motherboard
Pc don't work
I have encountered this the memory modules are not compatable and even if they were you may encounter problems with your computer having fatal errors if your memory is not the exact same brand and type. I always try to match the existing memory or just buy all new when i upgrade.
Mar 26, 2008 | Computers & Internet
Memory module
Your motherboard supports 533MHz memory modules, no more. If you put anything higher in, it will work, but only at the speed of 533MHz, so there's not much point in aiming any higher. Just make sure what you're buying is a DDR2 533MHz memory module, and it's best to get them in increments of 2. If you have 4 slots on your motherboard, get another 2x512MB modules of RAM. If you're running Windows Vista, it might be worth considering 2x1GB modules. I think that pretty much covers your question, if you have anything else to ask, feel free to reply.
Sep 07, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
159 people viewed this question
Alun Cox
