Question about Dometic Rooftop RV Air Conditioner
2005 Jayco 5th wheel-we have been running the ac and it cools great but now and then out of no where the compressor shuts off and the fan stays running. We turn the system off and wait a few minutes and most of the time it kicks back on with no problem. Then after a while -can be hours-the same thing happens again. Help please
  • Dometic Master
  • 6,674 Answers
When this happens, remove filter at ceiling assy and see if there is frost on evaporator coils/fins. That would cause it to kick out until frost is gone, then kick back in. Get back to me, and I'll give you instructions on what may be causing it.
Posted on Aug 30, 2010
I have a Goodman CK18-1B ac unit.outside fan will run for awhile then just shut off, compressor stays running like it should
Are you heating or cooling? If cooling is the compressor overheating? Some outdoor fans run only when condenser reaches a certain temperature. If it is in fact a problem, a capacitor is much cheaper than a motor. Replace the cap, if it fixed it, awesome, if not, you compressor will be happy. Honestly does sound like the motor but go cap first. Best wishes!!
Jul 03, 2017 | Goodman Heating & Cooling
Isuzu max ac good cooling fan running but long drive after compressor off fan off
The fan can stay on after the key is shut off to prevent "hot soak"
Jun 15, 2016 | Isuzu Cars & Trucks
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
A/c compreesr cluth stays on but no cool air
You replaced the ac compressor, and the clutch stays on, but the compressor does not run ???
Not sure I am following your info here.
If the ac clutch stays engaged the compressor should be running. You should have one hot and one cold ac line and the radiator fan should be running.
Aug 04, 2012 | 1999 Cadillac Seville
RVP 8000 A/C just experienced slight power surge. Compressor on.
I'm leaning toward sticky relay as well, but if you want to confirm it's not thermostat, remove thermostat from wall, and temporarily disconnect the yellow wire from thermostat (compressor) when/if, it happens again. If compressor stays running, I'd say relay for sure.
Just for future reference , Gray wire from thermostat is low fan, green wire is high fan, yellow is compressor, blue is ground. ( For cooling side) The red is 12 v + to furnace and white is negative to furnace.(heat side)
Jun 10, 2010 | Coleman Mach 15 Air Conditioner
Duo-Therm Sunchaser XL
Your wire size and breaker is correct and should be fine as long as all connections are tight and plug and receptacles are OK. Does any part of the wire get warm? Check the temperature of the plug (plugs/sockets) and cable at each end.
Aug 03, 2008 | Dometic Rooftop RV Air Conditioner
Compressor on ac unit
It could be a relay for the compressor is sticking in the run position.
If it is only about one week old take it back to the dealer for service or call them and tell them your problem. This should be covered by warranty and the dealer can refer you to someone authorized to do the work.
Jul 08, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
85 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
