Question about Canon PowerShot A70 Digital Camera
Canon powershot s21s problem
Can you help me fix my camera? Every time I take a picture the screen goes black and I need to turn it on and off again to take another.
I can not see subject, screen is blank. The set up program can be seen. When I switch to camera mode all setting are on screen but, the screen is blank.
Thank You
My email is gttyna5@gmail.com
  • Anonymous Jun 01, 2008
    I'm getting the same problem but the screen is just blank when i switch the camera on, i can see that the shutter does not open and when the lens comes out i can hear a click noise
    Screen is blank. Looking into view finder it has symbols I cannot read. Batteries are new and charged.
My camera is doing the same thing, seems to be a trend.....has anyone been able to figure out how to fix the problem?
Thanks
Posted on Jun 24, 2008
I AM HAVING THE SAME PROBLEM.
Posted on Jun 16, 2008
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/26928900@N00/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
Our canon powershot s21s appears to be working except the screen and the veiwfinder are black. What does this mean?
A stuck shutter is another common failure mode for digital cameras, and especially so for the Canon S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Mar 22, 2011 | Canon PowerShot S2 IS Digital Camera
Unable to take pictures
Your camera will need a lens. Contact Canon regarding repairs (it may be covered due to a CCD Imager fault)
Apr 02, 2010 | Canon PowerShot S2 IS Digital Camera
Canon Powershot SI screen goes black after taking a photo
That sounds like a sticky lens shutter. They usually have to be replaced, as they usually will need parts. When the camera is working look inside the lens and take a picture(with flash turned off). You should see a black shutter door clicking shut in the lens. When the camera acts up, look inside the lens again. If the door is staying shut full time, that is your problem.
Nov 17, 2008 | Canon PowerShot S1 IS Digital Camera
The symptoms are indicative of a CCD imager failure. But you can sometimes jog it back by trying the following:
http://www.fixya.com/support/t295396-canon_s2_black_screen
If the above works, recommend taking a photo at least once a week in a well-lit area to keep it running.
Jun 27, 2008 | Canon PowerShot S2 IS Digital Camera
Canon Power Shot S21s screen is black
Hey birdstrike,
According to the manufacturer there are two options. You can try pressing the display (DISP.) button, and if that doesn't work you are probably going to have to get it serviced by an authorized service center. There is a know problem with the CCD sensor on this camera and other model cameras that causes a malfunction when the camera is exposed to heat or humidity. Canon is covering this repair, and I have included a link below to the instructions on what to do.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Sincerely,
Allan
Go Ahead. Use Us.
May 09, 2008 | Canon PowerShot A75 Digital Camera
I had what Canon suggested was a ccd image sensor problem with my S2 IS, did as they suggested, filled out their form, printed it out, talked to a rep about the problem, sent the camera in to their service repair, only to hear from them that their solution was to let them repair it for $127.00, or purchase a, get this now a "refurbished" newer model S3 IS for $175.00 with a 30 or 90 day warranty on it..HAHAHAHA...why on earth would anyone add an extra expense to what the camera's value was at purchase in my case the cost for the camera was $349.00, or buy the next step up from and S2 to an S3 IS, that has already been refurbished for whatever reasons for $175.00...and hope that this camera screwed up before the limited warranty expired..and by the way I had only had my S2 IS for 18 mos.
In my opinion Canon needs a class action law suit filed against them for not honoring a product that has a history with the image sensor, refering to the S1 IS...and now already wanting to replace an S2 with a refurbished S3...DON'T THINK SO..
Apr 04, 2008 | Canon PowerShot S2 IS Digital Camera
Black screen
Sounds like you have a bad CCD. You can try contacting Canon to check out your options on how to get this repaired. Unfortunately the S2IS is not on their CCD recall list of cameras.
Mar 06, 2008 | Canon PowerShot S2 IS Digital Camera
I have the same problem with my S21S. A long time ago, I tried to find-out what size SD cards would work on this camera. Since there was NOTHING listed in the specifications, I tried a 4GB card. The camera simply would not recognise it, but worked fine when I returned the 1GB card to it. A few days ago, I popped-in a 2GB card to see if that would work. The camera seemed to accept it, and created a directory on it, but this is when my screen went blank. the only thing that is constantly present is a small hand symbol. The stored images can be displayed, and the menus work... I think its locked-up. Is there an "all reset" button, or sequence somewhere? TIA!
Nov 14, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot A70 Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
